Author Topic: My CB750 Book and CB500/CB550 Book, by Hondaman: a 15% discount thru 11/14/25!  (Read 299853 times)
0 Members and 14 Guests are viewing this topic.
Re: My CB750 book, by Hondaman: 10% Discount during December.
« Reply #150 on: December 17, 2010, 09:58:57 PM »
Hi Mark, I think I may have found an error in your book. While measuring my (F3) cam today I got consistent exhaust lift values of 7.50-7.55mm. Every other source I have (Honda, Clymer, Haynes) claims 7.43-7.52 mm. Your book says 7.06-7.26mm on page II-3.
Your values for inlet lift (7.64-8.00) is a lot closer to my measurements (7.99-8.04) and Honda's values (7.93-8.02), also copied by Clymer and Haynes, and the same for your clearance values.
Is the F cam just off that much from the K0-K8 cams? Or is it an error in your book? It could be my fault too, but I'm fairly decent with a calliper, and even if there was measurement error on my part, it'd be cancelled out by occurring in both measurements anyway, assuming a consistent measuring bias [ (y+x) - (y'+x) = y-y' ].
First (hopefully not to avoid the point, or sound defensive...), this book was written more about getting these 35+-year-old bikes back on the road in a reliable condition than it was about making them into a high-perf ride: the latter is more for the upcoming book, "750 Performance" (or whatever it ends up being called  :D ).
The cams quoted in this first book are specifically the K2-K6 cams, empirically derived from actual measurements in the 1970-1975 era. There are some differences in the cams made after 1976. Also, the numbers I have in that "Inspection" chapter are my averaging, from engines with more than (typically) 20,000 miles on the clock, which still run (ran) well, but were torn down for other reasons. Even my old K0/K1 manual shows the spec you're citing (about 7.5mm), but I seldom found that much lift on the cams I measured, even on new engines "in the day". The K0/K1, with the HM300 pipes, had more like the 7.5mm exhaust lift: the HM341 pipes needed less because of the restriction increase (or so it appeared, at the K2 era). If you had a K1 cam in a set of HM341 pipes, the sparkplugs would gas foul very quickly: some of our frankenbikes at SOHC4.net show this plainly when someone drops a K1 engine into a K4 frame, or that sort of thing.
Beginning in late '76 production, the cams changed in several ways. The casting marks on the cams roughly tell the story: there is an "R" number cast on the rough camshaft that declares the mold it came from. The ones with numbers of "R6" and earlier are generally considered to be the "early" K cams. The 1977 and later era had 2 distinct cams: one was the F1/K7/K8 cam and the other was the F2/F3 cam. I don't have accurate specs for the differences between these myself (as I did not keep the kind of notes on them like I did on the earlier bikes), but the ones I have measured show more lift and slightly more duration, on the F2/F3 cam, than on the other late (K7/K8) cam. Both of these post-1976 cams have lobes that open 5 degrees later than the earlier cams did (for emissions reasons): if you insert one of these cams into an early engine, the midrange power falls a little flat and the top end perks up. Vice-versa, too, with swapping cams the other way.
All this said, the cam lift lift varied widely (wildly?) in production of the K0-K6, as did the timing. One example: on several K3 bikes I measured in early summer of 1973, I got 3 different valve openings on each engine (measuring at the intake valves of #1, #2, and #4, as the fuel petcock was in the way of #3), spanning more than 3 degrees between the intake openings on any one bike (and not the same between the bikes). Likewise, the lift (as measured by indicating from the top of the rocker, though the valve cap hole) varied more than 0.0050" on these cylinders on any given engine, none of which had 1000 miles on them. Honda never seemed to be much concerned with this accuracy(?). The worst examples of this type came from "new factory" bikes, where there seemed to be a real scramble to make enough machines in those days. But, it didn't seem to make that much difference in the way the bikes ran, either, until one tried to reach 100+ MPH.
