I always lied the look of the F4U Corsair. My Uncle told me about them and I used to watch Baa Baa Black Sheep which was a short lived TV series.
Plane type: Single-seat fighter
Manufacturer: Chance-Vought
Crew: 1 (pilot)
Dimensions
Length: 33ft 4in. (10.15 meters)
Wingspan: 41ft (12.5 meters)
Height: 14ft 9"in (4.5 meters)
Powerplant
- Most models: 1 x Pratt & Whitney R-2800-18 double-row radial air-cooled engine @ 2000 h.p.
Weights
Empty weight: 9205 lbs (4174 kg)
Loaded weight: 14700 lbs (6650 kg)
Armament
- 6 x 50 cal machine-guns, 3 mounted on each outer-wing
(NOTE: 2 x 20mm cannons could be mounted on each wing instead)
- 2 x 1000 lb bombs may be carried under fuselage
- 8 x rockets may be installed, 4 under each wing
Performance
Maximum speed: 446 mph (718 Km/h)
Maximum range: 1005 miles (1618 km)
Ceiling: 41500 feet (12649 meters)
