Author Topic: carb cleaning question (warning: dummy inside)  (Read 5453 times)
Offline the architect
Re: carb cleaning question (warning: dummy inside)
« Reply #25 on: February 18, 2010, 08:42:40 AM »
Thanks for all the input!
I'm pretty good about laying things out in the order I disassemble them and keeping track of how things go back together.  I'm feeling much less intimidated than I was.  I'm hoping to tackle it this weekend, so I'll update my adventure soon.
There doesn't seem to be any varnish on the slides, and the seem to function smoothly.  The orifice / opening when closed varies a bit from carb to carb, so I'm thinking a re-sync will be in order.  I don't have a set of vacuum gauges or the mercury sync tool, but I have a nearby vintage bike shop that said they could do the sync for $40 - 50.
It's possible that a PO replaced some or all of the seals and o-rings.  If they don't appear dry and brittle, is it same to assume they can be reused?
Rider no. 83 on the 2013 SOHC/4 Honda World Tour
Rider no. 228 on the 2012 SOHC/4 Honda World Tour
Rider no. 70 on the 2011 SOHC/4 Honda World Tour
my '75 CB750 cafe build photo documentary:  looking for the Lone Stars is like playing Where's Waldo -- enjoy.
http://www.flickr.com/photos/34828040@N05/sets/72157615892537535/
CB350 twin, rigid meat grinder:
http://www.flickr.com/photos/34828040@N05/sets/72157627005176764/
Blip Workshop
http://www.blipworkshop.com
http://www.facebook.com/blipworkshop
Offline Duke McDukiedook
  • Space Force 6 Star General
« Reply #26 on: February 18, 2010, 09:06:31 AM »
Assume they didn't and order the rebuild sets.
If you pulled them out you might as well change your gaskets and seals while they are apart and out.
The Keyster kits will work fine for your bike, just don't use the needles if you want to change everything out. As long as the jets are not worn out or deteriorated or gunked to hell or not stock you shouldn't have to change those either.
« Last Edit: February 18, 2010, 09:08:44 AM by Dukiedook »
Offline Sporkfly
  • The frosty rider
  • Mmm, Guinness
« Reply #27 on: February 18, 2010, 09:08:00 AM »
I would replace all seals regardless of appearance.
1977 CB550K
1979 CX500
1976 Suzuki GT500 Titan
Offline Colonel
  • 750K5
« Reply #28 on: February 18, 2010, 12:42:42 PM »
I do agree with previous posts.
Do not let the carbs intimidate you.
I have a CB 750 K5 and this is my first classic bike; hence my very first carb cleaning job has been don on this one...
I researched the forum and used http://www.salocal.com/sohc/tech/carb/carb.htm
If you are organized this is pretty simple and once again, you have a lot of valuable help on this forum... especially around the carburetor topic.
Offline Bodi
« Reply #29 on: February 18, 2010, 04:58:59 PM »
I would avoid Berryman dipping a complete rack, as you imagine the stuff would attack any rubber parts. This is very nasty stuff! Simple green does a fairly good job and doesn't eat plastic or rubber.
Berrymans is much better at cleaning really gunked up carbs but removing plastic and rubber parts is imperative. With it and a bit (OK, a lot!) of elbow grease working with toothbrushes and such you can get the carbs looking almost new - the casting metal never comes up as bright as new but they look really great. If you're going for a concours restore then disassembling the individual carbs and dipping the castings, plus replating all the steel throttle parts, is de rigeur. To clean up a rack so they work, external cleaning is a luxury - you need to clean the insides of the carbs: all the hidden passages and the emulsion tubes are the key parts to go after. You will likely need new float valves and gaskets for the bowls and caps. A bit of oil on the throttle shaft "bearings" and such should get you going with no problems.
