Author Topic: Are your motion pro cables a bad fit?  (Read 9669 times)
Offline Flying J
« on: January 05, 2010, 11:13:41 AM »
All the cables i have received recently for my Cb550s i have had to adjust all the way out because they are to long. Any body else having this problem?
Offline Sporkfly
  • The frosty rider
  • Mmm, Guinness
Re: Are your motion pro cables a bad fit?
« Reply #1 on: January 05, 2010, 11:24:36 AM »
I've had the same problem with my 550 and motion pro cables even though they are listed as stock length.
1977 CB550K
1979 CX500
1976 Suzuki GT500 Titan
Offline MickeyX
« Reply #2 on: January 05, 2010, 11:31:22 AM »
We had a problem with motion pro cables on our CB650. The length was wrong, they were missing a nut, total crap. We ended up throwing them out and getting Honda cables. I won't buy motion pro again.
« Reply #3 on: January 05, 2010, 11:33:56 AM »
....and getting Honda cables. I won't buy motion pro again.
+1.
Offline cb750fbomb
  • is by no means a
  • "No hope? See, that's what gives me guts!"
« Reply #4 on: January 05, 2010, 11:34:22 AM »
all the MP cables I've bought for my '77 750f, two throttle and a choke, have been great. To bad they can't keep it consistent.
'77 CB750F2
“The major difference between a thing that might go wrong and a thing that cannot possibly go wrong is that when a thing that cannot possibly go wrong goes wrong it usually turns out to be impossible to get at or repair.”
Offline Flying J
« Reply #5 on: January 05, 2010, 11:52:46 AM »
Ok i talked to motion pro. They are going to check their current cables against some OEM and see if they screwed up. Ill keep you posted when they call back.
Offline Really?
« Reply #6 on: January 05, 2010, 12:31:07 PM »
The -3 clutch and stock length throttle cables were perfect for the K5 that I got from MP.
The Wife's Bike - 750K5
The Kid's Bike - 750K3
Offline Toxic
« Reply #7 on: January 05, 2010, 12:44:19 PM »
Hey Tipper
Your -3" cables were they for drag bars, clubmans or clip-ons?
I was just about to inquire how much shorter I need for my drag bars.
do you by chance have a part number?
thanks
Offline Flying J
« Reply #8 on: January 05, 2010, 12:47:24 PM »
I have bought stuff for my 750F and all was fine but for some reason the 550 stuff just doesn't fit right. To much free play.
Offline Really?
« Reply #9 on: January 05, 2010, 12:47:32 PM »
Superbike bars.  On thier site, they only had stock and a -3 clutch cable listed for the K5.  I have no answer for the the bars you  mentioned but should be real close to that, as my guess.
Offline SHELLFISH
« Reply #10 on: January 05, 2010, 12:48:46 PM »
Very timely post. I'm just about ready to order some throttle cables!
By the way. What side of the frame do the accelerator cables run on a 550 K?
On my 1976 550F they run down the right side. I know these are correct
On my 1976 550K they run down the left side.
« Last Edit: January 05, 2010, 12:52:36 PM by SHELLFISH »
I want to die like my grandfather did...in his sleep and not screaming like the passengers in his car!
MötleyRöx
« Reply #11 on: January 05, 2010, 12:58:11 PM »
If it was just the clutch cable, it could be a fairly easy fix with a longer adjustment screw that goes into the lever, from a different bike.
Any way to do something similar with the other cables too?
Just a thought, if motion pro is unwilling in the end.
Offline shizzomynizzo
  • It's 5 o'clock somewhere
« Reply #12 on: January 05, 2010, 03:11:07 PM »
If you look on their site, they do not offer a stock length cable for the clutch. They only offer 1.5 inch longer or shorter.
Someone wanted the part number for clutch cable with drag bars??? 02-0124 for the 75 550.
1974 CB550
1985 XLX Last of the IH
2001 Street Glide
CB750Winger
« Reply #13 on: January 05, 2010, 06:07:14 PM »
  I got my 750K with Clubman bars and only the pull throttle cable. My back couldn't take the bars so I put a higher than stock bar on it and went to look for the push cable. The MP cable I got was totally wrong so went to my Honda dealer to do a special order for length. Looking around the showroom and doing some measuring, a new Honda Shadow cable was a perfect fit and $14. I also had to get a clutch cable made as well as the front brake line. They were not as cheap but Honda sent my cables out and had the new ones made to the correct length. it was worth it for me and doesn't kill my back.