Generally, the lift figures of 7.8 to 8.0mm were 'normal' for the inlet and 7.1 to 7.3mm for the exhaust side on the K2-K6, despite Honda's quoted specs. And, they actually varied that much on the bikes I measured.  :o
Offline wohali
  • What, me worry?
  • Don Pardo, tell 'em what they've won!
« Reply #151 on: December 19, 2010, 09:47:20 PM »
Mark - again, I am in your debt. I was in no way on the offensive! :) I only thought that, maybe, a typo had slipped through the sieve. I've learned so much from the book that I'm surprised when something I read doesn't match what's in front of me! In fact, such is the respect I have for your work that I spent a good 2-3 days questioning my measurements, retaking them with different techniques and callipers.
Thanks for confirming that the "F" cams are different. My F3's cam seems to be stamped "R1", for what it's worth. I'll continue to take as accurate measurements as I can with the tools I have and post them in my build thread. Hope they're helpful to you for the new book.
Thanks again!
« Reply #152 on: December 20, 2010, 09:56:32 PM »
Thanks again!
That lobe on the left confirms the shape of the "F2/3" cam: it's the real article. That "stamping" mark is interesting: all the examples I have show a raised cast number, not inset like yours. Could I beg a clearer picture of that marking from you?
We all had a post discussion about this around 2006 or 2007, where a number of riders showed "R1" and "R3" cams from virgin "F" engines they had opened up, while the bulk of them were "R10" and higher markings. We're still trying to sort that out: maybe I'll try to revive that thread (it probably doesn't belong in here...) and see what we can find.
Offline 73nancy
« Reply #153 on: December 25, 2010, 10:51:01 AM »
just got you book for christmas from my rents.. spent the last two hours skiming everything taking down notes on what will help me get my bike finally done so i can ride it again.. im glad you wrote it the way you did very easy to follow like im just having a conversation with you.
one section i liked the most was on the begining of the electrical where you state what the main colored wires do. made it simple to think about the bikes wiring. the bold letters break it up nice.
k1 cb750 cafe racer (aka Helter Skelter)
k6 cb750 stock daily rider project
k3 cb750 race bike 911 big bore, alum rods, 13:1, race cam other goodies
Offline tango911
« Reply #154 on: December 28, 2010, 07:21:55 AM »
im sure ill love the book and its well worth it, but why was i taxed when purchasing on the web?
CURRENT STABLE:
1969 Honda Dream 305 (black)
1974 Mach III kawi 500 smoker
K2 (project)
K2 Original fixer up
K0 original fixer up
2006 CRF250R
Offline Prospect
« Reply #155 on: December 28, 2010, 05:37:19 PM »
I got the hardcover for Christmas from my wife. Wow!  Incredible detail and I really enjoyed the torque moment theory of the drive chain.
Current Bikes
1969 CB750  Sandcast #256
1971 CB750K1
1972 CB750K1
1975 CB400F
1975 GL1000 Goldwing
1954 Harley Davidson Panhead
1957 Harley Davidson Panhead
Toronto Canada
Offline tango911
« Reply #156 on: December 28, 2010, 07:38:41 PM »
just purchased mine, cant wait to check it out!!
CURRENT STABLE:
K2 (project)
2006 CRF250R
Offline CrankyOldGuy
  • Wish I was a
« Reply #157 on: December 30, 2010, 04:49:26 PM »
Mark,
I am lost for words.  I wish your book had been around 40 years ago.  After putting my K1 engine back together 35+ years ago I am actually amazed after reading your book that it actually ran and ran well :)
Just one question.  Did your wife proofread your book?  The part about doing the final cleaning of the crankcase halves in the dishwasher and drying them in the oven for 2 hours would not fly at my house, unless the Mrs. was away for a day or so  ::).
BTW I ordered it from Lulu on Dec 14th, it was shipped on Dec 21st, and landed at my door (Atlantic Canada) today Dec 30th.  Not bad for shipping by ground, the Christmas season and having to pass through customs.
Thanks so much.  I will find your book very useful.  I will probably have to buy a paperback copy to use in the shop as the hard copy is top quality and will reside in my bookcase.
