Author Topic: Honda CB550 only running on 2  (Read 2118 times)
Offline country joe
« on: January 29, 2010, 09:38:06 PM »
 hi, I'm new to the honda sohc website. I currently have a Honda CB550 that was given to me. My brother had the bike last, and had no use for it (He's a british bike guy). Anyway he had it running, but it only ran on two cylinders. which two I'm not sure. I haven't had time to play with it much, but I plan on making a bobber project out of it this spring. Anyone know if this is a common problem with these models, or anything else I should know about the CB550. Any advice or comments would help me out. I have more experience with Harleys than I do with these four cylinders so its all new to me. Thanks,  Country Joe
'78 Honda CB550K
'79 Yamaha IT400
'74 H-D Sprint 350 (basket case)
Offline Deltarider
Re: Honda CB550 only running on 2
« Reply #1 on: January 30, 2010, 01:22:53 AM »
If you can identify which two are not running, we can start commenting.
CB500K2-ED Excel black
Offline Gordon
  • 750K1, 550K2
« Reply #2 on: January 30, 2010, 06:49:06 AM »
+1
Could be lots of things, but knowing which cylinders will help narrow it down a lot.
Offline SHELLFISH
« Reply #3 on: January 30, 2010, 07:06:18 PM »
To get you started:  cylinders #1 and #4 run off of one of the points and one of the coils.
Cylinders #2 and #3 run off of the other points and the other coil.
So if #1 and #4 are not running or if #2 and #3 aren't running look at the points and or coils.
If it is a different combination say #1 and #3 then look at the carbs, fuel, vacume leak, compression or something else!    Good luck on your search!
I want to die like my grandfather did...in his sleep and not screaming like the passengers in his car!
Offline Tews19
  • I am no
« Reply #4 on: December 03, 2011, 12:31:37 PM »
Trim the spark plug wires, clean the caps and rescrew on. See if that helps.
1970 Honda CB750 survivor.
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #5 on: December 06, 2011, 01:42:32 PM »
To add to that if 1&2 or 3&4 aren't firing then look at the petcock or fuel lines, the two banks are seperated there.
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
