Author Topic: CB750 Dual disc front end swap (with GSXR1000/600/750 parts)  (Read 142947 times)
Re: CB750 Dual disc front end swap (with GSXR1000/600/750 parts)
« Reply #200 on: March 29, 2010, 07:54:54 AM »
  I wonder what you'd use to break the bead on the side of the road?...
Well we have done it...but there were 3 other guys helping...I dont recall what we used to break the bead or to reseal it...all I know is we needed 4 guys all working on it....so it has be slightly worried about doing it solo on the side of the road.
Spot the bike with no rear wheel ;)...I-59 in MI
cheers
Andy
Offline wannabridin
  • Patience made me a
  • -Garrett
« Reply #201 on: March 29, 2010, 07:55:57 AM »
It's funny you say that, I was gonna do one but my camera needed to be charged.
I usually use 3 adjustable wrench handles a taco'd 21 inch rim, and my feet, knees, and hands.
well that's yer problem right there...
« Reply #202 on: March 29, 2010, 08:05:24 AM »
I get the bead broken with ... tire irons.... myself..
 I have probably fixed a lot more than a  dozen flats, on the roadside, I always pack a tire pump..
 Beads on 16in  can get tough, as are tires that have sat for many years..
Offline Zaipai
    • My Home page
« Reply #203 on: March 29, 2010, 01:07:32 PM »
I would like to see how that tire removal is done. Its been for ever since I had to do one and I am probably due...
.: Scott :.
Its my Avatar..
75 CB550F  |
Offline Industrial Cafe
  • Like a well oiled
    • Undead Asphalt
« Reply #204 on: March 29, 2010, 02:28:57 PM »
I could throw one together on an old tire.
  • Like a well oiled
    • Undead Asphalt
« Reply #205 on: March 30, 2010, 08:55:20 AM »
CHANGING THE BEARINGS IN THE HARLEY WHEEL
It was easier than I thought it would be.
    First I made a 1" taper out of a piece of 26mm steel round stock
Then I hammered it into the bearing so it was stuck real good.
after that, I used a 1 inch piece of round stock to knock the bearing out through the other side.
    *IMPORTANT*
you have to do this task with the wheel standing up, so the 1 inch rod won't just knock your taper back back out of the bearing.
 I think it's called percussion force.  ???
   The hammer hits the rod and the rod hits the taper at just the right time to knock the bearing out of the hub. A few good whacks and out she pops!
It's pretty neat.
Then you put the bearing on top of the vise and tap the taper out with a smaller punch
  I used a 36mm socket (used on most foreign cars for their CV joints) to tap the new bearings and dust seals in. (one at a time)
And you're done!
next thing is to figure out the length of the wheel spacer for the right side of the axle.
« Last Edit: March 30, 2010, 08:58:26 AM by Industrial Cafe »
« Reply #206 on: March 30, 2010, 09:13:43 AM »
Cant you just use a 3/4 inch bar cocked in the bore, and hit against the inner bearing race, then alternate side to side...?
  • Like a well oiled
    • Undead Asphalt
« Reply #207 on: March 30, 2010, 09:26:20 AM »
Not with the 1'' bearing, the O.D. of the "crush sleeve" is 1.25 inches and the inside of the hub is 1.30''
   So it only moves enough for you to do nothing in there.
« Last Edit: March 30, 2010, 09:45:23 AM by Industrial Cafe »
  • Like a well oiled
    • Undead Asphalt
« Reply #208 on: March 30, 2010, 07:17:11 PM »
MAKING THE 0.580 INCH WHEEL SPACER
   I had an axle for a 03-04 GSXR1000 layin' around, so I used the sleeve nut thing (on the left)
to make a spacer.
First thing to do was put a bolt in the rotors to hold them onto the hub and center the wheel up.
I used a 1/4 inch (6mm) allen wrench to make sure each rotor was lined up with the fender mounts.
the GSXR bearing assembly (installed in the harley wheel) is slightly narrower because the bearing seats are deeper.
that gave me a small gap on the other bolt side.
which I later made up for by drilling out a fat washer with a 15/16 drill bit and filing the edges smooth.
then I marked the axle by adding some paint to the edge of a business card and sticking it in there.
using the depth stick on a caliper I measured from the bearing face to the mark I made.
transferred this measurement (.580'') to the sleeve nut thingy and drew a circle around it with a pencil.
I like to cut it a bit longer than the pencil line so I can file it to size.
that way I can make sure it's .580'' all around.
finished product- filed to fit perfect in there (took an hour or so)
I filed it in the vise until it was flat then I laid the file on the table and pulled the spacer toward me until it was the right size. spinning it around and drawing on the edge with a marker to see what I was taking off.
 It fit in there perfectly and the discs didn't need any spacers in this case. but depending on the rim you use you might.
not bad, I didn't have too much 'scooting of the axle' to do.
