Author Topic: Solid State bCharging systrems  (Read 2025 times)
CHUNG
« on: April 22, 2005, 09:47:42 PM »
I have been dealing with several bikes from the CB650 to the CB750, 1979-82 erea that have battery charging issues.
This is a Combo Reg/Rec unit. The Diodes check fine but the bike won't charge. There are two componants involved in one "black box" We use RICK"S ENTERPRISES for replacements. BUT he offers a seperate VOLTAGE REGULATER that might solve the problem of replacing the entire ASSY rather than the failed componant.
The Rectifier will bench test fine so the problem is in the regulator 1/2 and there seems to be no need to replace the entire assy at almost twice the cost of a regulator.
SOOOOOO, when you guys switch from the mechanical regulator to the solid state units, buy them NEW from RICK as two seperste items so that when they do fail, you can simply replace the failed unit.
I haven't "field tested" this yet but I have a few mules to do some diabolical testing on 8)
Offline SteveD CB500F
  • Ride on the Steel Breeze...
    • TVAM
Re: Solid State bCharging systrems
« Reply #1 on: April 23, 2005, 04:47:51 AM »
Let us know how the mules get on.
If this system is OK, we'll add a link in the General FAQ
SOHC4 Member #2393
2015 Tiger 800 XRT
1971 CB500K0 (US Model)
Offline SCJIM
« Reply #2 on: April 23, 2005, 08:48:52 PM »
hey chung.
i have been beating my head against a wall about the charging issue with my 81 CB650c
and i would love to know more about how to test my system
right down to the component level
Jim in SC
1981 CB 650 Custom
