So, finally registered, inspected, and all that, I decided to take the bike for its first real spin down to fill the tank. No odd noises that I could find, but cruising around 50mph, I felt an slight surge. I'm not sure, but I think I read somewhere that this is referred to as "hunting"? Then, when I found a nice stretch of highway, she would cap out at full throttle around 60 to 65. Conferred with my HD driving father, and he feels it definitely should go faster. There's no airbox on the bike, so maybe that relates.
Replaced the seals on the carb drain plugs (one seal was missing entirely), and cleaned them. Two were pretty clean, and the center two were really clogged. Cleaned and replaced, then fired the bike up. The center exhaust pipe on the side of the horn felt cool. I thought maybe I hadn't waited long enough for the pipes to warm, but slightly burned myself touching another pipe, so I think a piston might not be firing.
A local buddy said it sounded like a bad carb, so I went and bought some chemtool and came home in the failing daylight to begin to remove the carbs. Got the carbs out, and removed the bowls on the center carbs, since they seemed their drain plugs seemed to be the dirtiest and might relate to the piston problem.
The bowls were extremely clean! Hardly any gunk. The rings look new.
While scratching my head at this (since I was certain they were going to be filthy), the o-ring on one of the bowls came off, and I found that it appeared to be held in place by a clear jelly material. When I tried to fit the ring back, it doesn't appear to fit to the groove. There's about a quarter inch too much ring!
Now I'm new to bikes, but I would think the rings should fit rather snug in the groove. Conferred with the father, and he agrees, but I thought I would come and give you good folks an update on my bike and listen to your thoughts.
Do o-rings run slightly large, and I need this clear gel to hold the thing in place? Should I buy a set of rebuild kits for the carbs and strip them down completely, despite the clean look of the bowls?
Oh, and Happy New YEar guys!
-D
