Author Topic: When doing rearsets......  (Read 2639 times)
Offline YogiBear
« on: December 23, 2009, 08:05:41 PM »
I plan on putting rearsets on my CB500 eventually.  This forum has been outstanding as far as sources and pictures of mounting rearsets. One idea ive tossed around is using a backing plate that mounts with the swingarm pivot bolt and the motor mount bolt that holds the footpegs. (as ive seen on here) The question I have is if I were using flat stock to make my backing plate, would the pivot bolt still be long enough after I run it through the backing plates on either side so that the nut would still tighten down enough to be safe? Let me know if that doesnt make sense.
1974 Honda CB750K4        1973 Honda CB500 Four
Offline Triffecpa
Re: When doing rearsets......
« Reply #1 on: December 24, 2009, 07:21:20 AM »
any plate that is thick enough to provide solid backing for the rearsets would likely make the pivot bolt too short if you're running the bolt thru two plates.
Tracy
Offline SonnysTile
« Reply #2 on: December 24, 2009, 07:26:20 AM »
I had a set of Tarrozi bolt ons on my 500 and they looked fantastic!
installation took less than an hour.
totally worth it.
1972 CB500, 1975 CB400F, 1967 CA160
Offline YogiBear
« Reply #3 on: December 24, 2009, 01:18:53 PM »
Tracy
Would the solution be to find a longer pivot bolt from a different model CB? Maybe a CB750? Or would the diameter be incorrect? Im trying to plan out as much as I can ahead so I dont end up with a cluster when I go to do the build.
Offline YogiBear
« Reply #4 on: December 24, 2009, 02:00:56 PM »
totally worth it.
and what did you do for a mounting bracket? pictures??...
Offline KB02
« Reply #5 on: December 24, 2009, 02:01:33 PM »
I did what you are talking about on my CB750 K8 project. I got a swing arm pivot from an F2/3. It actually turned out to be a touch too long (better long than short, huh?). In theory, your concept will work. It's just a matter of getting the right diameter bolt (and long enough, too).
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Join the AMA today!!
Offline KB02
« Reply #6 on: December 24, 2009, 02:04:31 PM »
I went through a couple more revisions, but here is the basics of what I did:
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Offline YogiBear
« Reply #7 on: December 24, 2009, 02:43:22 PM »
Oh ya, I remember reading your entire build thread KB02 . Must have missed the part about the pivot bolt. Oops.  ::) I assume you mean the CB750 F2/F3, not cbr? correct?
Online Alan F.
« Reply #8 on: December 24, 2009, 03:47:38 PM »
Yes, that would be correct.  Honda has been using the F, F2, F3 designations for a while.
Offline YogiBear
« Reply #9 on: December 24, 2009, 03:49:28 PM »
Great, thanks.
Offline SonnysTile
« Reply #10 on: December 25, 2009, 10:49:15 AM »
Here's the Tarozzi's...   worth every penny for looks and ease of installation.  Not the same feeling as DIY, but it worked for me.
Offline YogiBear
« Reply #11 on: December 25, 2009, 12:02:51 PM »
Hmm, I really like the way those Tarozzi's mount. Almost makes me want to rethink a design for mounting. I think im going to stick with home made, just because money is a little tight on this project. But thank you for posting those pics of your bike. I like the color scheme on it. Its very old school.  :)
