Author Topic: My CB750 Book and CB500/CB550 Book, by Hondaman: a 15% discount thru 5/23/25! :)  (Read 171891 times)
Offline Jonny R
    • Music stuff I do, sometimes...
Re: My CB750 book, by Hondaman. 20% off on MARCH 15 only!
« Reply #275 on: May 07, 2012, 03:16:21 PM »
Ordered one for my K3.  Stoked!  ^Thanks for the code, which worked fine for me.
1973 CB750 K3
Offline bender01
« Reply #276 on: May 07, 2012, 08:03:12 PM »
Buy the Book!
 The Helping Friendly Book!
   I have one and want another in hardcover!
75 550 K1
74 750 K4
1968 450 K1 Super Sport
74 750k 836 project
Good luck!
Two Tired Quote !
Offline bikerbart
« Reply #277 on: May 10, 2012, 10:57:48 AM »
I just got my Book today,wow,what an amazing publication.Thanks Again Mark!!!
Offline Kickstart
« Reply #278 on: July 12, 2012, 07:35:52 PM »
Hondaman - Any idea of when book #2 will be coming out?  The one about the F's/ later K's & performance stuff?
It will still be a while: I have been knee-deep in 750 engines for about 6 months, mostly because of the first one! It was supposed to help folks build theirs themselves, but some decided to send me their engines instead (an unintended side effect!).
I was wondering about this.  I bought the book... which convinced me to order an ignition unit and a swing-arm rebuild (both of which I'm very impressed with BTW)...  I also lost track of how many questions I've asked you.  I assume I'm not the only one.  I'm not sure how you have the time to do all this.... I'm just happy you're doing it.  Such an incredible contribution towards helping others keep these bikes running.
Oh... and here's one more question:
In your book you mention some of the early bikes are missing drain holes in the frame.  Mine is an older (1975 F) one, and I can't find the drain holes as you described.  I'm going to send the frame out to be powder coated, and I figure I should drill these before I do.
I attached a picture on the bottom front part of my frame - this is where I should see the holes... correct?
I do see whole in the middle center brace (picture also attached), but that's the only one I could find.
Should I drill the holes as you describe in your book?... or am I looking in the wrong place?
Thanks!
« Last Edit: July 12, 2012, 07:38:37 PM by Kickstart »
- Chris
75' CB750F Blue (Project)
No Reserve Racing #171 AHRMA
Re: My CB750 book, by Hondaman. 18% off until July 13!
« Reply #279 on: July 12, 2012, 08:22:56 PM »
Thanks!
You're looking in the right place, all right! They didn't drill ANY holes after the K4, and many frames have rusted from it. You'll have to add one on each side.
I think that the pressures of costs on the later 750 sales efforts just made them start cutting out some steps. By the time of the first 750F bikes (1975-ish), there were many competing bikes for the touring market, which caused sales to slow and price pressures to rise. That's one of the reasons the later bikes wear out so much faster than the earlier ones, but this can all be 'fixed', as noted through the book.
Thanks for getting one!
Offline terza96
« Reply #280 on: July 18, 2012, 08:59:22 PM »
Hello Hondaman, I just started my restoration project on CB 750 1972 under the tread First try restoration and I need your book .Where I should order it with you or Lulu ?
thanks
Zoran
« Reply #281 on: July 18, 2012, 09:34:56 PM »
thanks
Zoran
Either way is fine, "Z", but I think you'll save some postage (to Canada) if you get it from Lulu directly. By the 1st class I must use, the Canada postage is something like $10, while Lulu gets Publisher's Rate, like $5 or so.
This might sound odd, but if you wait maybe a week or so, they may have another special soon. They have been popping these 10% to 20% specials up all summer this year. They only last a few days, but I usually come and edit this post so it pops up as 'new' on the forums for everyone to nab them. ;)
Offline terza96
« Reply #282 on: July 19, 2012, 09:03:33 AM »
Thank you Hondaman i''l wait as you said.
Just please let me now ,I already stared with project and waiting for book scared to open lower case without it .One of piston rods seized on crank ,not moving ?
Z
Offline Radam
  • taco racer
« Reply #283 on: July 19, 2012, 02:45:02 PM »
I'm also interested next time it goes on sale. I missed it by one day last time. Shipping to Oz is probably steep too.
« Reply #284 on: July 19, 2012, 09:56:14 PM »
Yeah, it is for me: I think it is $24!
Offline Kickstart
Re: My CB750 book, by Hondaman. 20% off until July 27!
« Reply #285 on: August 04, 2012, 10:18:10 PM »
Hi Mark,
Working through my rebuild with your book.  I have the cases split and I said to myself, why not do the gear polishing performance improvement.
I've attached a pic... is this pretty much what you were talking about? (I removed the top half of the case so you could see the gears.  That will obviously be going back on before I start).
I assume I should use the fine lapping compound... or should I start with the coarse and then finish with the fine?
Do I also put the polishing compound on the primary gear?
Also, how long is a long while?  :)    Is that about 1-2 hours total turning time on each gear - so about 5-10 hours turning time altogether.  Or, put another way, how do I know when I'm done?
Thanks!
