Author Topic: identification of parts  (Read 1660 times)
Offline supersports400
« on: January 24, 2010, 04:12:17 AM »
Hi,
Since I'm relative new to this forum, I have a question.
A few years ago I bought a CB400f, and I got a crate of NOS sohc4 stuff with it.
Some parts have the codes on it, 300, 333, 377 etc., but some are not coded anymore.
Most parts are engine parts like valves, guides, cam's, rockers, gears and shafts.
I did however identify a lot of these parts via pictures on ebay, but not all of them.
At the honda305 forum we do have a parts identify thread, but I was unable to find it here.
Can I make pictures of these parts so someone can identify these parts ?, and if yes, in what thread do I have to do that ?
If the parts are identified and it's not for a CB400f or CB350f I will part from it, here or on ebay.
Jensen
« Last Edit: January 24, 2010, 07:54:33 AM by jensen »
Offline Deltarider
Re: identification of parts
« Reply #1 on: January 24, 2010, 06:07:48 AM »
I wouldn't mind if you post them here.
CB500K2-ED Excel black
Offline Johnie
« Reply #2 on: January 24, 2010, 06:22:32 AM »
Check out this site. http://www.groupwracing.com/hondapartnumbers.html
It will list which bike goes with each code. The site gives a short tutorial then click on the colored area at the bottom which will take you to the actual codes and bike listings.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
« Reply #3 on: January 24, 2010, 09:10:17 AM »
Post the mystery parts on here, if not sure they are from  4's or could be.
 We like playing ID the part..of course if its all twin stuff, it might have to go into other..
Online Alan F.
« Reply #4 on: January 24, 2010, 09:13:13 AM »
+1
Offline Ross Davis
    • Retro Ride Info
« Reply #5 on: January 24, 2010, 10:14:08 AM »
The middle three numbers of the part number identify what model they started out with.  It is known as the product code.  These are the codes you have listed.  the first 5 number are the function or component number.  Example an inlet valve 14711 and exhaust 14721.  Last three are modification numbers usually starting as 000 then changing from there as a part is improve upon.  There are more sub IDs in the numbers but these are the basic.  The product code for a CB400F is 377.  00 is for the CB750K0 and K1.  333 is for the CB350F.
« Reply #6 on: January 24, 2010, 10:18:44 AM »
Also keep in mind while the 750 uses 300 as it's primary code there are many other codes from other models which it uses.
Offline Deltarider
« Reply #7 on: January 24, 2010, 10:23:40 AM »
And then... there's the Enigma code.  ;D ;D ;D
« Reply #8 on: January 24, 2010, 10:24:29 AM »
Hi,
Thanks for all the info, and I am talking about the parts without ID, who can one identify only visual.
I''ll make picture and post them here in this thread. Maybe some parts are indeed twin parts, but most of all is sohc4.
Jensen
« Reply #9 on: January 24, 2010, 10:43:47 AM »
We are Ready, start the Game...   ;D   ;D
Offline Deltarider
« Reply #10 on: January 24, 2010, 10:50:48 AM »
Can't wait..
« Reply #11 on: January 24, 2010, 12:39:26 PM »
Hi,
First three pictures are from a cam, different views, it was wrapped in Honda paper, so I assume it's Honda (all parts).
it's not for a twin, that's for sure, it wont fit in my CB72 head either.
Two types of rockers, 48 from the first one, 62 from the second one.
both guides are different, as you can see, where packed in bags of ten each (Honda bags).
I hope you guys know what it is,
Jensen
« Reply #12 on: January 24, 2010, 12:40:27 PM »
and the guides
« Reply #13 on: January 24, 2010, 12:50:21 PM »
We need more on the cam, number of lobes, length.
 If the rockers have no threaded hole for adjusters, they could be 250/350 twin or 450 twin.
« Reply #14 on: January 24, 2010, 12:58:08 PM »
Hi,
Rocker 2 has no adjusting screw thread, so that will be the twin.
Jensen
« Reply #15 on: January 24, 2010, 02:01:11 PM »
Hi,
picture added, cam has 8 lobes, lob heights are 35 mm, total length of the cam is 332 mm.
« Reply #16 on: January 25, 2010, 02:22:03 AM »
anyone ?
Offline ttr400
    • ttr400 Projects and Billet parts.
« Reply #17 on: January 25, 2010, 06:54:43 AM »
The CB400F cam is around 305mm long. the CB750 Cam is around 373mm long. so it's not any of those. Don't know on the rockers. Any sizes for the Guides?
Kevin
CB400F- 492 Yoshi Racer.
Cb400F- 466 Yoshi Cafe.
CR750 D Mann Replica.
VFR750R- RC30 - 1988.
www.ttr400.com
Offline Deltarider
« Reply #18 on: January 25, 2010, 01:59:34 PM »
Cam is 500/550.
« Reply #19 on: January 25, 2010, 02:07:44 PM »
Hi Deltarider,
Thanks for the ID on the cam,
Jensen
« Reply #20 on: January 26, 2010, 12:51:43 AM »
Hi,
Does that implicate that the CB500 and the CB550 use the same cam and that the cam will fit all years ?
Jensen
« Reply #21 on: January 26, 2010, 12:58:06 AM »
Hi,
Found the answer myself at CMS, all cams of the 500 / 550 K0 to K3 are sharing the same cam p/nb  14101 323 000,
Thanks again for identification,
Jensen
Offline Deltarider
« Reply #22 on: January 26, 2010, 01:46:50 AM »
Reassuring isn't it? I mean, for 500/550 owners there are still so many parts around.
BTW, another good site to identify parts and interchangebility is: http://www.motogrid.com/pages/parts/viewbybrand/7/default.aspx. Go to the right side where it says Quick Part Look Up.
http://www.davidsilverspares.co.uk/parts/ can be useful too.
Sometimes it's very hard to track down the specifics of a part. Right now I'm trying to find out what part (how many mm's) of the bolt that fixes the kickstarter assembly on the splined axe has a thread. The partnumber itself is 93200-08032-OA. It's a 8mm bolt, 32 mm long, but not specified is the mm's of the bolt that has a thread and I suspect this is important. Threaded bolts I got from the hardware store fail to fix the kickstarter arm firmly.
« Last Edit: January 26, 2010, 01:59:05 AM by Deltarider »
