Author Topic: relocating electrics under tank. is this spot too hot?  (Read 2071 times)
Offline cafenut
  • it dont hurt till the bone shows
« on: February 03, 2010, 07:31:45 AM »
anybody had problems with this mod? just seems to be alot of unsused space under there.
88 1100 katana
84 500 ascott
78 750 f cafe
78 750 f original
78 750 k stock
76 750 k custom
76 750 k chop project
Offline Inigo Montoya
Re: relocating electrics under tank. is this spot too hot?
« Reply #1 on: February 03, 2010, 09:48:28 PM »
Well coils do ok but for less robust electrics you might want some sort of heat shield at least. I would probably try under the seat.
Offline cb750k77
« Reply #2 on: February 03, 2010, 09:50:15 PM »
i agree under the tank gets really hot... under idle he is right under the seat is much better
CB750k77 rebuilt (almost)
Offline lordmoonpie
    • Moonpie
« Reply #3 on: February 04, 2010, 01:43:30 AM »
I run my micro digital ignition box under the tank. Trick is to keep it on top of the frame rail (loads of space) and underneath it, cut a pice of plumbers solder mat and tie wrap that in place. Plumbers solder mat is a ceramic weave matting that stops heat transfer when they solder up copper heating/gas pipes. It's very cheap from the local hardware store (well it is in the UK) and can be used all over a bike - for example on the inside of fairings that are close to engines or exhausts...
1994 Ducati 888 SP5
1951 Ducati 50cc Cucciolo
1981 Yamaha XV750 SE
Offline bucky katt
  • i am a pastafarian!
    • facebook
« Reply #4 on: February 04, 2010, 01:46:44 AM »
i imagine something like the high temp Dynamat might work ok too, but not as inexpensive as the plumbers mat that LMP suggested
Mark Twain - Notebook, 1894
« Reply #5 on: February 04, 2010, 06:46:19 AM »
Maybe wrap the unit in that weave then?
Offline cafenut
« Reply #6 on: February 04, 2010, 07:45:34 AM »
solder matt! heck of a cure, thanks alot for that tid bit. under the tank it shall be then!
88 1100 katana
84 500 ascott
78 750 f cafe
78 750 f original
78 750 k stock
76 750 k custom
Offline cb750k77
« Reply #7 on: February 04, 2010, 11:53:21 AM »
i think i'm gunna try that with my HID ballast i seem to of fried mine :( now my headlights dont work :(
