Author Topic: compression test question  (Read 3513 times)
Offline fergie
« on: April 24, 2005, 05:08:05 PM »
I recently picked up a 350f.I checked the compression on each cylinder and they all read just below 125 psi. however it took me about 20 or so kicks (on each cylinder)to get it up there.I cant check it with the starter turning the engine over because it does not work.My question is this: is my 125psi reading acurate or am I just falsly getting my hopes up.thanks, Fergie.
The most interesting man in the world
Offline Bob Wessner
  • "Carbs Suck!"
Re: compression test question
« Reply #1 on: April 24, 2005, 05:42:49 PM »
Will it start with the kick starter? If so, you should run and warm the engine first.
Offline Einyodeler
  • Midnight bugs taste best!!!
« Reply #2 on: April 24, 2005, 06:28:06 PM »
It also depends on the type of compression gauge tool that you use.I bought a gauge that had a hose about 18" long between the gauge and nipple and got very low readings,then tried a friends` tester that had the gauge attached to the nipple without the long hose and lo and behold my readings jumped by 40 to 50 lbs.The closer the gauge to the nipple the more accurate the reading.  ;)
1972 CB500 - 1973 CB500 - 1974 CB550K - 1975 CB550F - 1975 CB750F - 1976 CJ360 - 1983 CR480 - 1970 BSA A65T Thunderbolt
Download Motorcycle Shop Manuals here: http://forums.sohc4.net/index.php?topic=17788.0
Offline Dennis
« Reply #3 on: April 24, 2005, 07:02:45 PM »
Fergie,
Did you have the throttle wide open when you checked?
Yodeler.
Sort of, it depends on the gauge and where they put a "check valve" in the assembly.
There should be a valve right at the threaded fitting. If it is at the gauge with a long hose what you noticed will occur.
Offline fergie
« Reply #4 on: April 24, 2005, 07:28:44 PM »
my gauge has the 12" hose .fergie
Offline Dennis
« Reply #5 on: April 24, 2005, 07:51:57 PM »
That only matters if the check valve is up by the gauge. Can you see a valve (like you would see for filling a tire) at the fitting where you screw it into the spark plug opening. If you answer yes, then the long hose has minimal effect.
Someone posted a link to a long dissertation (including references to gas laws and other stuff that I vaguely remember from freshman physics) on this subject on the old site but I have no idea how to find it.
Offline fergie
« Reply #6 on: April 24, 2005, 08:47:55 PM »
there are two release valves one at the fitting and one at the gauge.fergie.
Offline pmpski_1
  • Beast V and Beast I
    • My CB550 related blog on MSN Spaces
« Reply #7 on: April 24, 2005, 09:03:41 PM »
So what about the reading if you kick it 20 times? If the engine doesn't run and you're trying to see if you have bad compression, should you keep kicking it until it gets to the point where it doesn't go any higher? Or should you just kick it a couple of times?
Thanks,
Brian
Beast   I: 1974 CB550K
Beast IV: 1976 Chevy Blazer
Beast  V: 2003 Buell XB9S
Offline heffay
« Reply #8 on: April 24, 2005, 10:14:53 PM »
Fergie~
i've always been told (by my instructors and by my compression test)  your highest reading is your best... if you consistently get a high reading (no matter whether it takes 20 kickes each time) or not!  you should trust your equipment... YOU HAVE TO GET A CONTROL!!!!!... meaning, get your best test... and work from there.
Offline heffay
« Reply #9 on: April 24, 2005, 10:17:22 PM »
p.s.  dont give a crap about the long extensions etc.... if you have quality tools you will get the same readings.
x2qwk4ux
« Reply #10 on: April 25, 2005, 08:40:20 AM »
I agree with the warmup procedure...then once it's warm, remove all plugs before doing the test so the engine spins more freely.  A quick way to see if your rings are shot, is add a teaspoon of motor oil into the cylinder with a turkey-baster & repeat the compression test.  If it goes up a LOT, you might want to consider re-ringing & honing.  125 sounds like it's in the mid-to-low range of acceptable to me...and if it don't smoke, just RIDE it.  I'm thinking you should would have 140-175 if everything was new.  Might also want to try adjusting those valves before the test.
Josh
Offline fergie
« Reply #11 on: April 25, 2005, 05:10:02 PM »
Thanks for the advice guys.Fergie
