Author Topic: what should I put here?  (Read 5071 times)
Offline Alan F.
Re: what should I put here?
« Reply #25 on: December 27, 2009, 09:25:20 AM »
How about a radar detector?  This one mounts in a 2.1" hole and it's the smallest I've found...and this price is like $50 less than anywhere else I saw: http://www.amazon.com/gp/product/B000ALGNGO/ref=cm_rdp_product
Considering you're in florida I won't suggest a thermometer as black ice isn't an issue...
An altimeter isn't really a good choice since the tallest mountain in florida is space mountain...
A compass might be useful, but don't they need a flat mounting surface?
Maybe a self destruct button? http://www.strapya-world.com/categories/2331_2869.html
You could mount a deer whistle there... http://www.sav-a-life.com/Deeralert_intro.htm?gclid=CKXRi9WO954CFcNM5QodVXHwcQ
You could glue on a Darth Vader figure facing foreward...
A camera mount?
Foreward cannon mount?
Seatbelt warning light?
[attachment deleted by admin]
Offline Alan F.
« Reply #26 on: December 27, 2009, 09:31:54 AM »
How about a tire pressure monitor?
The display is a little large at 1.7”W x 1.95”L x 1.4”D though...
http://www.doranmfg.com/motorcycle-tire-pressure-monitoring-systems.htm
Offline Industrial Cafe
  • Like a well oiled
    • Undead Asphalt
« Reply #27 on: December 27, 2009, 10:46:33 AM »
the tire monitor is a cool idea, but I think I like the camera mount,
I could use that quite a bit.
I could make a vibration isolation pad out of an in dash cd player, they have little silicone isolators in them.
 I think I have some of those and an old cam mount bolt here somewhere.
I'd have to make it with some sort of quick release doodad.
« Last Edit: December 27, 2009, 10:50:01 AM by Industrial Cafe »
Offline Alan F.
« Reply #28 on: December 27, 2009, 04:23:54 PM »
Good choice, you can always mount a deer whistle or a cannon to it later on too...
The trees I'm using have that spot too, but since I've milled the clutch cable loop and ignition switch loop off to mount my stock clocks it's almost covered.
And the idiot light panel obscures it pretty well too. I'll probably fill it in with some JB Weld an smooth it out so it's not too noticeable.
Cheers.
-Alan
« Last Edit: December 27, 2009, 04:28:53 PM by Alan F. »
  • Like a well oiled
    • Undead Asphalt
« Reply #29 on: December 27, 2009, 04:32:42 PM »
what fork are you running?
Offline Alan F.
« Reply #30 on: December 28, 2009, 10:16:00 PM »
I'll be using 41mm forks and trees from a 91-03 750 nighthawk.
What are yours?
Offline bucky katt
  • i am a pastafarian!
    • facebook
« Reply #31 on: December 28, 2009, 10:53:22 PM »
paint it in a white background then a small rising sun/japanese flag
Mark Twain - Notebook, 1894
Offline mark
« Reply #32 on: December 29, 2009, 01:23:09 AM »
I was going to wire one of these up to Doug's gas pedal....
I guess it would make an ok oil light.
F you mark...... F you.
  • Like a well oiled
    • Undead Asphalt
« Reply #33 on: December 29, 2009, 08:24:48 AM »
What are yours?
50mm 06 gsxr1000 fork and 02 trees.
fuzzy-
the flag idea is cool, but where would I put my camera? ;) ;)
mark-
the slow down light...... whats that off of?
« Last Edit: December 29, 2009, 08:26:49 AM by Industrial Cafe »
Offline mark
« Reply #34 on: December 29, 2009, 08:33:15 AM »
mark-
mid '70s FIAT.
supposedly if you tried to do 70 all day the catalyst would overheat and set the car on fire.
or something like that.
Offline tramp
« Reply #35 on: December 29, 2009, 02:54:45 PM »
how about a shock button
discharge about a 300v cap
you'll know who touched it by the pee mark on thier pants
1974 750k
  • Like a well oiled
    • Undead Asphalt
« Reply #36 on: December 29, 2009, 03:01:08 PM »
HA yeah, how bout tazers in the grips attached to the alarm?
Offline Roach Carver
« Reply #37 on: December 29, 2009, 05:33:36 PM »
tooth brush holder, small vase with a flower.
Offline mystic_1
  • 1970 CB750K
« Reply #38 on: December 29, 2009, 05:45:48 PM »
How about a light that comes on when you break the ton?
Sorta like the JDM speed warning light, but cooler :D
mystic_1
- John Augustus Shedd
  • Like a well oiled
    • Undead Asphalt
« Reply #39 on: December 29, 2009, 05:46:22 PM »
  • Like a well oiled
    • Undead Asphalt
« Reply #40 on: December 29, 2009, 05:47:00 PM »
mystic_1
good idea but, that thing would be on every time I pass someone.
MötleyRöx
« Reply #41 on: December 29, 2009, 05:47:16 PM »
but that is round... you need a square vase.
  • Like a well oiled
    • Undead Asphalt
« Reply #42 on: December 29, 2009, 05:50:16 PM »
hmmm.....
Offline mystic_1
  • 1970 CB750K
« Reply #43 on: December 29, 2009, 06:01:07 PM »
mystic_1
Offline mystic_1
  • 1970 CB750K
« Reply #44 on: December 29, 2009, 06:01:43 PM »
BTW you could make the vase INTO a warning light ;)
mystic_1
  • Like a well oiled
    • Undead Asphalt
« Reply #45 on: December 29, 2009, 06:02:54 PM »
I'm thinking the simplest one might be the best, paint a tiny rising sun in there.
MötleyRöx
« Reply #46 on: December 29, 2009, 06:04:31 PM »
Make sure to leave a black hole in it.   ;)
Offline mystic_1
  • 1970 CB750K
« Reply #47 on: December 29, 2009, 06:07:41 PM »
I do like that idea, seems like it would be the nicest looking, aesthetically.
mystic_1
  • Like a well oiled
    • Undead Asphalt
« Reply #48 on: December 29, 2009, 06:08:03 PM »
a black hole sun?
will it come and wash away my pain?
  • Like a well oiled
    • Undead Asphalt
« Reply #49 on: December 29, 2009, 06:09:01 PM »
mystic_1
I wonder if I could use enamel on brass like a lapel button?
