Author Topic: 1977 CB550 K cafe racer build  (Read 234975 times)
traveler
Re: 1977 CB550 K cafe racer build (completed 26 Jun 2010!!!)
« Reply #825 on: June 27, 2010, 09:22:51 PM »
PM sent Mick.
This carb leak makes ZERO sense.  I have started a thread reference this in the sohc/4 section.
~Joe
Offline HedNut
  • Underwater Basket Weaving
« Reply #826 on: June 28, 2010, 05:01:59 AM »
Hey Traveler!! BIKE LOOKS KILLER MAN!! Great work!!  Love your sync n' breather tips too!...Excellent!!  Great JoB! Looks awesome!
traveler
« Reply #827 on: June 28, 2010, 07:17:26 AM »
Thanks!
You don't happen to have a spare PD carb laying around, do you?
~Joe
Offline HedNut
« Reply #828 on: June 28, 2010, 09:16:52 AM »
I don't......sorry...
Offline Little_Horse
    • My cafe build
« Reply #829 on: June 28, 2010, 11:25:40 AM »
bike looks great, but you probably aren't done. I thought I was done but I am still changing and fixing things. Also for those of use following, or pretending to follow we hope you aren't done too  ;D.
"Little Horse Cycles" facebook page: http://www.facebook.com/pages/Little-Horse-Cycles/185809474769493
LHC is my start up cafe racer shop specializing in custom parts, bikes, restoration and recreation
The 500 builds http://forums.sohc4.net/index.php?topic=64250.0
« Reply #830 on: June 28, 2010, 11:28:33 AM »
Thanks!
You don't happen to have a spare PD carb laying around, do you?~Joe
I've got some PD's left, do you need a complete carb or just a body?
Offline greasy j
  • lanesplitting
  • non serviam
« Reply #831 on: June 28, 2010, 11:41:13 AM »
congrats! your bike is one of my faves for sure. just beautiful!
Offline Zaipai
    • My Home page
« Reply #832 on: June 28, 2010, 08:39:31 PM »
Joe, I was re-reading this, and I think instead of changing out the carbs.. it maybe better to do this..
By HondaMan:
Hop-ups: Add 4 teeth to the rear sprocket and get a cam. Don't get high lift, get longer duration - BUT: not a LOT more duration, because it is a small-bore engine. A little goes a long way. Adding 5 degrees of overlap and 10 degrees of duration should be your limit for non-racing driving: it will REALLY wake up the "mid-four". Don't bother with bigger carbs: port it in the head instead. The stock carbs can make a lot more HP than they do: make a "pocket" above the intake valve, then raise the exhaust ports about 2-3 mm and smooth 'em out. This will add up to 10 HP to this neat engine, which is a lot.
Just a thought..
.: Scott :.
Its my Avatar..
75 CB550F  |
traveler
« Reply #833 on: June 28, 2010, 09:03:18 PM »
I'm just going to keep fiddling with my PD carbs for the time being....thanks though.
~Joe
traveler
« Reply #834 on: June 28, 2010, 09:10:35 PM »
Thanks!
Either, but need a 46A model.  Prefer a complete #1 carb.
~Joe
« Reply #835 on: June 29, 2010, 04:31:29 AM »
PM your address again.
traveler
« Reply #836 on: June 29, 2010, 04:37:45 AM »
PM sent.
Any help would be appreciated.
Name the cost...seriously.  I have too much time and energy invested to not get it finished up like it should be.
Fighting hard to keep depression from setting in. :-\
~Joe
« Last Edit: June 29, 2010, 08:38:13 AM by traveler »
traveler
« Reply #837 on: June 29, 2010, 05:08:57 AM »
Looks like "bwaller" is going to help me out.  A ray of sunshine to say the least. ;D ;) :D
Me and carbs mix like oil and water.  I've ALWAYS had a bear of a time with them....some things, you just have to farm out, I guess.
~Joe
traveler
« Reply #838 on: June 29, 2010, 07:04:56 PM »
Well, bwaller cleaned up the carb, inspected it, and all is well.  I went ahead and ordered a new float needle and a new gasket set so HOPEFULLY a leaky #1 is a thing of the past.
