Author Topic: donor engine  (Read 854 times)
Offline pinnacle
donor engine
« on: January 13, 2010, 06:46:51 PM »
i started to strip down the 74 cb550 to swap over to my 78 frame and looked inside the intake and exhaust and definately need to clean the head up lots of carbon in the intake and exhaust ports what can i spray in there to soak and clean those ports  up without taking the head off yet to clean them up. i ran dry compression test and got 100-120 psi  by kicking it over is this descent for now until i fire it up  as i don't know  how long  it sat at the salvage yard i don't want to tear into the top end until i have a chance to run it and assess the problems or leaks that may exist.i suspect that the numbers may be off as i have not set valves or done any of the regular maint that should be done to ensure accurate readings
1974 cb550, 1978 cb550, 1984 honda shadow vt750
Offline OldSchool_IsCool
  • Really feeling like an
Re: donor engine
« Reply #1 on: January 13, 2010, 06:54:45 PM »
Well, you don't want to destroy the O-rings and rubber seals inside there, so brake cleaner is out.  You could try SeaFoam, ATF or similar.
Or you could wait until you have it running an spray a wee bit of water into the intakes to steam clean the innards.
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
Offline pinnacle
Re: donor engine
« Reply #2 on: January 13, 2010, 08:58:17 PM »
when you say atf do you mean atf transmission fluid and is it safe to use.would combustion chamber conditioner and cleaner be any good or harm any seals?
Online Don R
Re: donor engine
« Reply #3 on: January 13, 2010, 10:51:51 PM »
Throw some sea foam in it when it's runing, it will smell like it's burning coal.
