Author Topic: Post rebuild Leak check list  (Read 781 times)
Offline 76CB5WI
  • CHRIS
« on: February 19, 2010, 10:11:34 AM »
Leaky list all these had to be attended to after my recent project and caused me some
grief. Heres what popped up.
Exhaust flanges
Petcock fastener screws
Transmission cover
Floatbowl gasket
Oil tank line fitting-
 at tank get this tight before you reassemble or
you will be dissassembling or finding a very special and ancient wrench to do
the job of tightening. New crush washer recommended.
Carb overflows....need to be 3/16  ID pvc fuel line Not rubber vacuum line.
Carb drain gaskets
Oil tank vent
Crankcase vent-
 notice which is which I thought I had a blowby problem
after rebuild turned out to be the oil tank overflow dumping out excess oil
yaa!y and thank God.
« Last Edit: February 19, 2010, 10:18:38 AM by 76cb5WI »
87 FJ1200
72 CB750
76 CB550
