Author Topic: 1973 cb750 bars  (Read 1780 times)
Offline rustrocket92
  • Mad Fabricator
  • Buster is in the Lab!
1973 cb750 bars
« on: January 25, 2010, 06:04:44 PM »
I am trying to figure out the size of 1973 k handle bars ? I know they are 7/8 " bars but what are the other specs ? especially how tall.
1973 cb750k
1976 cb750k
1978 cb750f
1978 cb750k
Offline Alan F.
Re: 1973 cb750 bars
« Reply #1 on: January 25, 2010, 06:27:07 PM »
My 73 had some fairly tall bars on it when I got it but still had internal wiring, I believe they're called '300' bars.  What other measurements do you need?
Offline Johnie
Re: 1973 cb750 bars
« Reply #2 on: January 25, 2010, 06:32:36 PM »
The 73 & 74 had the same bars. My K4 came with higher bars the previous owner put on in the pic. I am removing them and going with the stock bars. Are these the taller ones you mentioned?
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline Alan F.
Re: 1973 cb750 bars
« Reply #3 on: January 25, 2010, 06:47:06 PM »
I knew I had a pic somewhere, the bars at the top are stock 78CB750K the lower ones are what I referred to in my earlier post.
  • Mad Fabricator
Re: 1973 cb750 bars
« Reply #4 on: January 25, 2010, 07:29:52 PM »
Maybe I should have explained what I am doing and you guys could help better. I have already completed my first project. See the OPERATION BIRTH KONTROL thread and I am now starting my second project OPERATION BOBZILLA. I am looking at building a hardtail bobber and I am wondering about the dimensions of stock bars. I can get 10" over cables but if I dont know the dimensions of the stock bars I can't quite figure out what size bars I can use with 10 over cables. For example if stock bars are 4" tall and I use 10" over cables I should be able to use 14" bars. CORRECT?
1973 cb750k
1976 cb750k
1978 cb750f
1978 cb750k
