Author Topic: tapered roller lower/ball bearing upper?  (Read 4431 times)
Offline Alan F.
« on: December 24, 2009, 08:04:25 PM »
A coworker mentioned this to me the other day, says it's a great improvement.
Anyone tried it on a vintage bike?
Would there be much use on a stock streetbike, or is it only beneficial if you ride hard or race?
-A
Offline Industrial Cafe
  • Like a well oiled
    • Undead Asphalt
Re: tapered roller lower/ball bearing upper?
« Reply #1 on: December 24, 2009, 08:08:27 PM »
strange, I would think roller top, roller bottom would be better.
« Reply #2 on: December 24, 2009, 08:25:15 PM »
I'd have to ask for clarification. "Great improvement" compared to what?
Sure its better than balls top and bottom. Since the bottom does the lion's share of the work.
But why leave the balls on the top? Other than it might be easier.
I doubt you can buy tapered bottoms without taperd tops economically, (sold as a set). So why not just put them in?
Still I'd like to hear the explanation for the statement "great improvement".
« Reply #3 on: December 24, 2009, 08:43:03 PM »
 I assume greater weight bearing/load capabilities with the tapered bottom (wear the real load is as was said) but less friction with balls at the top. That would all have to do with bearing contact area with the race. Trying to get the best of both worlds.
« Last Edit: December 24, 2009, 08:46:56 PM by MRieck »
Offline bucky katt
  • i am a pastafarian!
    • facebook
« Reply #4 on: December 24, 2009, 11:44:31 PM »
ok, we are talking about steering head arent we?
Mark Twain - Notebook, 1894
« Reply #5 on: December 25, 2009, 06:26:16 AM »
Yes
Offline Johnie
« Reply #6 on: December 25, 2009, 06:30:15 AM »
Where are the race dents mainly showing up, top or bottom race or both? I am doing the K4 top and bottom soon and the dents are the worst I have seen.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
« Reply #7 on: December 25, 2009, 11:33:40 AM »
I think it may partly be a matter of convenience.
 As most of you know, you cannot buy drop in tapered rollers, they are taking existing sets, and modifying OD or ID.
 If you are making your own trees & stem, or just a stem, you have choices, of other sizes, ie a smaller OD race will fit easily with a shim bushing.. say a 22mm or 7/8 ID.
 So it might be a case of what was easy, and yes, I think taper on the lower is a help. But the convenience of quick tree or complete fork removal with 2 tapereds, is the icing on the cake..
« Reply #8 on: December 25, 2009, 12:54:23 PM »
YEs besides the ease of simply replacing the top with OEM, there would be less friction, so maybe there is a gain. I may do that next time just to see.
And to another poster, I've never seen a top OEM race dimpled, just the bottom.
« Reply #9 on: December 25, 2009, 01:24:36 PM »
Run em real tight, & they will..
Offline Alan F.
« Reply #10 on: December 25, 2009, 06:02:18 PM »
I understood that to be what he was describing, they had switched one of their track bikes to new tapered rollers, then switched to balls and stock races at the top.  I understood that less friction translated into faster steering/faster feedback to the rider.
-A
Offline Yoshi823
  • Biker to the bone.
  • Never too old to be a biker
« Reply #11 on: December 26, 2009, 11:43:06 AM »
-A
Don't the more recent top of the range Honda Sportsbikes like the newer Fireblades have this setup now?
Bikes...they're in the blood.
Yamaha 2001 R1
Yamaha 1990 FZR1000R EXUP
KTM 2004 450 EXC RFS
Honda 1997 XR400R
Honda 1988 CB125T2
http://www.cb750cafe.com/bikes.php?cat=3&id=67
Offline Old Scrambler
« Reply #12 on: December 28, 2009, 12:40:44 PM »
Hmmmmmmmmmmmmmm....so one set would do two bikes (with appropriate bottom spacer) and the top space would be correct to hold the stock ears.........Hmmmmmmmmm?
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
Offline Alan F.
« Reply #13 on: December 28, 2009, 04:02:59 PM »
No, the top bearing and the bottom bearing are usually different sizes.  I'd call up All-Balls and try to just buy the bottom bearing and maybe the spacer, they're known for making odd matched kits for triple tree swaps, maybe they'd play ball. oops... ::)