Harry O.
750 K1 Original Owner
« Reply #158 on: December 30, 2010, 09:50:32 PM »
She's read part of it, but I know she hasn't found that little gem yet. I'll know it when she does!  :D
Well, they do that to me, too, when I buy them, even in 'bulk' (if you can call 10 books at a time 'bulk'). Most online parts retailers tax me, too.  :-\
Offline solo 2
« Reply #159 on: December 31, 2010, 08:52:57 AM »
Hi Mark, do you have soft covers available to ship. LULU doesn't like my address.
You know you've achieved perfection in design, not when you have nothing more to add, but when you have nothing left to take away.
« Reply #160 on: December 31, 2010, 07:51:47 PM »
I do: at the moment I have 3 on hand. They are $83 each, $10.70 shipping by Priority Mail in the big box, or $7 in their (unpadded) envelope, might get scratched up a little, from what I hear, in those envelopes.
This presumes a U.S. address, though: drop me a PM with your address? You can Paypal me, too, if you wish.
Offline wohali
  • What, me worry?
« Reply #161 on: January 02, 2011, 05:32:14 PM »
OK, this time I definitely found an error, though it is minor.
Page II-3, in the body of the 1st paragraph: "Honda states that the maximum bearing clearance in the cam journal can be 0.0083"/0.21mm" - not 0.0083"/0.06mm as stated. The values above the paragraph in the callout are correct.
« Reply #162 on: January 03, 2011, 08:52:35 PM »
Ummm...could this be a misinterpretation? The spec reads:
"-measure with inside calipers in the bearing and with a micrometer on the cam, and subtract to get the difference: 0.0024"-0.0083"/0.06-0.21mm".
What this means is:
the range of the value is either 0.0024"-0.0083" (English) or 0.06-0.21mm (metric).
Maybe the way I typed it is confusing?
Offline wohali
  • What, me worry?
« Reply #163 on: January 04, 2011, 07:47:05 AM »
What this means is:
No no, the spec is completely clear. The typo is in the body of the text below the spec.
In the text, you use the maximum value for inches - 0.0083", which makes sense. You don't want the journal clearance larger than the maximum value. However the maximum value you list in the text only (not the spec!) is 0.06mm, the minimum value of your range. A minimum value in the sentence doesn't make sense. Why would the maximum journal clearance be 0.06mm if you use metric but 0.0083 if you use SAE measurements? :) It should say 0.21mm in that sentence, which would match the spec.
« Reply #164 on: January 04, 2011, 11:21:41 PM »
What this means is:
Oh, I see!  :o  Yep, you're right: the spec is right, my musings below that has the error.
Do I feel a Fourth Printing coming on? These things bug the heck out of me... :-[
Offline wohali
  • What, me worry?
« Reply #165 on: January 05, 2011, 03:39:40 PM »
Hondaman and I chatted in private message and I indeed have found another typo:
Page II-6: spec should read "Shaft-to-rocker-tower clearance:" (insert word tower).
Posting not to embarrass anyone, but to make sure that everyone knows...I got this confused with the next section (Rocker arm-to-shaft clearance, page II-7) and had asked in PM for confirmation.
Offline RSchaefer
Re: My CB750 book, by Hondaman: 10% Discount during January.
« Reply #166 on: January 18, 2011, 08:08:37 AM »
Hondaman I am restoring a '75 CB750F and looking for a good book to get me started.  I am a reasonable wrench, have a paperback Clymer book last printed in '92 covering CB750 SOHC Fours - 1969-1978.  I have downloaded all or most of the parts manual, service manual, etc. from the forum.
I think I am lucky in that the candy blue sapphire is mostly stock and I think only has 800 miles on it.  It has set idle for probably 30 years.  I acquired it about 15 years ago, cleaned the carbs of significant varnish and got it running briefly.  I used to own a '69 CB750 and did all my own work as there were few Honda mechanics trained on the bike in '69 - '70.  I worked in a Honda shop during high school in '64 - '65.
