Author Topic: 77 CB550 Oil Pump Leak????  (Read 8802 times)
Offline sniper1
  • SNIPER1
« on: January 09, 2010, 11:33:03 AM »
I pulled the cover and noticed I have an oil leak that appears to be coming from the oil pump. Looks like quite a bit although only a few drops per week. there was a good amount of oil in the recess on the cover. SHould there be an oil in this area? I wouldn't think so...
I called bike bandit and Z1 and both are out and the oil pump is a discontinued item and no aftermarkets.
Question is, would replacing the "O" rings solve the leak???
How much of a pain int the A$$ is it to fix??
Should I be looking for one from a salvage yard??
Any help is greatly appreciated!
Offline René 衛星の
    • My shop!
Re: 77 CB550 Oil Pump Leak????
« Reply #1 on: January 09, 2010, 11:40:29 AM »
Sniper,
Replacing the rings should do the job.
Replacing the oilpump may get you into a better (temporarily), but might also get you into a worse position.
Cheers, Rene
« Last Edit: January 09, 2010, 11:42:51 AM by René van Maanen »
Dorje.com #252
Offline Fritz
« Reply #2 on: January 09, 2010, 11:42:58 AM »
Having the same problem, I was told that leaking oil pump seals are quite common. Replacing the "o" rings should cure it.
1976 CB550F
Offline sniper1
  • SNIPER1
« Reply #3 on: January 09, 2010, 11:47:13 AM »
Thanks for the help. Bike bandit had the O rings so I ordered them. Hopefully that does the trick.
« Reply #4 on: January 09, 2010, 11:53:58 AM »
youll need an impact driver to loosen the screws, if it still "phillips"replace them with allen type heads,loosen the counter sunk cover ones whilst the pump is still on the bike.
Offline Yoshi823
  • Biker to the bone.
  • Never too old to be a biker
« Reply #5 on: January 09, 2010, 12:04:23 PM »
Are you sure that it isn't oil thrown off the chain?
I'd thoroughly clean the general area, then use talcum powder liberally where you think the leak is coming from. Then run the engine & see what comes out.
Bikes...they're in the blood.
Yamaha 2001 R1
Yamaha 1990 FZR1000R EXUP
KTM 2004 450 EXC RFS
Honda 1997 XR400R
Honda 1988 CB125T2
http://www.cb750cafe.com/bikes.php?cat=3&id=67
« Reply #6 on: January 11, 2010, 10:31:43 PM »
The two "normal" leaks are the oil pressure switch and the oil pump cover that Honda dont sell the "O" ring for, you can only get the 3 between pump and crankcase which rarely leak.
Some time ago i put a lot of time and effort into sourcing a replacement for the cover which i sell as part of a set of 4 (3 x pump to crankcase + 1 x pump cover)
Majour part of cost is postage, if you want a set PM your address and I will tell you how much---Dont forget I am in the UK!!
« Reply #7 on: January 12, 2010, 12:12:09 PM »
i went to the local bearing service and got o rings from them that fit perfect.
Offline needswork
« Reply #8 on: January 12, 2010, 01:21:49 PM »
I had the same issue a couple of years ago. I replaced 2 (or was it 3?) o rings with o rings I bought at Canadian Tire. I also replaced the orignal bolts with hex head bolts. It hasn't leaked a drop since (not there anyway!). Total cost of repair was something like $4.
Paul
'78 CB 550K fixer-upper. The bike needs work, I sure don't!
Offline Way Way norcal
« Reply #9 on: December 19, 2015, 09:52:32 AM »
do you have to drain the oil before removing that oil pump cover??
« Reply #10 on: December 22, 2015, 11:46:11 PM »
No you don't
Offline mikecb550
« Reply #11 on: February 04, 2017, 11:56:15 PM »
Hello. I wish to ask a question regarding a subject covered in this  post.
Are there 4 or 5 o rings needed for the cb550 oil pump? I have a diagram attached it shows only 4. The photo earlier in this thread shows 5. can anyone confirm please.Thanks.
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
« Reply #12 on: February 05, 2017, 02:22:01 AM »
Iirc there are four to be worried about.
Offline jonda500
« Reply #13 on: February 05, 2017, 04:48:55 PM »
The fifth that is not available separately from the oil pump is the same as the two used in early 70's goldwing oil pumps - which are available from honda. The part number is 91305-426-003.
I tried several different 45mm o rings under the oil pump cap, but the leak persisted until I ordered the correctly sized 47 x 1.2mm honda goldwing o ring.
John
A starter clutch thread:
Offline mikecb550
« Reply #14 on: February 05, 2017, 09:34:34 PM »
Excellent .I have them ordered. If I don't use that fifth o'ring I can save it for the gold wing I'd like to own one day.cheers.Mike.
Offline mikecb550
« Reply #15 on: March 04, 2017, 04:45:35 PM »
Hi. Do you just use engine oil to lube the new o rings? thanks.
Offline mikecb550
« Reply #16 on: May 24, 2017, 02:35:41 PM »
Hi. just following up.i had to drill off the cover plate as the heads stripped out before they would budge. I replaced with allen head bolts. but when i tightened down the left side engine cover, the bottom oil pump cover allen bolt cracked the engine cover. as the bolt head was too proud. I guess that is why they originally used countersunk bolt heads. Job done now and oil tight. Thanks.Mike
« Last Edit: May 25, 2017, 03:31:19 AM by mikecb550 »
Offline GardenGnome
  • 1977 CB550F
« Reply #17 on: May 24, 2017, 08:56:26 PM »
I also appear to have run into the same problem with an oil pump issue as you. Took off my cover and just heaps of oil in the recess of the cover. I posted about it recently and was informed of a member here, name is Elan. He sells oil pump rebuild kits on eBay for $42.00. Just thought I'd give my two cents on the matter. Good luck. I'll make a post about the process and how it goes, but from what I hear the screws are a pain to remove without stripping. Has anyone had any luck hitting the screws with PB blaster or some other kind of lubricant in an attempt to make the removal of the screws easier?
If I've learned anything about building a motorcycle, it's check and re-check your work before you put it all back together. Although you do gain more experience by doing it twice.
Offline AlabamaCB750
  • Competent CB750K2 Owner
« Reply #18 on: May 24, 2017, 09:09:25 PM »
My 72' came with the same problem when I bought it. I had our parts guy order all 5 o rings and after one of our mechanics installed them, problem fixed. But, like jonda500, they had to order the 5th ring from a 73' goldwing. Your parts guy is going to look at you funny when you tell him what you need...lol!
« Last Edit: May 24, 2017, 09:11:00 PM by AlabamaCB750 »
Offline CycleRanger
  • No comment about being an
« Reply #19 on: July 25, 2017, 10:28:59 AM »
John
Thanks for that info!
Offline dspardoe@me.com
« Reply #20 on: June 25, 2019, 08:05:54 AM »
I have a leaky oil pump on my 75 CB550f and just order from Vital Motor Parts an oil pump rebuild kit for $43.00 off of eBay. Just thought I'd share that you can still buy the kit.
Dave
1975 CB550F Super Sport
1982 Suzuki
1968 Triumph Bonneville
1972 Yamaha 60 dirt bike
Offline uksparky
  • Track days
« Reply #21 on: June 25, 2019, 04:41:20 PM »
I also have very small leak from pump only a drop or two, got the O rings from Honda, impact from HFT... beat on the three screws they would not budge, stopped as i thought the case would crack lol
I left it at that, next thing is drilling the heads off  :o  think i will leave it for now
Present bike 1982 900C Custom
