Author Topic: original honda sohc oil cooler set up?  (Read 15031 times)
Offline turboguzzi
« on: January 29, 2010, 08:20:55 AM »
was a bit surprised to find this,
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=310146542065&ssPageName=STRK:MEWAX:IT
anybody's got an idea if it'll work on a sohc?
seems to be from the CBX dohc 650/750 series motors, i.e. like those of mid eighties 650/750 nighthawk
diameter seems like that of a sohc
TG
Offline voxonda
Re: original honda sohc oil cooler set up?
« Reply #1 on: January 29, 2010, 08:26:16 AM »
TG,
Can't see why it should not work, it is the same simple setup as I, and others produce.
Cheers, Rob
Offline turboguzzi
« Reply #2 on: January 29, 2010, 08:27:28 AM »
rob
do you have any idea if the CBX type motors used the same oil filter cover as the sohc's?
Offline voxonda
« Reply #3 on: January 29, 2010, 12:21:30 PM »
Looking at the adaptorplate I think they do, it even has casted piece to center the oilfilterhousing on top. Sorry, do not know how to describe it, hope you understand. Just googled a bit and yes they do have the same setup.
Rob
« Last Edit: January 29, 2010, 12:23:39 PM by voxonda »
Offline wrenchmuch
« Reply #4 on: January 29, 2010, 12:56:24 PM »
You'll need the longer filter housing bolt to use it on a sohc . Later F's had a cooler plate in between the case and filter cover (no lines or external cooler ) and used the longer bolt .
CB750K1
CB750K4
Offline voxonda
« Reply #5 on: January 29, 2010, 12:58:57 PM »
+1
Offline turboguzzi
« Reply #6 on: January 29, 2010, 10:20:50 PM »
kewl, will look it up on the parts list, the seller already told me he doesnt have the center bolt
Offline RRRToolSolutions
  • I love old Japanese bikes!
« Reply #7 on: January 30, 2010, 04:28:37 AM »
That is the exact cooler I use on mine - I bought the 1983 650 version and had new, custom cloth-covered lines and fittings made for $25 to fit Terry's 750 adapter. Mine works like a charm.
Gordon
Kaws, Hondas, Yamahas, and Suzukis - especially Kaws
« Reply #8 on: January 30, 2010, 05:03:26 AM »
I've got a feeling that these adapters (which were used on several Honda's including late model SOHC 650's, apparently) have been tried by some folk here before, but there was a problem that they wouldn't work without some additional machining/fabrication?
Also, as Rob will attest, the purpose of the adapter is to block flow and redirect oil from the engine, up the hose to the cooler radiator, and back down into the engine via the filter. Because of this, the longer oil filter bolt from a CB750 F2/F3 on it's own won't do much, as it will allow oil to flow past straight into the filter, and not up the oil hose, into the cooler radiator. So while it might look like you've got an oil cooler on your bike, in truth, it's just a non-working replica of an oil cooler.
The radiators are good though, I've used a few over the years. Cheers, Terry. ;D
Offline turboguzzi
« Reply #9 on: February 02, 2010, 03:11:55 PM »
good explanation as why this stock dohc 650 setup wont work with just a longer bolt, but then, how does it work on those nighthawks? what are we missing?
TG
« Reply #10 on: February 03, 2010, 10:13:56 PM »
Some, and i cant remember which(750 twin cam maybe), had a short steel adaptor piece that held the sandwich plate(for want of a better description) to the crankcase then the filter bolt screwed into that.
Didnt the longer F2 bolt have a loose alloy "sleeve" on it?
« Reply #11 on: February 03, 2010, 10:37:43 PM »
TG
It could be like Bryan suggests TG, there might be an adapter bolt that secures the adapter to the engine? Cheers, Terry. ;D
G'Day Bryan, no need for a sleeve mate, the (useless) F2 heatsink thingy didn't redirect oil anywhere, so it was just a loose fit between the engine case and the oil fiter housing. Cheers, Terry. ;D
Offline City Boy
« Reply #12 on: February 04, 2010, 05:04:59 AM »
Hi gang.An alloy sleeve was used in 350/400F filter housings to bridge the gap between the 750 type filter and the crankcase in the longer housing of the little 4's.I use the longer housing on my 750 and 1100F.It holds 140 ml.[4.5 oz.]extra of the nectar.Clearance may be an issue depending on the exhaust pipes used.      Rock On
'52 Kiekhaefer Mercury Rocket Hurricane KG4H
'70 750/RC 1000 Original Owner
'83 1100F
Offline coyotecowboy
  • Easily Distracted
    • American Legion Riders Post 69 Medicine Lodge, Ks
« Reply #13 on: February 04, 2010, 04:47:12 PM »
Gordon
Ok, I gotta know, what is that filter housing off of?  I'm running into a problem with my cooler plate putting my filter housing out too far to clear my 4 into 1 header.  The fins hit, and I could chuck it up in the lathe and turn them down but it would be better yet to just buy one without the fins in the first place... :P
The adventure begins when things stop going as planned - Glen Heggstad
http://www.alrpost69.com/
Sunrise Orange 750 K2
1981 Husqvarna 430 XC, "Inga"
Offline cb650
« Reply #14 on: February 04, 2010, 04:52:28 PM »
I dont think they are off a sohc 650.   Most of the nitehawk dohcs had them  550 650 700 ect.