I am looking to basically restore to stock condition but upgrade when reasonable to latest technology for performance, maintenance and safety.  Specifically suspension, ignition and tires.
It seems like your book is the way to go but your emphasis is on the "K."  This may have been asked and answered in this thread but after going several pages into it, I skipped ahead to the last page just to see if it was still available.  So my question - is all your info relevant to the F0, I realize the majority of it would, and what differences, if any, would there be?
Thanks!!
'66 CB77, 305 Superhawk (Project Bike)
'72 CL 175, (Project Bike)
'75 CB750F (Project Bike, Complete)
'05 GL1800 ABS Black Cherry (Current Ride)
'87 GL1200 Wineberry Aspencade
'83 GL1100 Wineberry Aspencade
'76 GL1000 LTD
'75 GL1000 Turquoise
'69 Honda 750cc Gold
'67 Honda 305 Dream Black
'63 Honda S90 Black
'61 Honda 50 Red
GWRRA #000008
VJMC Member
bk2blak
« Reply #167 on: January 18, 2011, 04:54:47 PM »
Hey Hondaman, Is this offer still good? I am intersted in a signed copy. Thanks, Dave
« Reply #168 on: January 19, 2011, 07:01:40 AM »
My signed copies are a little less expensive, since I buy them 5 at a time to get a discount. The hardcovers are $93, paperbacks $83, shipping is $10.70 from here (Priority Mail, lots of packing inside to protect them from scratches). Check the first post above for how to Paypal or send funds.  ;)
« Reply #169 on: January 19, 2011, 07:08:24 AM »
Thanks!!
The F0/F1 shared most of even its wiring with the K5/K6, except the "safety module" was changed to a simple diode for the clutch/neutral switch. The engines look identical inside until you count the 1st & 2nd gear teeth, and notice the top plate on the clutch has slanted corks - and the center steel plate is two, sandwiched together. The cam and spark advancer have different specs, but that makes no difference when you're working on them. The "F" bikes all came with 10k ohm sparkplug caps, while the "K" bikes had 7500 ohm (factory), replaced with 5k ohm today. Everything else about the F0/F1 is only cosmetically different from the "K" series. The carbs, if yours has the "7A" or "07" body type, have a #27301 needle in place of the earlier #27201. Internally, that's all that changed besides the piston dome height for the higher CR. The head is, of course, different, but the measurement methods are still the same.  ;)
Offline Eydugstr
« Reply #170 on: January 23, 2011, 01:55:18 PM »
Just got a copy of this book from Lulu.com - thanks for going to all the effort in the engine breakdown section.  Tons of great info!
Offline theriddler
  • 1976 CB750F1
« Reply #171 on: January 28, 2011, 02:28:29 AM »
An amazing book! It's popularity is testament to the effort that's gone into it... I feel a mixture of excitement (renewed interest in getting my F1 up to as original condition...) and trepidation (not sure I'm up to the standard of work as shown...), well we'll see... coming from my background (toolmaker, ships engineer, special purpose machine design), hopefully I'll be able to do the bike justice!!! ??? 8)...anyway I really just wanted to say thanks and that this forum is great!
« Reply #172 on: January 30, 2011, 09:11:55 AM »
If you're a toolmaker, just look to the book for the format of the assemblies (in the Reassembly chapters) and you'll be fine. The machining details are already a part of your life!  :D
Offline CB750faces.com (Lecram)
  • CB750faces.com
    • Buy High Quality Honda gauge parts online!
Re: My CB750 book, by Hondaman: 20% Discount Feb. 2-3 only!
« Reply #173 on: February 03, 2011, 06:28:02 AM »
Just ordered one at Lulu with discount. Price for Netherlands in Euros, incl shipping: €69.17
  • CB750faces.com
Re: My CB750 book, by Hondaman: 20% Discount until Feb. 21 @ 11:59PM!
« Reply #174 on: February 22, 2011, 12:19:23 AM »
I recevied the book yesterday and have to say that I am very happy with it. Great book, clear pics, good info. Recommended
