Author Topic: Front brake pressure switch wires missing  (Read 936 times)
Offline YogiBear
« on: January 06, 2010, 01:41:20 AM »
On my 74 CB750, the wires that are supposed to be attached to the brake light switch at the triple tree are disconnected and no where in sight. Im not sure what the previous owner did, but could somebody please tell me what wires connect to the switch and where I can find them on the bike? My brake light works perfectly with a push of the rear drum brake pedal. Thanks.
1974 Honda CB750K4        1973 Honda CB500 Four
Re: Front brake pressure switch wires missing
« Reply #1 on: January 06, 2010, 01:50:02 AM »
if the loom looks more or less intact they may just be cut of flush with where they enter it,have a look and try and unpick the tape,near the front brake switch,you might just have to do a solder join to extend them again.,,or does the whole wiring look like it been tampered with?fingers crossed its easy.,i think your looking for a black and a green with a yellow stripe?
Offline YogiBear
« Reply #2 on: January 06, 2010, 02:29:47 AM »
well to be honest, it looks like the po just took the wires off. dont ask me why  ::). I guess I'll poke around and look for the black and green w/ yellow stripe wire.
Offline Toxic
« Reply #3 on: January 06, 2010, 05:37:16 AM »
I think this is probably the case.  That green/yellow traces all the way back to the rear brake switch. This then goes to the tail light.
Keep  looking for it. Its probably cut flush or buried in e-tape.
Worst case you should be able to tap into the green/yellow at the rear brake and run it foreword.
I can't see the PO undoing the whole loom just to remove all traces of it.
