Author Topic: Broken timing light or weak spark?  (Read 4876 times)
Offline elquenada
« on: February 01, 2010, 05:11:46 PM »
i got a used sears timing light and dwell meter a while back on ebay.  i was trying to use the light this weekend but the strengh and consistency of the strobe was very weak except on cylinder two.  The cylinder two plug wire produces a constant strobe whereas the other plug wires only give off an ocasional flash here and there.
The plug readings look pretty good as far as can tell (light tan).  I also tried grounding the spark plugs to the engine and found that although plug two looks a little stronger, all plugs had a visible blue spark.  do you think my light is busted?  if not should I install new cables?  I read the FAQ and the new cable install doesnt look that hard to do.
ps-i have a stock setup with a Dyna S ignition and NGK plug caps. (PO installed it) Plugs are D8EA.
1975 CB 550
"A veces lo que es contra lo justo
por la misma razón deleita el gusto"
Lope de Vega
Re: Broken timing light or weak spark?
« Reply #1 on: February 01, 2010, 11:35:40 PM »
First make sure your HTleads are clean and free of grease. Be aware of polarity when you clamp the induction trigger on a cable. On our bikes "This side towards plug" is true for only two of the four cables. For the other two it's the other way around to get the strobe function. Close clamp well.
« Reply #2 on: February 02, 2010, 02:08:42 AM »
is the light 12 volt powered,is the battery good ?does the bike charge well idling?if the voltage is low the light may suffer.
Offline Yoshi823
  • Biker to the bone.
  • Never too old to be a biker
« Reply #3 on: February 02, 2010, 02:51:33 AM »
I used to work for Sun Electric (now part of Snap-On) & repaired there diagnostic equipment. One day I had to repair a customers engine analyser as his strobe was defective, a common situation when the strobe was dropped. After doing the repair I checked it on a simulator & all was working ok. A few days later I had a recall as the customer reckoned that the Sun machine was 'out' when compared to his Snap-On timing light. After I got the customer to attach both pieces of equipment to a common source, it transpired that the RPM pickup magnet shapes were broken on the Snap-On light. This was also a common occurance as the shapes were quite easily broken if dropped or clamped shut over the ignition lead when the lead was not in the 'U' shaped bit.
Bikes...they're in the blood.
Yamaha 2001 R1
Yamaha 1990 FZR1000R EXUP
KTM 2004 450 EXC RFS
Honda 1997 XR400R
Honda 1988 CB125T2
http://www.cb750cafe.com/bikes.php?cat=3&id=67
Offline elquenada
« Reply #4 on: February 02, 2010, 03:09:03 AM »
great info. my battery is brand new and fully charged.  it also appears to be charging when i raise the rpm and put the multimeter to it.  I didnt know that some of the leads had reverse polarity so i{ll definitely check that out.
as far as what yoshi said..im not reallt sure what to make of this.
1975 CB 550
Lope de Vega
« Reply #5 on: February 02, 2010, 04:59:21 AM »
That inductionclamp is very delicate indeed. That's why on many you'll find the warning: Do not drop. I'd like to add: avoid any impact!
BTW, you'll have best results when the strobe is fed by an external battery. I don't know why this is, but that's the way it is.
« Last Edit: February 02, 2010, 05:05:39 AM by Deltarider »
Offline elquenada
« Reply #6 on: February 02, 2010, 09:40:40 AM »
ok well maybe I will use the 12v battery off my scooter to power it and see what happens. thanks.
1975 CB 550
Lope de Vega
Offline Gordon
  • 750K1, 550K2
« Reply #7 on: February 02, 2010, 08:17:35 PM »
Try pulling the plug cap off the spark plug and resting it on top of the plug so there is a small gap between the cap and the plug, but not so large a gap that the spark can't jump it.
I'm not exactly sure why this works, probably something about added resistance in the circuit, but I've had to use that trick on my old VW as well as a few motorcycles, and it works well.
Offline elquenada
« Reply #8 on: February 03, 2010, 05:00:31 PM »
interesting tip. i'll definitely try that this weekend when I can get back at the bike. too bad it looks like snow is coming so i doubt a test ride will really be possible.
1975 CB 550
Lope de Vega
« Reply #9 on: February 03, 2010, 11:43:23 PM »
Why? It's against the laws of physics. It's in fact an extra threshold. If there's not enough energy to jump the gaps and as a result the energy in the coil can't go anywhere, it could ruin your coils.
« Last Edit: February 04, 2010, 08:20:05 AM by Deltarider »
Offline Gordon
  • 750K1, 550K2
« Reply #10 on: February 04, 2010, 08:59:24 AM »
Like I said, keep the gap small enough that the spark can jump it.  It works.
