Author Topic: Valve spring booster shims  (Read 2356 times)
« on: February 02, 2010, 01:49:20 pm »
Hi guys. I'm looking for shims to set spring pressures in a 500/550 head. Minimum ID is 0.737" maximum OD is 1.050", and I believe I can live with some at 0.015" thick.
Does anyone have a more modern 4 valve head apart with shims that might come close? I HAVE finally just found a place (after many calls) where I can buy some that are 0.765"ID & 1"OD but wonder if I might be lucky enough to get something closer.
Thanks
Re: Valve spring booster shims
« Reply #1 on: February 02, 2010, 07:33:54 pm »
With a shim punch kit you should be able to knock out .750 id and 1.060 od (if they go that big).
 If there was a bit of demand, be easy to make a punch, or they could be made on a lathe..
« Reply #2 on: February 03, 2010, 04:26:49 am »
Thanks Frank. I don't have a shim punch kit & it may be faster & cheaper to just buy these shims and run with em.
Offline lordmoonpie
    • Moonpie
« Reply #3 on: February 03, 2010, 05:18:35 am »
Brent,
They might not be cheap but have you tried DelWest in the USA? They do all kinds of shims and will make anything to spec. if it's not stock.
1994 Ducati 888 SP5
1951 Ducati 50cc Cucciolo
1981 Yamaha XV750 SE
Offline kos
    • m3racing.com
« Reply #4 on: February 03, 2010, 06:38:56 am »
I have a DOHC apart and the standard shims are .040" thick.
KOS
220...221, whatever it takes.
Offline kos
    • m3racing.com
« Reply #5 on: February 03, 2010, 07:48:09 am »
Just found some .035" shims from KPMI 5mm CB750 conversion kit.
If you need, let me know. Free to SOHC guy.
KOS
« Reply #6 on: February 03, 2010, 08:06:11 am »
KOS
I have some those too Mark but I think he wants a tighter ID.
« Reply #7 on: February 03, 2010, 08:08:48 am »
A CNC punch could knock em out fast, I assume you want steel if they are that thin..
Offline turboguzzi
« Reply #8 on: February 03, 2010, 03:21:48 pm »
cant you ground some down on a face grinder with a magnetic holder plate?
« Reply #9 on: February 03, 2010, 03:25:29 pm »
I have done some, the problem is at 1mm they heat so quickly.
I've got shims on the way.
