Author Topic: Fork pipes?  (Read 1157 times)
Offline MattFreeman
  • What Have I Done?
Fork pipes?
« on: December 23, 2009, 06:13:39 AM »
So I dropped a little question regarding this on a different thread, in an effort not to jack I didn't get too specific.
So what I'd like to know specially is: will any upper fork pipes/tubes fit my '76 CB750F lowers?
While I'm at it, does any one have a pair of clean ones that will work?
Thanks in advance.
Matt
Re: Fork pipes?
« Reply #1 on: December 23, 2009, 09:06:48 AM »
73 -76 are the same, 77/78K are chromed, dont rust easily.
Offline MattFreeman
  • What Have I Done?
Re: Fork pipes?
« Reply #2 on: December 23, 2009, 10:14:31 AM »
So would the 77/78's not work with my 76 lowers?  Are the K's same as the F?
Would the 77/78 lowers work with my 76 brake and wheel?
I apologize if I'm getting into previously covered territory.
MF
Re: Fork pipes?
« Reply #3 on: December 23, 2009, 10:29:40 AM »
77/78 K tubes will fit, and the whole leg assembly..lower are longer, and easier to get fork braces for.
 77/78 F forks have a diff lower and brakes, tubes may work, but I am not sure on them..
Offline somesuch
Re: Fork pipes?
« Reply #4 on: December 23, 2009, 11:02:05 AM »
I had a problem with mixing and matching tubes/lowers. I am NOT sure of the years, but in addition to longer lowers, the damping rods and the corresponding bottom out cones are different between the years and you have to be careful when mixing those. Early years centered the bottom out cone in the lower by a the cone having a 35mm "foot", later cones did not have a wide foot, but fit in a pocket machined in the lower.....those probably should not be mixed :) The damping rods also differ between the years in their length, diameter of the shaft, damping holes, the piston/roll pin arrangent.
The bottom line is:   the diameter of the damping rod shaft needs to be the same as that of the (new) tube and that may necessitate the use of different damping rods, which may necessitate a look at the bottom out cones. Do not use the (smaller) cones that are designed to be centered by a machined pocket in the lower that does not have such pocket, relying on the bottom bolt to center it!
It is pretty simple when you see it, just my retarded explanation seems complicated...
--Nick
