Author Topic: Carburetor Synchronizer  (Read 19922 times)
Offline mycb750k6
  • "res ipsa loquitur"
  • Rocketman
    • photobucket albums
« on: December 20, 2009, 04:21:04 PM »
Would someone recommend a Carburetor Synchronizer? There a few on ebay but I'd feel better with a recommendation from one of you experts if you don't mind. Also is there a FAQ on Carburetor Synchronizing. I swear I looked.
bmarshall
Re: Carburetor Synchronizer
« Reply #1 on: December 20, 2009, 04:33:31 PM »
+1, inquiring minds want to know
Offline myhondas
  • Not really such a
« Reply #2 on: December 20, 2009, 04:46:32 PM »
only saw two different ones for the 750 on ebay. one was from a guy who bought it and never used it. the other is from a ebay store. Looks like either one would work.
1974 CB 750 K4 SHOWROOM
1965 C100 CUB 50 (PIT BIKE)
1996 VF 750 CD daily rider
SOHC# 5105 11228
Offline Gordon
  • 750K1, 550K2
« Reply #3 on: December 20, 2009, 04:48:19 PM »
I try not to post this too often, in fact I rarely do, but here goes:
Use the search....
Offline Whaleman
« Reply #4 on: December 20, 2009, 04:50:33 PM »
I like this kind. Dennis Kirk sells them cheap. www.denniskirk.com  Dan
Offline Gordon
  • 750K1, 550K2
Offline Kframe
  • Life is good!
« Reply #6 on: December 20, 2009, 05:44:36 PM »
If you like rigging up your own stuff, and saving a buck, you can very easily make your own.
Here's just one version found on the interwebs.
Linky
The one I made is mounted to an L shaped board/base from plywood, and you have to put in restrictors, which are just two one inch sections of very narrow tube (toothpick sized inside diameter) spliced inline near each end.  I found little nylon spacers that worked as restrictors in those drawers of Hillman fasteners at the hardware store.  Most Ace and Our Own, True Value, have those drawers.
The restrictors damp the fluid, so it doesn't "boil" from the intake pulses and also slows the rise and fall of the fluid so you have time to make fine adjustments.
Here's mine:
-K
2007 Triumph Bonneville T100, ARK'd, Pods, TOR's, Napoleon's, Innovate G5 Air/Fuel Gauge, Ignition Relocation by D9, Stebel Nautilus, Avon Roadriders
1984 Honda Shadow VT700c, Stock
1974 Honda CB550K, In rehab
1986 Honda Helix
Offline torrinh
  • If you don't ride in the rain, you don't ride.
« Reply #7 on: December 20, 2009, 06:12:07 PM »
Morgan Carbtune
1983 Kawasaki GPZ 750
1978 Honda CB750K w/ 1976 CB750F1 motor
1979 Suzuki GS550L
Offline MickeyX
« Reply #8 on: December 20, 2009, 07:54:02 PM »
Morgan is well worth the money. It is usually cheaper to go directly to them. Ours was around $70 and we can sync all 4 at one time without worrying about sucking fluid into the engine. So easy to setup.
Offline johnyvilla
« Reply #9 on: December 20, 2009, 08:02:48 PM »
I agree with Whaleman- these units are cheap, convenient and work well hanging from rafters.
http://forums.sohc4.net/index.php?action=dlattach;topic=63048.0;attach=98274;image
Offline B.O.X.N.I.F.E.
  • The Stumped
« Reply #10 on: December 20, 2009, 08:43:44 PM »
Morgan Carbtune.
1974 CB550
Forever West
« Reply #11 on: December 20, 2009, 10:37:36 PM »
what ever 4 vacuum gauge set you buy,first thing is to use all the tee connectors etc and hook them all up to a single good vacuum source like the vacuum advance port on your car,bring the revs up to produce a steady idle and see that all the guages are reading the same,use a magic marker and write say either a subtract or add value on the guages which might be a little out,,use one of the gauges as your base line.
