Author Topic: cb 550---Anybody know offhand the size of the rear axle nut?  (Read 4147 times)
Offline elquenada
« on: January 23, 2010, 09:52:53 AM »
I dont have a socket big enough to torque down the rear axel nut and I dont feel like buying a whole set.  any idea how large that nut is? I looked in the parts manual and on motogrid's website and the size wasn't listed.
1975 CB 550
"A veces lo que es contra lo justo
por la misma razón deleita el gusto"
Lope de Vega
Offline bk0931
    • www.brianweissrestorations.com
Re: cb 550---Anybody know offhand the size of the rear axle nut?
« Reply #1 on: January 23, 2010, 05:27:40 PM »
I think i bought a 1 and 1/16 size socket for the rear axle. I know it should be metric but its what i had and i think it worked
76 cb550k
76 cb550k
86 ford f-150
Offline elquenada
« Reply #2 on: January 24, 2010, 12:55:22 PM »
thanks.
1975 CB 550
Lope de Vega
« Reply #3 on: January 24, 2010, 01:00:45 PM »
The stock toolbag wrench is easy to use & prevents overtorquing.. six point too..
 Not sure if Honda still sells them, but, I cant see them being  much over 10 bux used.
 Over tightening is pretty hard on adjusters and such..
Offline MickeyX
« Reply #4 on: January 24, 2010, 02:34:49 PM »
Well, if it's not tight, why not just take it in with you and size it up?  :) Or, if it's something that I need to take off, I put an adjustable wrench on it and then measure that with a tape or in relation to another wrench size.
So, what size was it then?  :)
Offline elquenada
« Reply #5 on: January 24, 2010, 03:27:35 PM »
not sure I just hand tightened for now cause I was busy with other things.  i'll pull it off this week and bring it to the store. if what bk0931 says is true than it should be a 27mm.
1975 CB 550
Lope de Vega
Offline chickenman_26
    • Motorcycle Consumer News
« Reply #6 on: January 24, 2010, 04:04:26 PM »
It's 26mm.
MCN DTF
Offline elquenada
« Reply #7 on: January 24, 2010, 06:20:54 PM »
cool.  thanks for the confirmation.
1975 CB 550
Lope de Vega
« Reply #8 on: January 25, 2010, 07:58:11 AM »
It's 26mm.
For 550F2 and K3 it's 18mm.
« Reply #9 on: January 25, 2010, 08:33:37 PM »
use a "shifter" or is that a monkey wrench or an adjustable spanner?
« Reply #10 on: February 08, 2010, 08:34:27 AM »
It's 26mm.
The thread is 18 mm. He wanted to know what size socket is needed for the nut. That's 26 mm.
MCN DTF
« Reply #11 on: February 08, 2010, 01:52:52 PM »
Quote from: Deltarider on January 25, 2010, 10:58:11 am
It's 26mm.
Sorry, the 550F2 and K3 have a smaller nut 24mm or even 22mm.
« Last Edit: February 08, 2010, 02:02:10 PM by Deltarider »
Offline SHELLFISH
« Reply #12 on: February 08, 2010, 02:48:24 PM »
1976 550 F & K are both 26mm. I use a 1 inch wrench. It's tight but it works.
I want to die like my grandfather did...in his sleep and not screaming like the passengers in his car!
Offline elquenada
« Reply #13 on: February 08, 2010, 06:13:36 PM »
thanks.  the 26mm was the right size for the '75 550 k1 as well.
1975 CB 550
Lope de Vega
« Reply #14 on: February 10, 2010, 10:35:46 AM »
That's what I love about Internet tech forums. No guesswork, just the facts. ::)
MCN DTF