« Last Edit: March 30, 2010, 07:19:24 PM by Industrial Cafe »
  • Like a well oiled
    • Undead Asphalt
« Reply #209 on: March 30, 2010, 07:24:19 PM »
Gratuitous mock up picture
I still need to drill the rotors with the Harley bolt pattern and get a master cylinder...
among other things.
also I noticed, there's a reasonable gap between the crossover line and the tire. that saves me a buck! ;D
Offline Zaipai
    • My Home page
« Reply #210 on: March 30, 2010, 07:28:22 PM »
Dude, that is looking fantastic!!! You are the Bob Villa of the SOHC4 World...
.: Scott :.
Its my Avatar..
75 CB550F  |
  • Like a well oiled
    • Undead Asphalt
« Reply #211 on: March 30, 2010, 07:37:41 PM »
I like Bob Vila, but I'll never live up to his legendary beard.  :D :D
Offline Staggerlee
« Reply #212 on: March 30, 2010, 07:38:24 PM »
Nice dude!
How wide are the rotors on center all mounted up?
  • Like a well oiled
    • Undead Asphalt
« Reply #213 on: March 30, 2010, 07:43:20 PM »
measuring from the inside faces of the rotors I got 4.980 inch
so basically 5 inches.
« Reply #214 on: March 30, 2010, 09:24:56 PM »
Looking good Brian.... ;)
Offline BlindJoe
« Reply #215 on: March 30, 2010, 10:40:47 PM »
awesome
« Reply #216 on: March 31, 2010, 03:31:37 PM »
i had a part-time job opening up a new Sears , and Bob Villa came there to demo some tools .... i got to meet him .....and............wait for it..   he was such a dick  :o :o
    "i said i wanted Evian not this Ice mountain crap ...    ok, well get it
      :o :o :o :o... i really expected him to be more grounded in the real world
     ......broke my heart
oh yeah , and the wheel looks badass too  ;D ;D
  • Like a well oiled
    • Undead Asphalt
« Reply #217 on: March 31, 2010, 04:55:37 PM »
no waaaay!? :D
I drilled the harley pattern on the gsxr rotors, I'll post a ''how I did'' it in a bit.
« Last Edit: March 31, 2010, 04:59:11 PM by Industrial Cafe »
Offline Zaipai
    • My Home page
« Reply #218 on: March 31, 2010, 05:04:18 PM »
Can't wait to see it Bob...
.: Scott :.
Its my Avatar..
75 CB550F  |
  • Like a well oiled
    • Undead Asphalt
« Reply #219 on: March 31, 2010, 05:44:22 PM »
DRILLING THE NEW ROTOR PATTERN
First thing was to trace the center hole and the bolt holes from the old Harley rotor with a pencil.
Then sit the GSXR/Hayabusa Rotor on the paper, center it up with the ID end of the caliper and draw another circle.
if you did it wrong it looks like this. ;D
I corrected and cut it using the bottom of a  spray paint can.
Luckily the center hole on the Busa rotor just fits over a spray paint cap.
      While you're there, find the centers of the bolt holes and center-punch them.
 To drill it without walking the bit, I use bits from 3/16 to a little bigger than 5/16.
      If you have a drill press handy this won't be as important,
tadaah!
I like to use a fine round file and a countersink bit. but a de-burring tool will work too.
I clean the holes with these gimmicks.
Do it twice and the rotors are done.
    Now to get some hardware for 'em.
They have about 1mm of hop but once it's bolted up, I think it'll be fine. the bolt holes are slightly bigger than the bolts.
I don't know what to do for a speedometer, there's no room for a manual drive...
« Last Edit: May 03, 2010, 05:43:06 PM by Industrial Cafe »
Offline JS550
  • the artist formerly known as
  • IAFF local 1307
« Reply #220 on: March 31, 2010, 05:55:04 PM »
Looks fuggin great! Cant wait for a ride report.
Jim
If you're worried about how many calories are in beer, is losing weight really your biggest problem?
  • Like a well oiled
    • Undead Asphalt
« Reply #221 on: March 31, 2010, 06:00:02 PM »
Oh neither can I! I'll do a ride-along video.
Offline JS550
  • IAFF local 1307
« Reply #222 on: March 31, 2010, 06:08:11 PM »
In FLIP FLOPS!
  • Like a well oiled
    • Undead Asphalt
« Reply #223 on: March 31, 2010, 06:12:00 PM »
AGAIN!
Offline MattFreeman
  • What Have I Done?
« Reply #224 on: March 31, 2010, 07:56:14 PM »
I remember being impressed with a members tach/speedo. If I'm correct he used a digital bicycle speedo and put the display inside the tach face. Maybe not what you wanna do given how sweet your gauge setup is, but I was struck by how clever it was.
I think others have used a bicycle computer as a speedo but I'm not really sure.
Great work BTW!!
