Author Topic: Honda CB compatibility  (Read 3195 times)
jonathantaylor86
« on: February 01, 2010, 10:24:59 AM »
Does anyone know if the points cover and headlight assembly from a CB750 or CB450 could fit a CB500? I have a 72' CB500 and I'm looking for parts so I will know if I can broaden my search for these items by knowing that they are compatible.
Offline Old Scrambler
Re: Honda CB compatibility
« Reply #1 on: February 01, 2010, 10:44:40 AM »
No Exchange on those models.............Do a search on part numbers.
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
Offline MFHP
« Reply #2 on: February 01, 2010, 11:04:40 AM »
Headlight is the same as 750
Point cover is unique
cheers,
Mike
750K77;  CB500Four K1
Offline paulages
  • 1976 cb735
    • DOOMTOWN RIDERS P.R.M.C.
« Reply #3 on: February 01, 2010, 12:11:35 PM »
Cb650 makes a good points cover replacement.. it's much thicker than the easy-to-dent cb500/550 cover, but bolts right on.
paul
SOHC4 member #1050
1974 CB550 (735cc)
1976 CB550 (590cc) road racer
1973 CB750K3
1972 NORTON Commando Combat
1996 KLX650 R
jonathantaylor86
« Reply #4 on: February 01, 2010, 12:15:15 PM »
do you know what years of the cb650 are compatible?
Offline MickeyX
« Reply #5 on: February 01, 2010, 12:35:39 PM »
1971 Honda CB500
1972 Honda CB350F
1972 Honda CB500K1
1973 Honda CB500K2
1974 Honda CB350F1
1974 Honda CB550
1975 Honda CB400F
1975 Honda CB550F
1975 Honda CB550K1
1976 Honda CB400F
1976 Honda CB550F
1976 Honda CB550K
1977 Honda CB400F
1977 Honda CB550F
1977 Honda CB550K
1978 Honda CB550K
All '79-82 CB650 or CB650C, not the Nighthawk version though.
jonathantaylor86
« Reply #6 on: February 01, 2010, 12:43:50 PM »
thats brilliant MickeyX
Offline squeakywheelz
« Reply #7 on: February 19, 2010, 11:59:45 AM »
I'm sure this has been asked elsewhere:
CB750k exchange?  Looking to transplant a k7 engine in a k3 chassis.  Any known changes to the mounting, chainline, wiring, etc?  Drag and drop, right?
750K3 + F2 Engine --> Cafe-esque
Offline vames
« Reply #8 on: February 19, 2010, 12:45:46 PM »
You can renew an old scratched dented points cover by boiling it in wintergreen oil, apparently.
« Reply #9 on: February 19, 2010, 01:13:55 PM »
It works better if you add seafoam to the mix
Offline MFHP
« Reply #10 on: February 19, 2010, 02:19:21 PM »
probably, you could do a search.
Mounting is the same. Wiring is the same. But chainline is different. You will also need the rear wheel sprocket carrier from the K7. The sprockets on the K7(as well as on the F2) are moved more outwards to give enough clearance between the wider 630 chain and the also wider 17"x4.5 tyre.
good luck
Mike
k7; 500K1
« Reply #11 on: February 19, 2010, 07:18:01 PM »
The CB750 points cover has the "HONDA" at right angles to the screw holes, but otherwise fits, leaving the "HONDA" on an angle of about 30 degrees.
But, most used 750 covers are bent! :-\