Carb mails this week, parts mail tomorrow, 108 mains will be here any day.....time to do do some serious corner carving!
~Joe
« Reply #839 on: June 29, 2010, 07:06:54 PM »
Good stuff Joe, hope it all works out for you....
traveler
« Reply #840 on: June 29, 2010, 07:12:17 PM »
Thanks, Mick.  When will you start your build?  I know you have been gathering parts, but any idea when the INITIAL build up will begin?
Thing is gonna be a beast, I know. ;)
This 550 REALLY handles nice.....just need the motor pulling at 100%.
~Joe
Offline Zaipai
    • My Home page
« Reply #841 on: June 29, 2010, 07:37:13 PM »
~Joe
+1
Then you can come spend a week here and get mine humming.. Its ok now, but I bet you could get spot on.. ;)
.: Scott :.
Its my Avatar..
75 CB550F  |
traveler
« Reply #842 on: June 29, 2010, 07:51:57 PM »
no...yours is fine.
Cycle X was having a "blue light special" on 550 drag pipes a day or so ago.......REALLY marked down, and these were PROFESSIONAL quality, not cheapo's....even had me thinking it over......but I want a Mac 4-1, black with a chrome tip!
~Joe
Offline Zaipai
    • My Home page
« Reply #843 on: June 29, 2010, 08:03:36 PM »
no...yours is fine.
~Joe
Yes I was watching. Those were the ones I wanted. However I wanted them in black, and still working out details on money. I have another day 1/2 before I need to pull the trigger.. Yes, as I understand it the 4 - 1 exhaust is best for WOT and since I do mostly town hopping.. I don't mind 4 - 2 or drag pipes..
.: Scott :.
Its my Avatar..
75 CB550F  |
traveler
« Reply #844 on: June 29, 2010, 08:07:25 PM »
I may patch my pipes....but I'm not real happy with them.  I'd like to have a set of Benji's STAINLESS 4-2's with peashooter tips.  He even gives you a choice to baffling depending on the sound you wnat.  I think I would want the high pitch schreik over the loud rasp.  Problem is, Benji want's damn near a grand for them!!!! :o :o :o
~Joe
« Reply #845 on: June 29, 2010, 10:22:34 PM »
~Joe
Well i have most of the parts mate but i have limited room to actually start building. I still have a few parts to get yet and a couple of parts are still being developed {not allowed to give away any more info than that  ;D} So hopefully it won't take too long to get the rest of the bits and i can start soon. I was just going through what i already have and i really am having a hard time containing myself... ;D   Really would like it finished by Christmas, i will be doing a build thread and everyone is invited... ;)
Offline Zaipai
    • My Home page
« Reply #846 on: June 30, 2010, 03:58:16 AM »
Can't wait RR gonna be watching for that build thread to start!
.: Scott :.
Its my Avatar..
75 CB550F  |
traveler
« Reply #847 on: June 30, 2010, 08:13:58 PM »
I ordered a brand new MAC 4-1 exhaust tonight.  It is black with a chrome tip.
My 108 main jets arrived today, and Western Hills is sending me some O-Rings and a new float needle.
This...the good #1 carb coming in from BWaller, and HOPEFULLY she will run right. ;)
~Joe
Offline Zaipai
    • My Home page
« Reply #848 on: July 01, 2010, 05:32:46 AM »
Awesome man! From what others have said, the 4 into 1 is going to work well for the type or riding you are going to be doing..
.: Scott :.
Its my Avatar..
75 CB550F  |
traveler
« Reply #849 on: July 01, 2010, 04:15:51 PM »
So....do we need to talk about a certain beat up 4-2 in need of a home, or are the drags coming?
With some WORK, these pipes would be really sweet......I jsut really wanted the 4-1 for my cafe, and stainless ones from RocCity were $1K, and flipprboi at BCR wanted 850...so I got what I wanted.
in short....want 'em?  I'll let you have them for the cost of shipping, Scott.
~Joe
