Author Topic: CB750 Dual disc front end swap (with GSXR1000/600/750 parts)  (Read 166045 times)
Offline Staggerlee
Re: CB750 Dual disc front end swap (with GSXR1000/600/750 parts)
« Reply #250 on: April 05, 2010, 05:19:13 PM »
Keee-rist those are expensive.
Offline Industrial Cafe
  • Like a well oiled
    • Undead Asphalt
« Reply #251 on: April 05, 2010, 05:21:31 PM »
yeah, but did you notice it was a 5 pack?  5.25 ea then
  • Like a well oiled
    • Undead Asphalt
« Reply #252 on: April 05, 2010, 05:59:14 PM »
I made some fender brackets today out of some scrap 20X5mm aluminum flat bar
I still need to get hardware and do the ole trim, tweak, 'n' shine
here's a pic-
I wanted to do the fender brackets with stainless wire, but I couldn't find any.
 so I used what I got.
and it keeps the cross over line from potentially contacting the tire
« Last Edit: April 05, 2010, 10:26:50 PM by Industrial Cafe »
  • Like a well oiled
    • Undead Asphalt
« Reply #253 on: April 05, 2010, 06:04:27 PM »
rode her out to the road to get a pic.
I wanted to see if my vision was coming together as I was hoping.
it is, but that tiny back wheel is killing me.
« Last Edit: April 05, 2010, 10:30:40 PM by Industrial Cafe »
  • Like a well oiled
    • Undead Asphalt
« Reply #254 on: April 08, 2010, 04:54:28 PM »
I got the master cylinder in the mail today, yay...
It needs a new bleeder for aesthetic reasons, and the cap had a mass produced screen print of a skull and cross bones on it. (now removed)
   I re-drilled the bleeder and filed it so it wouldn't look so rough for now, straightened the reservoir bracket, and tightened everything all up.
I need to make different spacers for the calipers, mine are too big.
 they need to be .180in (4.6mm) the 10mm spacers were too big and the pads were making contact with the edge of the rotor.
here it is-
It still needs a little more tweaking and tightening to be finished, but it's pretty much done.
    next thing to do is get an electric speedometer and swap guts into mine. but I'm not in a hurry for that. $$
oh, and grips.
Offline Zaipai
    • My Home page
« Reply #255 on: April 08, 2010, 06:28:46 PM »
Looking good.. You have to be happy with how its turning out!
.: Scott :.
Its my Avatar..
75 CB550F  |
  • Like a well oiled
    • Undead Asphalt
« Reply #256 on: April 08, 2010, 08:27:16 PM »
Yeah, it really came together how I imagined.
   There's still little details, and as soon as I get everything sorted out I'll do a ride-along video to report how it all feels.
« Reply #257 on: April 08, 2010, 08:35:06 PM »
if you do not drill lots of holes in your headlight brackets i will slap you so hard in the back of your head , you will spit out the leftovers of your previous boy toy encounter  .... that is all
  • Like a well oiled
    • Undead Asphalt
« Reply #258 on: April 08, 2010, 09:00:57 PM »
I do need to mod the headlight brackets. maybe tomorrow.
Offline Zaipai
    • My Home page
« Reply #259 on: April 08, 2010, 09:03:22 PM »
Hey Spikey, if he does not do it, we should take a road trip down there and you can pop a few holes in them with your pistols.. ;)
.: Scott :.
Its my Avatar..
75 CB550F  |
  • Like a well oiled
    • Undead Asphalt
« Reply #260 on: April 08, 2010, 09:07:31 PM »
dual wielding.
I'm thinking of trimming the bottom up a little and drilling it to match the drum cover.
« Reply #261 on: April 08, 2010, 09:45:15 PM »
guys ...seriously, get a pair of semi-autos...words cannot fully describe how cool dual wielding is in reality  ;D ;D
that video was my first try, i've gotten a lot mo betta
i was actually thinking of making some parts with real bullet holes in um , not sure what tho
you could put some shotty holes in those brackets ;)
  • Like a well oiled
    • Undead Asphalt
« Reply #262 on: April 09, 2010, 11:59:17 AM »
yay, my rotors are warped.
Offline Zaipai
    • My Home page
« Reply #263 on: April 09, 2010, 12:00:09 PM »
Can you get them fixed easy? Maybe the local bike shop?
.: Scott :.
Its my Avatar..
