Author Topic: up to 6 quarts of oil on 71 cb750  (Read 2772 times)
631girl
« on: January 17, 2010, 10:01:48 PM »
the motor was completly empty.. I'm up to 6 quarts.. Does it take this much oil. And still want more oil.bike is not smokin oil pressure is normal...and bike run great.. I have 3 other cb750s.. Any suggestions.thanks for ur help..
Re: up to 6 quarts of oil on 71 cb750
« Reply #1 on: January 17, 2010, 10:19:26 PM »
No it shouldnt, it probably leaking past the pump.
When you start it, about 2 qts will probably be puking out of every orofice...
Offline Frankenkit
  • Industrial Strength
« Reply #2 on: January 17, 2010, 10:21:32 PM »
The service manual and owner's manual differ on this.
The service manual says that after an oil change/drain/etc, you should put in 3.1 quarts, the owner's manual says 3.0 quarts.
Both agree that after this, you should stand the bike upright on level ground (or the center stand?) and check to make sure that it's at the upper mark on the dipstick.  If it's not on the upper mark on the dipstick, you add up to half a quart more.
6 quarts is roughly twice what you should be running.
I've somewhat overfilled my 650 before, but all that really happened was that the additional oil pressure 'helped' push my shifter seal out.  :P $5, an oil filter and change, and a week's worth of lost riding later everything was ok. BUT that was probably only half a quart over what my bike wanted/needed added because of side stand lean.
« Last Edit: January 17, 2010, 10:24:45 PM by Kit »
2012 CBR250R "Black Betty"
1980 CB650c- (sold) Delilah
1973 CL350- Lola?
Stuff for sale
Offline cb350twin
    • http://mail.google.com/a/sohc4.net/
« Reply #3 on: January 18, 2010, 02:14:56 AM »
Most cars don't even take 6 quarts...
1975 CB 750 K5
1972 CB 350 Twin K4
1972 CB 500 Four K1
Offline Queeg
  • insane fuel junkie
  • OY! with the poodles allready!
    • Queegs Problems
« Reply #4 on: January 18, 2010, 03:08:04 AM »
yeah but mine takes 11.5! makes for a nice $50 oil change every time. wanna trade?
guess who?
Offline mystic_1
  • 1970 CB750K
« Reply #5 on: January 18, 2010, 07:33:28 AM »
I've never known a 750 to take more than 4 quarts of oil even after a complete rebuild where the motor was bone dry (well, aside from assembly lube).
So where did the extra two quarts go?
Also, what are you using for an oil tank?  Most of the oil resides in the tank in normal circumstances.
mystic_1
- John Augustus Shedd
Offline campbmic
  • Sea-Foam and Flaming 151 is a dam good
« Reply #6 on: January 18, 2010, 07:37:28 AM »
Are you checking the oil with the bike on the kick stand? That will definitely do it
Its hard to be wrong when you know nothing!
Offline Gordon
  • 750K1, 550K2
« Reply #7 on: January 18, 2010, 08:25:26 AM »
It doesn't matter.  I can't speak for all models, but at least on the early 750 there is no noticeable difference in the oil level reading between the side stand or center stand.
It may vary slightly on other models, but it's not going to vary by anywhere near two quarts.
« Reply #8 on: January 18, 2010, 08:55:59 AM »
I think there is  a bigger issue here, trying to flog a bike together quickly, without a good plan. let see a pic of the oil bucket.
 For someone with 3 750 sohc's, they sure seem to have minimal knowledge about the most basic of thing to do on them.. take the time & do it right..
