Author Topic: new donor bike inquiry  (Read 1262 times)
Offline pinnacle
« on: January 09, 2010, 12:36:25 PM »
ok i just picked up another donor bike to fix up my 78 cb550k  that i blew the head on but this one is a 74 cb550.are there any differences that will keep the motors from being a direct bolt on?i noticed the carbs are different and some electrics.how can you tell if it is a f model and what diff will that make on the motor?
1974 cb550, 1978 cb550, 1984 honda shadow vt750
Offline pinnacle
Re: new donor bike inquiry
« Reply #1 on: January 09, 2010, 07:01:34 PM »
ok so here are some pixcs of it anybody want to chime in?
Offline fmctm1sw
« Reply #2 on: January 09, 2010, 08:26:39 PM »
Not sure but is there some kind of high handlebar fetish up there in Canada?
Quote from: 754
Quote from: inkscars
This is not a pod thread
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline Tnutz
« Reply #3 on: January 09, 2010, 09:32:46 PM »
make sure you use the rocker box from your 78.
2004 Ducati 999 mono posto.
-Full Termignoni exhaust
-Lots 'o' carbon fibre
1973 Honda cb500/4
-Motor Rebuild
-Has clubmans
-Paint is sub par
Offline pinnacle
« Reply #4 on: January 09, 2010, 11:37:10 PM »
what is the rocker box do you mean the valve cover assembly and why? just curious will my carbs and intakes from my 78 fit the 74 motor until i am able to fully clean the other carbs? and are there in other parts from 78 that i should transfer over that would make it better such as stator,the mac 4 into 1 or the 4 into 2  that this one has.here is a pic of what it is going into.
« Reply #5 on: January 09, 2010, 11:54:21 PM »
the carbs will be ok,the donor has the series 1 carbs,your PD ones will be ok although youll have to use the intake runners aswell,whats blew the head?damaged valves ?
Offline pinnacle
« Reply #6 on: January 10, 2010, 12:05:12 AM »
yep i replaced a bent intake valve on #3 piston put everything back together as the manual instructed had it running for about 45 min and then heart break exhaust valve on a #1 piston made contact with piston and put a hole right through it.thats how she goes .anyways two tired advised grabbing a new 550 motor as i could not be sure how much damage was done with impact and how much debris was floating around the motor.
« Reply #7 on: January 10, 2010, 12:12:51 AM »
sounds odd,has it high compression pistons or a high lift cam or something?,cam timed correctly?
Offline pinnacle
« Reply #8 on: January 10, 2010, 11:39:35 AM »
i don't think so ultimately i think i screwed up somewhere along the way or like tt said possible that there was another bent valve that went unnoticed and broke off at the stem after it started to run.but here i am with a new  motor ready to go  and we will see if i learned my lesson.
Offline OldSchool_IsCool
  • Really feeling like an
« Reply #9 on: January 10, 2010, 05:13:55 PM »
As for why, the early 550 rocker covers did not bolt down the rocker pivot shafts.  As they turned and shook, they wore unevenly in their bearings.
http://forums.sohc4.net/index.php?topic=20408.msg212239#msg212239
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
