Author Topic: rolling a fender lip  (Read 3242 times)
Offline bucky katt
  • i am a pastafarian!
    • facebook
« on: January 27, 2010, 03:40:24 PM »
i am going to bob the rear fender on my k4 750 and i'm wondering if anyone here can tell me how to roll the egde to make it look more professional? i dont really have any metal working tools or a torch. the rear fender is just way too long looking with the airtech cafe tail i have.
Mark Twain - Notebook, 1894
Offline lone*X
Re: rolling a fender lip
« Reply #1 on: January 27, 2010, 03:53:14 PM »
Do a search on cutting or shortening the rear fender.  Haven't done it myself but some have shortened it by cutting either the inner fender or under the seat to shorten it from the other end and leaving the factory rolls in place at the back.
Lone*X  ( Don )
75 CB550K1
VTX1800C for two up cruisin.
Offline Alan F.
« Reply #2 on: January 27, 2010, 06:18:28 PM »
+1 but it still leaves all of the mounting holes from the tail light.
Offline 78 k550
« Reply #3 on: January 27, 2010, 07:22:26 PM »
if your just shortening it I would cut a little about the seam then re-weld it back up. That might not work if your not keeping a kinda similar shape.
Paul
Paul
Littleton, CO
76/77 CB 750F,
76 GL1000 LTD
84 GL1200 Standard
Offline bucky katt
    • facebook
« Reply #4 on: January 27, 2010, 07:35:09 PM »
i've actually cut it already, i just dont like the raw edge that was left after the cut. i want to actually roll the edge so that it matches the rest of the fender, just the edge where i cut
Offline mrblasty
  • Expertly
« Reply #5 on: January 27, 2010, 08:38:48 PM »
DAMNIT BUCKY! WHY DID YOU CUT FIRST ASK SECOND?  Sorry, I must have been channeling my dad.  The only way now is the hard way, with you fist and teeth.
I farted and made my son cry.
1973 Honda CB 750
1975 GL 1000
Offline bucky katt
    • facebook
« Reply #6 on: January 28, 2010, 12:06:11 AM »
i cut on a badly rusted fender first, before cutting into the nice one thats on the bike  :D i want to make sure i know what i'm doing before i cut on the nice stuff. i remember using an old wooden baseball bat to roll a fender lip to get a little extra clearance on a lowered car, you'd just put pressure on it as you steadily roll it around the wheel opening.
« Last Edit: January 28, 2010, 12:07:45 AM by bucky katt »
Offline mystic_1
  • 1970 CB750K
« Reply #7 on: January 28, 2010, 05:15:07 AM »
Is the fender chromed?  If so, you won't be able to roll the edge without messing up the chrome.  That aside, it'll be hard to roll the edge without either a specialty tool or a torch.  If you still have that welder, you could weld on some rod stock to give you a nice edge and then refinish the fender.
mystic_1
- John Augustus Shedd
Offline bucky katt
    • facebook
« Reply #8 on: January 28, 2010, 05:22:06 AM »
no more welder. of course the week after i sell it i need it for something. i got rid of it because i hadnt used it in about 2 years.oh well, i'll figure something out.
« Reply #9 on: January 28, 2010, 08:48:30 AM »
Try this,
 get a piece of flat bar, grind to match fender radius, and be square.
 draw a line about 3/8  or 1/4 from fender edge with morphys or dividers.
 start in the middle hold fender firmly and start to tap over the 3/8 part till it is about 90 degrees, then move flat bar or and repeat.
 when you get into the sides (after middle is complete), regrind and square up the flat bar (1in or 1.25 should work here), and finish corners to 90 degrees.
 when the whole cut is at 90, flip fender, put on a wood block, and gently hammer the edge down to flat..
 good luck....
Offline bucky katt
    • facebook
« Reply #10 on: January 28, 2010, 09:31:25 AM »
thank you for the idea 754, i'm going to wait another hour let it warm up a bit more then i'll try doing just that. going to mount the viper fairing too.
Offline Really?
« Reply #11 on: January 28, 2010, 11:23:23 AM »
Wow Bucky.  I hope I didn't make you do that.
The Wife's Bike - 750K5
The Kid's Bike - 750K3
Offline bucky katt
    • facebook
« Reply #12 on: January 28, 2010, 11:32:42 AM »
? i'm a bit foggy and confused now
Offline Really?
Offline bucky katt
    • facebook
« Reply #14 on: January 28, 2010, 11:59:41 AM »
nah TipperT, the more i look at it the less i like it. i will be keeping the grab bar but the fender will get bobbed and i'll just drill new holes to mount the tail light, then i'll weld nuts on the underside of the fender so it will bolt back on like factory.
Offline stueveone
« Reply #15 on: January 29, 2010, 04:49:35 PM »
I've used this stuff before. . .
http://www.brandsport.com/trmg-2105-c.html
Works surprisingly well. You can't even really notice that its not a factory rolled edge!
Offline bucky katt
    • facebook
« Reply #16 on: January 29, 2010, 05:04:53 PM »
you know, i had been thinking about doing just that, i still have most of a roll of it in my toolbox from when i ran a detail shop.
Offline mrblasty
  • Expertly
« Reply #17 on: January 30, 2010, 01:30:55 AM »
here are a few pics of my rear fender and my bike that hasn't been washed in over two years :o
1973 Honda CB 750
1975 GL 1000
Offline mystic_1
  • 1970 CB750K
« Reply #18 on: January 30, 2010, 07:19:58 AM »
Ever get hassled about your license plate?
mystic_1
Offline mrblasty
  • Expertly
« Reply #19 on: January 30, 2010, 11:40:57 AM »
mystic_1
Not yet, the cops aren't dicky to motorcycles up here.  When I first put it all together I thought about it for a sec but took the wait and see approach.  The plate is just visible from the seat of a car.
1973 Honda CB 750
1975 GL 1000
« Reply #20 on: January 30, 2010, 09:06:03 PM »
In these parts we have numbers..and they are higher than 11 and bigger.. :o
Offline NickC
« Reply #21 on: January 30, 2010, 09:20:25 PM »
I bobbed the front of the fender on my 550 and moved it. No rolling necessary  ???
