Author Topic: Forged pistons  (Read 2683 times)
Forged pistons
« on: December 16, 2009, 10:12:39 AM »
I wonder what the opinions are about valve/piston clearances with forged pistons with -1% silicon. I understand ok that thermal expansion is greatest in this type of forged piston, but should clearances be adjusted accordingly? I need to machine deeper valve reliefs and the plan is to aim for 0.060". Should I bump exhaust to maybe 0.080" with these?
Ross suggested more clearance than this, but my go-to guy is from the automotive side and I don't want to overdo it.
Offline mec
Re: Forged pistons
« Reply #1 on: December 16, 2009, 11:11:36 AM »
what bike, rpm, rev limiter, steel or alu con rods, heavy duy valve springs?????
mec
Honda Monkey
Takeuchi TB 070
Massey Ferguson
Re: Forged pistons
« Reply #2 on: December 16, 2009, 11:53:12 AM »
It's a cb550, (572cc CR+-12:1) there will be a rev limiter, stock steel balanced rods, Kibblewhite valve springs and a Megacycle 12620 cam.
This is not a full blown GP engine, but it is being built for vintage racing and will rev to wherever the power drops drops off once I can get it done & on a dyno.
« Last Edit: December 16, 2009, 12:18:59 PM by bwaller »
Offline mec
Re: Forged pistons
« Reply #3 on: December 16, 2009, 12:18:48 PM »
you are on the safe side with 1,3mm in and 1,5mm ex valve clearance minimum (not TDC).
valve to valve 1,3mm min.
jm2c
mec
Honda Monkey
Takeuchi TB 070
Massey Ferguson
Re: Forged pistons
« Reply #4 on: December 17, 2009, 04:48:30 AM »
Thanks mec.
