I wanted to do the cable, I saw it on a yamaha forum and it does look really clean. I dont have access to a welder and I'm trying to keep everything on the bike "removable". Just so if I ever wanted to turn it back to stock and do a resto.
BUT...if I do decide to go with the cable...
where the cable is hooked up at the drum (not to the actual actuator, but where the cable is "seated"), did you guys cut it off another bike's drum and weld it on, or did you just fab one up?
Where do you source a cable, will any motorcycle rear drum cable work? (cb160, yamaha, etc...)
