Author Topic: CB550 shift drum retaining bracket looks bent, badly?  (Read 1017 times)
Offline cb550fcafe
    • KDI Cycles
« on: February 03, 2010, 04:34:38 AM »
I'm tearing down a 76 CB550F for rebuild, I found the shift drum retainer badly bent. So I took another 550 apart and found the same thing, just alot less bent. So is this normal? Or is there something I need to take a closer look at?
Offline steam-powered man
  • Not the eggman, Not the walrus, I am the
  • Where are you going? I was going to make Espresso
Re: CB550 shift drum retaining bracket looks bent, badly?
« Reply #1 on: February 03, 2010, 10:30:28 AM »
just checked my 76cb550k retainer, not bent as much.  the nearby threaded insert moves in/out just a bit.  the retainer seems to limit this movement to about 1/32 proud of the case.
bobp
searching for a dr350se
« Reply #2 on: February 03, 2010, 04:00:08 PM »
That end of the retainer prevents the shifter fork shaft from coming out of the case. It should be straight but as shoemaniii said does not touch the shaft .
