But what about the splashes that don't make it out of the boat??? Theres no way that ALL the water gets out of the boat! Eventually all the little drops that don't make it out will sink the boat!!! Wonder how heavy you're typical flat bottom boat would have to weigh to force the water out and over the hull... Someone smarter than me figure it out.
If you turn your headlights on while driving faster than the speed of light,what will happen?will the light be going twice as fast, or will it kind of just bleed off the sides? kind of like water.
Quote from: vanillagorilla on December 17, 2009, 05:19:17 PMBut what about the splashes that don't make it out of the boat??? Theres no way that ALL the water gets out of the boat! Eventually all the little drops that don't make it out will sink the boat!!! Wonder how heavy you're typical flat bottom boat would have to weigh to force the water out and over the hull... Someone smarter than me figure it out. That was not the question..Mick
Quote from: retro rocket on December 17, 2009, 05:24:29 PMQuote from: vanillagorilla on December 17, 2009, 05:19:17 PMBut what about the splashes that don't make it out of the boat??? Theres no way that ALL the water gets out of the boat! Eventually all the little drops that don't make it out will sink the boat!!! Wonder how heavy you're typical flat bottom boat would have to weigh to force the water out and over the hull... Someone smarter than me figure it out. That was not the question..MickNeither was anything relating to a bilge pump!
If you are traveling backwards at 101% the speed of light, are you moving forward at 2997924.58 meters per second?
Quote from: soichiro on December 17, 2009, 05:06:22 PMQuote from: Industrial Cafe on December 17, 2009, 04:17:21 PMif you poke a hole in a boat and the water squirts over the side, will it sink?I don't think I fully understand the question...Is the hole poked in the bottom of the boat? And you're asking, if the water comes up through the hole, will the boat still float or sink? He's asking if the hole was poked in the bottom of the boat, and that water had enough pressure to be shot outside the boat, would it sink....Don't ruin it with the obvious, Soi
Quote from: mlinder on December 17, 2009, 05:07:50 PMQuote from: soichiro on December 17, 2009, 05:06:22 PMQuote from: Industrial Cafe on December 17, 2009, 04:17:21 PMif you poke a hole in a boat and the water squirts over the side, will it sink?I don't think I fully understand the question...Is the hole poked in the bottom of the boat? And you're asking, if the water comes up through the hole, will the boat still float or sink? He's asking if the hole was poked in the bottom of the boat, and that water had enough pressure to be shot outside the boat, would it sink....Don't ruin it with the obvious, Soi I had my explanation typed up, but I deleted it so as not to ruin the fun for everyone else. I'll just state my conclusion. And this should leave many of you scratching your heads...The boat sinks. And believe it or not, the way the problem is stated, it sinks even if there wasn't a hole.
IC i find most of your posts amusing but sometimes they really piss me off....got anything constructive to add....Mick
Move on mate ....your the only one not getting it....Mick