Offline Zaipai
    • My Home page
« Reply #14 on: January 05, 2010, 06:19:27 PM »
I ordered  push cable and a pull cable and a clutch cable from Dennis Kirk and they are all too long. It said on the site they were the exact replacements for my 75 CB550F and they are not. In fact I have the adjustments out all the way and the gas cables work ok but the clutch is no where near where it should be.. I will be watching this thread for ideas....
Its my Avatar..
75 CB550F  |
« Reply #15 on: January 05, 2010, 06:24:32 PM »
Something to remember when ordering over seas is that these bikes had different handle bars for different markets so this could cause a problem with lengths.
Offline Zaipai
    • My Home page
« Reply #16 on: January 05, 2010, 06:27:22 PM »
Thanks Mick, I did not know that.. So I will have to pay more attention to it in the future.. I am waiting to buy new cables for a while so I will have plenty of time to look..
.: Scott :.
Its my Avatar..
75 CB550F  |
Offline Flying J
« Reply #17 on: January 06, 2010, 01:26:37 AM »
Its not the length of the cable that is causing the problem. I can use the same cables on clubmans that i use on stock bars. It just takes creative routing. The problem were having with the 550 cables is that the inside cable is to long and you can not take up enough slack with the adjusters. I have a 1/2 inch  of free play in my throttle and i have every thing adjusted all the way out. same with the clutch. They never called me back today but i will be calling them again tomorrow.
Offline fastbroshi
  • Puppet
« Reply #18 on: January 06, 2010, 06:49:05 AM »
  I'm pretty sure I ordered a custom one, though I have clubmans.  And you know what?  The clutch end bulb or cylinder part that attaches to the clutch's arm was too big.  Had to grind it down a bit to make it fit.
  And one more thing: for what they charge, they should be A+ perfect.
« Last Edit: January 06, 2010, 06:53:12 AM by fastbroshi »
Just call me Timmaaaaay!!!
Offline tlbranth
« Reply #19 on: January 06, 2010, 09:11:24 AM »
The MotionPro throttle cable for my K0 750 had a too long inner cable relative to the casing and I had to customize it to work. Don't remember what I did but remember wondering "how hard could it be to measure a stock cable and duplicate it?".
Don't own a Vanagon
Don't work at Boeing
Life is good
1970 CB750 K0
1975 GL1000
1999 GL1500
Terry
Offline Zaipai
    • My Home page
« Reply #20 on: January 06, 2010, 07:14:01 PM »
Yea that was kinda my thinking.
Its my Avatar..
75 CB550F  |
« Reply #21 on: January 06, 2010, 08:12:49 PM »
I called up and talked to them about this. The guy said something like... We make a certain number of cable models. we feel even if it's not the right size, but it will work for the application, we sell it for that application. If we didn't make them, where would you get them, custom cables cost 40 bucks a piece?...I said, well then why do you advertise them as "stock" replacement when they're 1 1/2 inches longer and the inside is too long for a particular application?
The guy got ticked off and said order from a dealer then if you don't like our products.
Funny thing is I did buy their cables from the local dealer.
What are the alternatives to Motion Pro? (as I am in need of a new clutch cable, less than a year old and under 1500 miles and it's already fraying at the lever)
1974 CB550
2001 Street Glide
Offline Zaipai
    • My Home page
« Reply #22 on: January 06, 2010, 08:17:41 PM »
I am with you. From what I can tell its probably best to order from the local Honda shop.. I hope some one comes up with a better place..
Its my Avatar..
75 CB550F  |
Offline tlbranth
« Reply #23 on: January 06, 2010, 08:35:33 PM »
Not a good way to attract customers. I remember AT & T having an attitude like that.
« Last Edit: January 06, 2010, 08:39:30 PM by tlbranth »
Don't own a Vanagon
Life is good
1970 CB750 K0
1975 GL1000
1999 GL1500
Terry
« Reply #24 on: January 06, 2010, 11:20:39 PM »
I would take them back to the dealer who sold them to you, if Motion pro get it from their distributors it may hit home a little better, also mention to the dealer what their response was as that ia a pretty poor way to deal with a customer and it WILL loose them business..
