Author Topic: cb750 carb rebuild questions  (Read 8287 times)
jscro73
« on: February 19, 2010, 06:45:23 AM »
looking to rebuild my carbs and i'm wondering if i should replace the jets and needle valve, or if they generally dont wear out.
i see kits that replace everything for around $70-$80, and then i see oem kits that just replace the gaskets, but are honda service kits for the same price without new jets, etc.
what do you guys think i should do? go for the whole after market kit, or go with the honda service parts and dont worry about the jets?
thanks, Jason
Offline Bowswell
  • CB750K1,CB750 K4,CB350F,CB400t1,meanstreak
Re: cb750 carb rebuild questions
« Reply #1 on: February 19, 2010, 06:53:41 AM »
jscro73
« Reply #2 on: February 19, 2010, 06:59:59 AM »
i like that. thanks!
Offline 76CB5WI
  • CHRIS
« Reply #3 on: February 19, 2010, 09:39:23 AM »
Dip those carb bodies and do the orings between each carb too.
Nock the emulsion tubes out and dip them too if your up to it.
87 FJ1200
72 CB750
76 CB550
Offline SOHC Digger
  • I'm not an
« Reply #4 on: February 19, 2010, 02:33:54 PM »
What style carbs are they?
Offline Gordon
  • 750K1, 550K2
« Reply #5 on: February 19, 2010, 02:40:09 PM »
The brass parts don't generally wear out.  I'd stick with the stock ones if given the choice.  Of course the gaskets and o-rings should be replaced with new ones.
« Reply #6 on: February 19, 2010, 07:14:54 PM »
thanks, Jason
These carbs don't wear out very much. At 138,000 miles on mine, the needle jets are slightly oval: turning them 180 degrees in their holes restored the proper mix again. The needles wear a hair, but not so much as to need replacement, ever. Most of the time the parts get damaged, bent, or something along those lines, then need replacement. But, 99% of the time a careful, thorough cleaning will bring the parts back to 100% performance.
The float valves are probably the most-damaged parts inside the carbs (except for possibly the early carbs' brass floats) from a combination of water and MTBE-enhanced fuels of the 1980s. Once in a while those little valves (and maybe the seats) will need replacement: the test is to connect to a full fuel tank, remove the float bowl cover, then lift the float until it just barely closes the valve, but has not closed the spring plunger. It should seal and stop the fuel. If it does not, it is leaking a little and should probably be replaced.
But again: my carbs still have original float valves and needles, at 138,000 miles...  ;)
Link to website: SOHC4shop.com  (Note: no longer at www.SOHC4shop.com, moved off WWW. in 2024).
