Author Topic: clean tank- "The Works" works  (Read 8511 times)
Offline Bob Wessner
  • "Carbs Suck!"
Re: clean tank- "The Works" works
« Reply #25 on: January 09, 2006, 05:17:09 AM »
Sorry to report this one also has a small dent below the right side badge, so you wouldn't escape bondo. Besides, shipping would be more than the damn thing is worth.  >:(
Offline cbjunkie
  • ...know what i'm sayin'?
« Reply #26 on: January 09, 2006, 07:04:55 AM »
terry - give me the info, mate - are you really using bondoed tanks? the same thing that happened to bob happened to me and everyone's been telling me i'm crazy to bondo, then seal the tank... :(
what gives?
cheers...
1971 750K1
1972 CB350 (deceased)
sometimes naked, sometimes mad -
now the poet, now the fool -
thus they appear on earth,
the free men.
Offline Jonesy
  • Shop Rat
« Reply #27 on: January 09, 2006, 07:06:07 AM »
Not to Hi-jack the thread, but how the heck do you guys see down in the tank?
On my 75' 550 K1, I really am hving a hard time seeing in there even with a good flashlight.
Do I need to stick a mirror down in there?
Regards,
DiscoEd
I have a mechanic's "Bendy-Light" that I can drop into the tank and peek around.
At work we have a fiber-optic scope I can put in there (after hours, with no one around, of course!). I know these are available, but damned expensive (over a grand)!
« Reply #28 on: January 09, 2006, 12:40:39 PM »
what gives?
cheers...
G'Day CBJ, no, I wouldn't use Bondo to repair a hole in a tank, (if that's what you meant?) I've just got a couple of tanks that after paint and bondo removal (I use a 3M nylon "strip disc" mounted to my sander/polisher on the top and sides, and chemical stripper underneath) are pretty badly dented, and I'm not that keen on cutting the bottoms out to bash the dings out from the inside.
I've got a mega-dollar "stud welder" that I can use to pull the dings from the outside, but I can never get them perfect without being able to "hammer and dolly" them from both sides. A little Bondo is fine for small surface dings, but in my opinion, that's about all it should be used for.
My (now rotten) F2 tank came from New York, and apart from non-OEM paint, looked great, but somewhere between New York and Melbourne, an errant Postal worker put his boot through the box and put a ding the size of your fist in the tank, so instead of my initial plan of just rubbing it smooth with some 400 and priming/painting it, I had to strip it bare, and lucky I did, there were two holes in the tank where a PO had used self tapping screws to pull a dent, then just filled the holes with bondo! Ok on a car panel perhaps, but disasterous on a gas tank!
Bottom line I guess, is that if the holes are too big to be repaired with leak sealer like POR15 or Kreem, then you may as well junk it. Remember that gas tanks rot from the inside out, so pin holes on the outside don't equate to the damage you'd find on the insides if you could get in there and see. Cheers, Terry. ;D
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #29 on: January 09, 2006, 12:52:18 PM »
Couldn't agree more. Even if you were to try and pick around on the outside looking for weak spots, unless you are lucky enough to hit the paper thin rust, you won't find them. All future used tanks will get a phosphoric acid test and let it do the testing for me.
Offline cbjunkie
« Reply #30 on: January 09, 2006, 02:05:04 PM »
Hear Hear!  :P
1971 750K1
the free men.
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #31 on: January 11, 2006, 07:06:27 PM »
cbjunkie,
Thanks for the reference to The Must for Rust. A year and a half ago did my orig. tank with the first two steps of the POR-15 kit which uses phosphoric acid. Worked great, but the kit was about $35 and really all I used was the cleaner and acid. Checked out Must for Rust at Home Depot and it is phosphoric acid as well and only about $6. Though it did reveal some holes in the tank  >:( it worked great. Afterwards, rinsed real well and just let it air dry. Finally got around to uploading some pictures. Top two are the before and bottom the after. Pretty impressive stuff for the price.
Offline cbjunkie
« Reply #32 on: January 11, 2006, 07:24:17 PM »
ha-ha, right on! full circle, bob - i bought the P-15 kit after you recommended it on your site - i already was using the MFR on the 350 last year and didn't make the connection (i did NOT bother to read the ingredients  :-\) until i actually poured out the POR-15 stuff into my tank...
i thought, "hmm...this looks, smells, and acts just like the MFR stuff..."
those photos say it all...my "new" SS tank from ElCheapo is on its way right now - I hope it makes it by this wkend...  ;)
1971 750K1
the free men.
Offline paulages
  • 1976 cb735
    • DOOMTOWN RIDERS P.R.M.C.
« Reply #33 on: January 11, 2006, 07:37:26 PM »
can't wait to see you beat the hell out of it. ;)
paul
SOHC4 member #1050
1974 CB550 (735cc)
1976 CB550 (590cc) road racer
1973 CB750K3
1972 NORTON Commando Combat
1996 KLX650 R
Offline cbjunkie
« Reply #34 on: January 11, 2006, 07:39:05 PM »
fear not - i plan to beat it sensless..  ;D
1971 750K1
the free men.
Offline DiscoEd
  • Keeping it surreal!
    • My personal gallery is at:
« Reply #35 on: January 11, 2006, 08:12:01 PM »
Careful CBJ, what goes around comes around!
-DiscoEd
1975 CB550 K1
1976 CB550
1974 CB360
2003 Suzuki Volusia Intruder
http://gallery.sohc4.net/main.php?g2_itemId=1954
Offline cbjunkie
« Reply #36 on: January 11, 2006, 08:16:34 PM »
good point. i retract my unheeding and ignorant statement, oh motogod! (not you, ed)  :D
1971 750K1
the free men.
