Author Topic: Alternate part available??????  (Read 965 times)
Offline Gnat
« on: December 16, 2009, 02:45:27 PM »
I'm a newbie who is having sticker shock...be gentle..please
I am rebuilding my 1974 cb350F-1 engine. Well I'm ordering parts which is the same thing...right? Anyway all of the hardware from the clyinder head cover and cylinder head are missing. So I go to an OEM parts house and find that the washers in the clylinder head that go under the capnuts that screw to the case studs are between 3 and 4 USD apiece. The description is 8mm washer,seal and 12 are required......50 bucks for 12 washers...come on...not really :o
Got to be another way here..all the rest is priced accordingly...meaning its 10X too expensive but 100X is just rediculous.
Help!
Gnat
"Trying to keep the rubber side down"
Offline tlbranth
Re: Alternate part available??????
« Reply #1 on: December 16, 2009, 04:18:55 PM »
I'm not familiar with your bike but a straight washer - even stainless would be a few cents. If the washer is also a seal, how about a small crush washer - NAPA.
Don't own a Vanagon
Don't work at Boeing
Life is good
1970 CB750 K0
1975 GL1000
1999 GL1500
Terry
Offline gane
  • Gane
« Reply #2 on: December 16, 2009, 06:41:12 PM »
Gnat, washers are copper, and thicker than typical "sealing" washers as they need to withstand the torque of head bolts. I'll check my stock at work tommorow as I only have  3  here.  If I have enough, and you''ll PM me an addess, theyre' yours. G
« Reply #3 on: December 17, 2009, 01:51:30 AM »
There is some hardware that is "Special"to Hondabikes and dfficult to get elswhere, like the fibre washers under the screw heads that hold the petcock on and your head nut washers, unfortunately if you need new, unless you are willing to pay for a few 1,000 production run, you are normaly stuck with Honda prices