75 CB550F  |
Offline J.Webster Designs
  • www.JWebsterDesigns.com
« Reply #264 on: April 09, 2010, 12:24:17 PM »
for some reason.... im thinking that alot of the used rotors on ebay are probably going to be warped.
VISIT OUR WEBSITE!
FOLLOW US ON SOCIAL MEDIA!
Facebook:
www.facebook.com/JWebsterDesigns
Instagram:
www.instagram.com/j.websterdesigns
« Reply #265 on: April 09, 2010, 04:25:19 PM »
are you talking about the rotor hub was bent? or the actual rotor?
VISIT OUR WEBSITE!
Facebook:
Instagram:
  • Like a well oiled
    • Undead Asphalt
« Reply #266 on: April 09, 2010, 04:26:34 PM »
yeah, I'm inclined to agree with you.
 I straightened them, but there's a spot in the rotor where you can tell the rotor was heated up real hot and stopped.
   on both rotors, there's a 4-5 inch area where the surface is 10 thousandths thinner than the rest of the rotor.
                                            I'm tired of fiddling with them.
they're so easy to bend, just the lightest tap with a rubber mallet and they move.
  • Like a well oiled
    • Undead Asphalt
« Reply #267 on: April 10, 2010, 03:37:08 PM »
OK, here's what you do when you don't have a dime to spare.
First I measured the thickness of the rotors at 1 inch increments.
      I started to grind them down with a die grinder and a 36grit roloc disc
Then my bit broke. I rode it around and after I broke my bit and it's better, but not fixed.
here's what's on the bench-
  Just so you know, the rotors are different.  One is thinner with 10 bars.
                                                            The other is thicker with 8 bars.
 probably one hayabusa and one gsxr600. (who cares they're the same size)
I'll end up getting replacements some day, but I want to try this experiment.
                the rotors have been re-measured and marked
rotor A- (0.160) has a very thin spot, at least .010'' thinner than the rest of the rotor. ???
rotor B- (.179) has 2 minor thick spots that I still need to work out.
so that's what I did today.
     if you feel compelled to tell me "brakes and safety bla blee, replace bla bloo" read this first.
Quote from: automated reply
Oh, really? Did the guy at the dealer$$hip tell you that? ::) ;) ;D
« Last Edit: April 10, 2010, 06:43:45 PM by Industrial Cafe »
Offline JS550
  • the artist formerly known as
  • IAFF local 1307
« Reply #268 on: April 11, 2010, 10:44:39 AM »
Fuggin cool. I would think just one of those rotors would be enough to stop it anyway. I wouldnt worry too much about safety. Great work.
Jim
If you're worried about how many calories are in beer, is losing weight really your biggest problem?
Offline Zaipai
    • My Home page
« Reply #269 on: April 11, 2010, 11:00:17 AM »
Yea, you can always get new rotors later anyway. I say get it close and enjoy..
.: Scott :.
Its my Avatar..
75 CB550F  |
Offline JS550
  • IAFF local 1307
« Reply #270 on: April 11, 2010, 11:03:01 AM »
Go Akimbo! Nice perk.
  • Like a well oiled
    • Undead Asphalt
« Reply #271 on: April 11, 2010, 11:40:40 AM »
Jim
I hear ya man,  Damn the Torpedoes, Full Speed Ahead!! If I'm gonna go down, I'm goin' down in a fiery chipped beef sandwich face-plant!   WOOO!
I can't tell if you're being sarcastic in agreement or making fun of me...  :D 8)
but seriously, I have full confidence in my skills and abilities with what I have on hand.
   If the rotor doesn't measure out within +/- .002'' I won't be using it.
I'm sure you know by now (after reading this thread) I'm pretty good at MacGyvering stuff.
« Reply #272 on: April 11, 2010, 12:43:43 PM »
 I think your front fender braces will give trouble down the road, they are tricky to make. Lucky your fender is cutdown and fairly light..
Offline JS550
  • IAFF local 1307
« Reply #273 on: April 11, 2010, 01:02:15 PM »
I would never make fun of a swap like that! Seriously, no doubt one of those rotors & calipers would stop a 750!
  • Like a well oiled
    • Undead Asphalt
« Reply #274 on: April 11, 2010, 03:29:06 PM »
heh, I thought you were maybe giving me a ribbing :D
      now that you mention the "one would be enough" I was thinking of only running one... but it looked strange.
I forgot to post finished pics, it's pretty stable.
     - but like you said, my fender is pretty light... so, we'll see.
I used stainless bolts, countersunk screws, and lock nuts.