Offline Lars
« Reply #12 on: December 21, 2009, 01:32:50 AM »
+1 on Morgan Carbtune.
...if you got the ability to act...
Offline Duke McDukiedook
  • Space Force 6 Star General
« Reply #13 on: December 21, 2009, 02:12:47 AM »
Everyone that gets the Morgan loves it, that should say something.
Offline Johnie
« Reply #14 on: December 21, 2009, 05:48:14 AM »
+5 on the Morgan. This is the last piece of the puzzle you will use to get that bike running great. Do not skrimp on the $$$ here. It is well worth the cash and the unit has proven itself on this board. I have used mine since 1999 and it still works like new. I can dial in the carbs perfectly every time. Go for the gusto man... ;D
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline mycb750k6
  • Rocketman
« Reply #15 on: December 21, 2009, 06:07:40 AM »
OK Morgan it is then. Thanks guys. They sell for sixty bucks on ebay so I bought one. Glad I asked since I was considering that more expensive one in the plastic box. So I also ran across this instruction on how to use the Morgan from salocal: http://www.salocal.com/sohc/tech/carb_sync/carb_sync_2.htm
I'm still unclear about one thing. Should the vacuum gauges be synced against each other on one carb before attached all four gauges to all four carbs? Otherwise how do you know your syncing the carbs and not the gauges? Sorry, sometimes I need it spelled out for me. Also what is the acceptable value on the gauges when you sync or is it just as low as possible and all the same?
Offline NickC
« Reply #16 on: December 21, 2009, 07:21:27 AM »
I used one of these to dial mine in when i first received it
Offline JBMorse
    • Travel Blog
« Reply #17 on: December 21, 2009, 08:20:34 AM »
I don't think you need to sync the morgan first.  I don't remember anything about that in the instructions.  The carbtune has those metal slides instead of a fluid, which I like.  The Carbtune.com website has the instructions that you get with the tool when you buy new.  There's some extra info there as well.
Good luck!  I'm sure you won't regret the purchase.  It makes life so much easier.
1971 CB500K
Offline Johnie
« Reply #18 on: December 21, 2009, 10:47:19 AM »
Agreed...never heard of calibrating the Morgan. Never did it. Always had great results. The only big difference from the new Morgan and the one I got in 1999 is mine came with the brass nipples. I hear they are plastic now. You may want to contact Z1 Enterprises to get some extensions for the ports. Makes it a lot easier to get the nipples in place on those port holes. The extensions are not expensive either.
Oshkosh, WI  USA
Offline ev0lve
« Reply #19 on: December 21, 2009, 11:12:02 AM »
No syncing of the gauge required. Just plug it into the carbs and go. On the K just pick the two carbs furthest out and get them right then the next two and so on.
The level the gauge shows is kind of immaterial as long as they're all reading the same - takes about 15 - 20 minutes adjusting idle and such  ;D
« Last Edit: December 21, 2009, 11:14:34 AM by Iggy »
Offline Johnie
« Reply #20 on: December 21, 2009, 01:45:19 PM »
And be sure you put a couple of good fans on that engine while it is idling so you do not overheat.
Oshkosh, WI  USA
« Reply #21 on: December 21, 2009, 01:50:18 PM »
One is enough.
« Reply #22 on: December 21, 2009, 02:12:12 PM »
just get all readings the same....and keep the tubes from falling onto your engine! they'll melt in no time....  :o
(wondering why #1 suddenly went to hell, while i'm standing next to #4) :-[
f'n rookie!  :D
Offline Tnutz
« Reply #23 on: December 21, 2009, 02:22:12 PM »
i have the 4 guage kind. i bought it on ebay for a decent price.
2004 Ducati 999 mono posto.
-Full Termignoni exhaust
-Lots 'o' carbon fibre
1973 Honda cb500/4
-Motor Rebuild
-Has clubmans
-Paint is sub par
Offline Johnie
« Reply #24 on: December 21, 2009, 02:23:11 PM »
One is enough.
On those hot days 1 is for the bike and 1 is for me...  ;D
Oshkosh, WI  USA
