SOHC/4 Owners Club Forums
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
SOHC/4 Shop
Home
Help
Login
Register
Donate
Tech Forums
SOHC/4 Bikes
Topic:
CB550 air box removal.Do i need to alter carb setup
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: CB550 air box removal.Do i need to alter carb setup (Read 1010 times)
CBFAN2
Guest
on:
January 01, 2010, 12:23:49 PM »
I'm planning on removing standard airbox,and fitting cone type filters.
Will i need to alter anything ,and if so what ?.
Logged
natewatkins
Full Member
Re: CB550 air box removal.Do i need to alter carb setup
Reply #1 on:
January 01, 2010, 12:37:31 PM »
You may want to check this out. Its a good starting point.
http://forums.sohc4.net/index.php?topic=5410.msg203462#msg203462
You may want to do a search on the forums for "pod filters" and you will find a wealth of information on what folks here have gone through to get them set up properly.
Logged
OldSchool_IsCool
Really feeling like an
Old Timer
WARNING: Objects in mirror appear to be LOSING!
Reply #2 on:
January 01, 2010, 12:39:13 PM »
What year is your bike? Is it an F or a K? What carbs are on it? What is your exhaust setup?
You will likely have to mess with rejetting your carbs to compensate for the difference in intake breathing. There are a number of threads here with more detail. and also threads that will tell you ur creating headaches for urself that you can avoid by keeping the stock airbox.
Logged
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
CBFAN2
Guest
Reply #3 on:
January 01, 2010, 12:47:03 PM »
Bike is a k3 model with a 4 into 1 exhaust.
Logged
TwoTired
Really Old Timer ...
Reply #4 on:
January 01, 2010, 04:56:03 PM »
Stock K3, PD carbs are tuned for stock exhaust and air filter restriction. They do not auto-adapt. You will have to readjust the pilot screw, slide needle height, and main jet to accommodate your engineering changes.
Logged
Print
Pages: [
1
Go Up
« previous
next »
Tech Forums
SOHC/4 Bikes
Topic:
