Author Topic: Turn signal lights mounting options for these headlight mounts???  (Read 1473 times)
Offline jasonseasen
Hi,
I recently got this set of headlight mounts and wondering about options for mounting turn signal lights, seeing as these do not have holes to allow connecting. Anyone have any pics of set-ups or braces they used?
Thanks,
Jason
lendog
Re: Turn signal lights mounting options for these headlight mounts???
« Reply #1 on: January 14, 2010, 07:26:15 PM »
I was thinking about getting the same set...where did you get those from?....how much?
lendog
« Reply #2 on: January 14, 2010, 07:33:19 PM »
I would just drill a hole on the side and mount them.
« Reply #3 on: January 14, 2010, 07:47:52 PM »
I have those for my project too. THey along with most, will allow for you to stick the signal stem thru the headlight mount hole, thread it into the nut that holds the headlight on, has the ground wire on it. YOu'll have to tighten the stem first with the lamp loose on the stem. THe chance of the lamp being in the position you want when the stem is tight is remote. Stock lamps or any with a 10mm stem.
I consiodered drilling a hole  but those ears are really nice and I didn't want to mess them up. I had mine chromed, even though they came with a high polish on them, they were duller than my chrome headlight shell.
Offline jasonseasen
« Reply #4 on: January 14, 2010, 07:59:22 PM »
Thanks MCrider, do you have pics of the lights installed onto the headlight mount?
« Reply #5 on: January 14, 2010, 08:02:22 PM »
Nope, if plans work out I'll be mocking up that part this weekend. I post pics to my build thread which is in my signature. If this thread is still around I'll post here too.
Offline jasonseasen
« Reply #6 on: January 14, 2010, 08:07:57 PM »
Nice, thanks MCRider. I am a bit far from adding it, just currently planning parts. I will keep watching your build thread.
« Reply #7 on: January 17, 2010, 11:57:36 AM »
I've got them posted to my build thread, but here's a few.
Here's the concept
And here's the mock up with the headlight.
Offline nokrome
« Reply #8 on: January 17, 2010, 01:02:10 PM »
i am running those same mounts on my project, i also had the idea to drill a hole through them to mount the the turn signals since the head light mounting holes were a lot bigger diameter then my turn signal stems,
   in the end i decided that im just not going to mount signals on the front for now, im still looking for some that i really like (i really like the clean lines of not having anything up there.
  btw, i got mine from Mikes XS
Funny thing about regret is...... its better to regret something you have done than to regret something you haven't done.
Offline nokrome
« Reply #9 on: January 17, 2010, 01:26:11 PM »
here is a pic:
« Reply #10 on: January 18, 2010, 01:08:02 PM »
Nice looking so far Nokrome, like the frame color.
I also would like to go sans signals, but mine is for street use, and I need them at night to be legal.  I've bot these minibullets which really hug up close.
Back to the OP, if you scroll way down you'll see what's called "P" clamps. These could be used to mount signals lower on the fork tube, as low as the lower tree, or even below the lower tree, so they wouldn't detract from the headlight area so much.
http://www.customdynamics.com/led_mini_bullets.htm