« Reply #37 on: January 12, 2006, 04:34:49 AM »
Hey CBJ, before you take the hammer to it, I'll send you a couple of pics of an F tank that Carpy converted to a real nice "Cafe" tank by cutting and welding "Knee recesses" and a K series filler, it really changed the look of the tank, without the requirement for a bucket of bondo, ha ha! I've got the pics on a CD he sent me, I'm "pliagarising" the look for a tank I'm doing for Sean Condon, but am upgrading it with a modern Yamaha R1 style flush filler cap. Cheers, Terry.  ;D
Offline cbjunkie
« Reply #38 on: January 12, 2006, 08:03:01 AM »
i've seen the cutting and welding jobs he does - and they're very nice. if bikes were the center of my universe (shock! awe!) and my means of sustenance then i would definitely apply my craftsman's touch to the process this way... ;D
here's what me and paul are up to...
http://www.sohc4.us/forums/index.php?topic=6254.0
first paul's - the inspiration...
then mine - the first (failed due to pinholes) attempt...
but do send on the Carpy photos, Terr - maybe you have some that he doesn't have posted?
1971 750K1
the free men.
DONZIE
« Reply #39 on: January 12, 2006, 04:23:52 PM »
HELLO ALL - I am new to your group but certainly not new at what you guys are doing - I may can help on this one - I have sealed "dozens" of tanks over the years & have tried pretty much all the brand sealers mentioned here - all appear to worK "ok" buuuut for me this is the ultimate sealer & it is cheaper  @ about $30 a full quart - i really like the fact that it is silver not funky green like some - once applied your tank still looks like silver metal inside not gummie bear green
check out their sight ----
DONZIE
 <The MasterSeries Coating Line Rust Paints & Coatings: Stop Rust Permanently>
« Reply #40 on: January 12, 2006, 04:53:45 PM »
G'Day Donzie, have you got a link to the site? Cheers, Terry. ;D
« Reply #41 on: January 12, 2006, 05:00:13 PM »
« Reply #42 on: January 12, 2006, 05:23:31 PM »
This one? ???
DONZIE
« Reply #43 on: January 12, 2006, 06:09:08 PM »
YEP THATS THE STUFF - GET THE THINNER TO GO WITH IT - IT IS PRETTY THICK & IF YOU DON'T THIN IT IT WILL WANT TO PUDDLE - AS WITH SEVERAL OF THE OTHER TANK SEALERS IF YOU LET PUDDLE TOO MUCH AS IT DRIES SOMETIMES IT WILL CRACK OR WRINKLE A BIT - IT DON'T HURT ANYTHING IT JUST LOOKS BETTER NICE & SMOOOOOOTH - IT IS A VERY GOOD HIGH BUILD PRIMER ALSO - I HAVE USED IT SEVERAL TIMES UNDER THE BOTTOMS OF TANKS BADLY PITTED - IT DOES JUST WHAT THE SUPPLIER CLAIMS -
OH YEAH - I HAVE NO CONNECTION WHATSOEVER TO THIS PRODUCT I JUST THOUGHT SOME OF YOU GUYS MAY BE INTERESTED
DONZIE
Offline cbjunkie
« Reply #44 on: January 12, 2006, 06:19:51 PM »
scroll down a bit and see a product that could be the answer to our "what do you paint the underside of fenders with?" thread...
1971 750K1
the free men.
Offline DiscoEd
« Reply #45 on: January 12, 2006, 06:44:50 PM »
Man CBJ, I'm glad you caught that... I went to page but didn't scroll down there.  :-[
This stuff does sound interesting for project "Fender"
1975 CB550 K1
1976 CB550
1974 CB360
Offline cbjunkie
« Reply #46 on: January 12, 2006, 07:03:12 PM »
from the "about products" page...
"This primer was developed in the mid-70's as a bridge primer. Bridges coated with 2 coats of silver and one coat of color such as our AG111 have a documented 20-25 year service life."
#$%*in'
1971 750K1
the free men.
Offline DiscoEd
« Reply #47 on: January 12, 2006, 07:24:29 PM »
#$%*in'
Well, that is troubling! I guess that means I'll have to paint the fenders on my 550 twice before I pass it on to DiscoEd Jr.
By then the bike should only be about 80 years old.
-DiscoEd
1975 CB550 K1
1976 CB550
1974 CB360
whoismattclark
« Reply #48 on: April 24, 2006, 11:09:13 AM »
I gave the "The Works" a try last week and boy does it work.  I had similar "before & after" results as Bob W's posted pics.  Problem is the rust came back immediately -- within 24 hours.  It was probably my fault...I think these 2 things contributed:
I was judicial in the use of my wife's "borrowed" hair-dryer for fear of breaking it, and I tried to immediately fill the tank with gas to keep prolonged exposure to air, but I found I had a leaky petcock, so I had to drain it, leaving it more exposed than I would have liked.
So, today, I try again.  This time I bought my own cheapo blowdryer from Big Lots, fixed the petcock, and on a suggestion from a mechanic, I'm gonna give the tank a good soaking of WD40 after the drying cycle.
Any suggestions on process and procedure before I jump in again are quite welcome...
thanks,
MDC
in Los Angeles
eldar
« Reply #49 on: April 24, 2006, 11:54:17 AM »
fogging the tank with wd-40 works pretty well and you dont need to wash it out before filling with gas.