Offline Ross Davis
    • Retro Ride Info
« Reply #15 on: February 04, 2010, 05:01:46 PM »
It is like the one off the 650 Nighthawk DOHC with HVAs.  The SOHC F2 750 had a spacer for a cooling fin it had and a longer oil filter bolt.  You can machine the lower housing it to fit and use the lines that are there.
« Reply #16 on: February 04, 2010, 06:45:53 PM »
That is a customm adapter Terry in Australia made for me. Give him a PM and see if he'll hook you up.
Best Regards,
Gordon
« Reply #17 on: February 04, 2010, 06:49:34 PM »
That is a custom adapter Terry in Australia made for me. Give him a PM and see if he'll hook you up.
Best Regards,
Gordon
Thanks Gordon, that's one of my adapters with a spin on filter. Cheers, Terry. ;D
  • Easily Distracted
« Reply #18 on: February 04, 2010, 07:41:15 PM »
I see now.  I've already got the adapter plate and cooler, it just has a hollow bolt that threads into the block, then the oil filter housing fits onto that with the stock bolt.  It came off a K6 that hadn't run since about 78.  I should probably check the passages and make sure that the oil flow is directed through the plate then the cooler, and not just directly into the filter.
« Reply #19 on: February 05, 2010, 04:19:47 AM »
Terry sent me a special fitting that threads through the adapter and into the crankcase at 30 lbs. The exposed end fits the K&N chrome filter perfectly. I buy the filters through discount parts retailers for about $12 each. This set-up makes oil and filter changes a breeze and with the oil filter and cooler - almost a quart more Motul synthetic can circulate inside - a win-win for me and a bunch of expensive pieces inside.
Regards,
Gordon
Offline mick7504
« Reply #20 on: February 05, 2010, 07:38:29 AM »
Here's an adaptor plate and bolt from the 70's.
Simple and efficient.
Easy enough to turn up in a lathe.
If I was you
I'd be worried about me.
Offline turboguzzi
« Reply #21 on: February 05, 2010, 08:40:30 AM »
hei mick
seen those plates, since the central wall has to be thick enough to take the pipe threads, it looks like it weights a ton. can you weight it?
I am trying to add as little weight as possible to my racer and since that honda adapter plate is cast, it has material only where needed = much lighter.
manged to find that the stock honda plate has a similar short fitting to hold the plate.
cheers
TG
Offline mick7504
« Reply #22 on: February 05, 2010, 09:34:08 AM »
TG
The adaptor plate weighs 400gms and the bolt 80gms.
A friend uses a lot of Bronze Alloy and I think it should be lighter than than a cast plate while still maintaining strength.
Or maybe turn an adaptor plate from aluminium stock.
The plate could be trimmed a little shed some weight.
If I was you
« Reply #23 on: February 05, 2010, 04:03:37 PM »
TG
That adapter is the same as one type that I make, it is heavy compared to the lightweight cast potmetal "Lockhart" and "Derale" adapters of the era, but it could be lightened considerably as most of the 20mm (+/-) wall thickness could be milled out, either side of the oil passages.
I did it a few times on adapters that I made, but it's time consuming, and most of the 200-odd that I've sold on EBay and to members here have gone on road bikes, where weight wasn't an issue.
CB750 racers use a cooler with pipes coming from and returning to the engine and oil tank, the advantage being that the long hoses carry a fair bit of extra oil, so when you add a big cooler radiator as well, you're increasing the oil capacity by a litre or so. The racing coolers aren't all that practical on road bikes, where space for running the long hoses over the engine and under the tank is limited when shared with wiring looms, cables and other hardware. Cheers, Terry. ;D
Offline turboguzzi
« Reply #24 on: February 06, 2010, 05:56:17 AM »
hei terry
thanks for the info, in my case it would go on a 500, so no hose volume added.
question still remains, is that SC series adapter a bolt on on a 500?
Cheers
TG