Chris
- Chris
« Reply #286 on: August 04, 2012, 10:35:32 PM »
Ah, that brings back memories of keeping warm on cold Illinois winter nights...sweating, actually. I can still feel the ache in my right shoulder from the turning... But, what else can you do with your bike in Illinois in January and February?
Your setup looks good, if you bolt on the other case so all the gears get involved. I used fine compound on the ones I did, because in those days I wasn't sure of what I was doing, yet. If you look closely at the teeth on the gears, you will see the tiny hog-cut steps: you want to knock the edges off, at least. On the road, this takes about 20k miles of touring riding.
I would turn a while, then separate the cases to make sure the compound doesn't work its way into the bronze bushings, repeat until bored. It only takes a couple of the 8mm bolts to hold the case together well enough for this process.
Some time ago, someone on this forum found a way to make an electric motor setup for this process. I think it only took minutes to accomplish, and I also think he said it took many hours to clean the fast-moving compound out of everywhere it went! Keep an eye on that stuff: it doesn't take much of it in a bronze bushing to tear things up.
Offline jukku
  • Happy with my Hondamatic
Re: My CB750 book, by Hondaman. 25% off until August 24th!
« Reply #287 on: August 30, 2012, 11:46:49 PM »
My CB750 book, Honda shopmanual and Honda sparepartslist, I think I will manage ;-)
My CB750 book is a very priceworthy book.
Offline Radam
  • taco racer
« Reply #288 on: August 31, 2012, 06:31:12 PM »
My copy of the book came in a few days ago! Best birthday present ever!
Offline USCG_C130
Re: My CB750 book, by Hondaman. 20% off until September 7th!
« Reply #289 on: September 04, 2012, 07:57:44 AM »
thank you so much for putting the 20% code up, i have been checking lulu everyday and woke up to a great surprise, i just submitted my order and cant wait for your bookto get here, and for this damn florida weather to cool down so i can get back out in my garage!! and finish my project. i am embarrassed to say that over the summer florida it has been neglected!! Thanks again
« Last Edit: September 05, 2012, 08:47:31 AM by USCG_C130 »
Offline VTCBike750
« Reply #290 on: September 04, 2012, 02:42:56 PM »
USCG, your gonna love this book
-Adam
1972 CB750 (current project)
http://forums.sohc4.net/index.php?topic=87951.0
Offline terza96
« Reply #291 on: September 05, 2012, 09:19:06 PM »
Hi Hondaman ,
I try to place an order for your book on Lulu site but it don't show any discount ?
Maybe I not doing something wright ?
Thanks
« Reply #292 on: September 06, 2012, 12:07:37 AM »
Hi Hondaman ,
Thanks
I just looked at www.lulu.com, and they still show the code on their main page, good until September 7. It should work OK. When you go to check out, at the bottom of the screen(s) you will see a place where they ask for a "promo code" or "discount code", just type it in right there. When you go to the next page, it shows up the discount.
Sometimes their website acts strangely, slowly, and other times it moves right along. I think they get a LOT of traffic during these specials.
Offline terza96
« Reply #293 on: September 06, 2012, 08:25:04 AM »
Thank you ,
but i am not able to find that promotional code ?I found that field "Coupon code "on the screen but what to type it in ?
When I put 20 % it said the code is not valid .Browsing a Lulu site can't find the code to put in the field .
Zoran
« Reply #294 on: September 06, 2012, 10:23:10 PM »
Thank you ,
Zoran
Try these steps, Zoran - before Friday 9/7 at 11:59 PM, though (that's when the sale ends):
1. Go to www.lulu.com
2. At the top of the page, use SEARCH to find: My CB750 Book . (I recommend the long-lasting hardcover version).
3. When the book appears, click "Add To Cart".
4. When the next page appears, there is a little window that says "COUPON", type in the code there. The code is:  CITHARA20
5. The page will change to show the discounted price then.
I just tried this, and it worked OK. If your computer can't ''see' some of the items, maybe try a different browser (like Firefox or Mozilla?). Sometimes Microsoft's Internet Explorer does strange things...
Offline terza96
« Reply #295 on: September 07, 2012, 09:05:52 AM »
Thank s man
Thats what I needed ,that code . 8)
Ordered already,work as a charm with discount too !
Can't wait to get a book .
Thank you Hondaman again
Offline Oakleyguy
  • Sir Renton
  • Engineerd
« Reply #296 on: September 10, 2012, 02:45:54 PM »
Well dang! I'm having the same problems in both Chrome and Firefox!
Edit:
Damn, just saw the note about the Sale ending on the 7th.
'79 400T
K2
F0
Offline terza96
« Reply #297 on: September 10, 2012, 07:41:26 PM »
Thank you ,
Zoran
Do as it said  maybe it's still on .Good luck
« Reply #298 on: September 10, 2012, 10:09:58 PM »
Edit:
Hang in there: they seem to put on sales every 4 weeks or so, for about 3-5 days at a time. They e-mail me, so I jump right over here and post it when they do. Sometimes they sell them for less than I can buy them: that's when I buy my copies. :)
Offline terza96
« Reply #299 on: September 13, 2012, 11:02:16 AM »
Got a book today , very nice ,just took a quick look .
Thanks
