Author Topic: opposed piston opposed cylinder 2 stroke.  (Read 1966 times)
Offline Industrial Cafe
  • Like a well oiled
    • Undead Asphalt
« on: December 26, 2009, 08:04:45 PM »
an interesting idea.
EcoMotors has a design called OPOC, Opposed Piston Opposed Cylinder. The design is just what it says, as you can see above, with 2 cylinders and 4 pistons. Peter Hofbauer came up with the idea when he was at Volkswagen
, the outboard pistons take the place of the cylinder head and each piston only travels half the distance necessary for the full stroke, allowing higher engine speeds. An electrically controlled turbocharger can be used when necessary with adjustable boost, it can even spin up before the engine starts to give instant boost.
The engine can be built in a modular fashion, allowing more cylinders to be added in pairs with a clutch between the modules so one pair can be used at start or light load with the clutch adding more cylinders when required.
http://thekneeslider.com/archives/2009/12/21/ecomotors-opoc-two-stroke-engines-opposed-piston-opposed-cylinder/
Re: opposed piston opposed cylinder 2 stroke.
« Reply #1 on: December 26, 2009, 11:28:00 PM »
very similar to the old commer "knocker" deisel.
    • http://forums.sohc4.net/index.php?PHPSESSID=cvc4o6vir1cbsds0k6ctq90ip3&/topic,60973.0.html
« Reply #2 on: December 27, 2009, 02:11:05 AM »
the germens did that thing for 60 years ago..
  • Like a well oiled
    • Undead Asphalt
« Reply #3 on: December 27, 2009, 07:48:24 AM »
germany 1932... Damn that master race.   :D :D
nothing is new or innovative anymore.
« Last Edit: December 27, 2009, 07:55:29 AM by Industrial Cafe »
  • Like a well oiled
    • Undead Asphalt
« Reply #4 on: December 27, 2009, 07:52:51 AM »
Offline Gordon
  • 750K1, 550K2
« Reply #5 on: December 27, 2009, 01:10:08 PM »
The difference between the first engine posted and the other two is that in the first one there is only one crankshaft operating two pairs of opposing pistons, and no matter how many more pairs are added on there will still only be one crankshaft.  That's a major difference in the basic design and would be much lighter and probably much more efficient.
Offline Uncle Ernie
« Reply #6 on: December 27, 2009, 01:51:41 PM »
It probably never caught on because it's so slow.
Offline mlinder
  • "Kitten Puncher"
  • Stop Global Tilting now!
    • Moto Northwest
« Reply #7 on: December 29, 2009, 07:31:25 AM »
The length of the con rods to the outer pistons worries me. A lot more reciprocating mass, and a lot more stretch, and a lot more stress.
@ Uncle Ernie: Lawl. It IS slow, isn't it? :P
No.
Offline DammitDan
  • Prodigal Son
  • It lives!
« Reply #8 on: December 29, 2009, 03:24:01 PM »
Course I'm just a layman, but it seems odd to put that much stress on a piston pin.  On most engines the connecting rod is connected to the piston in such a way that the force being exerted is transmitted (pushed) directly to the rod.  In this engine all of the force is being translated to the pin (which reverses the force from a pushing to a pulling motion) and THEN to the rod.  Seems like a weak link, though the fact that it's a 2-stroke may alleviate that issue.
CB750K4
Offline Duke McDukiedook
  • Space Force 6 Star General
« Reply #9 on: December 29, 2009, 03:37:58 PM »
Compression and tension, tensile yielding and failure is probably what you have to worry about with the connecting rods in the first engine. Just like most metal they yield in tension lower than they would in compression. If the length gets long like mlinder was commenting on you would have to be worried about a moment failure too.
  • Like a well oiled
    • Undead Asphalt
« Reply #10 on: December 29, 2009, 03:45:42 PM »
I'll stick with my SOHC 750 motor it sounds like a little ferrari. this weird motor design cant sound cool.
IMO, there are a few motors that sound awesome, chevy 327, ford 302, the almighty hemi, SOHC4s, and the ford flat head 8.   every other car company needs to make their motors sound like them.
and that's all that matters in life- a cool sounding motor ;D
« Reply #11 on: December 30, 2009, 04:34:04 AM »
best saund in vorld,,after sohc,,is german IH 1455..six silinder turbo,abaut 7 liter..ccm.12 gear vith konverder slip.
its, the best tractor build in europa,,for 25 years ago..in neuss germany..
and not forget the king----cbx 1000----uhhhhhhh   must have one :-*
« Last Edit: December 30, 2009, 04:36:35 AM by strynboen »
  • Like a well oiled
    • Undead Asphalt
« Reply #12 on: December 30, 2009, 08:02:44 AM »
I love stringbean! his crazy accent comes thru the keyboard... its awesome!
« Reply #13 on: December 30, 2009, 08:16:39 AM »
ill never stopps,, ;) ;)svartsnegger speaks alså badd,,,"illl be back.".vas all he kut say,,,for many years,,and he almost be president ;D ;D ::) ::)
Offline CBJoe
« Reply #14 on: December 30, 2009, 08:33:39 AM »
Careful  ;)  Dont turn this into a political thread  ;D
'07 Bonneville Black
'65 CB77
'66 CM91 (C90'ish)
« Reply #15 on: December 30, 2009, 08:35:10 AM »
take it easy ;)i vont go for president... ;D
Offline HedNut
  • Underwater Basket Weaving
« Reply #16 on: December 30, 2009, 08:56:06 AM »
Wicked engine to bring back!  I often lay in bed at night and dream of ways to make a "totally NEW" fueled engine...I've done many sketches on the john...scribbles at my desk...beautiful blueprints in my head....only to find out it's already been done or tried to some extent.  SOMEDAY...I'd like to think I'll be the one to revolutionize fuel buring machines...ahahaha  One can have a dream!...and that same one can Strap that dream between it's legs and RIDE!!!
