Author Topic: Brake Fluid mixing???  (Read 1387 times)
Offline Johnie
« on: February 20, 2010, 03:10:45 PM »
K4 - Can I mix DOT 3 with DOT 4 without causing a problem? Or better yet, bleed the brakes down and then add DOT 4 to the master and run that through without causing a problem with anything? I have DOT 3 in there now as that is what the PO said he uses. Was thinking about DOT 4 since it does not collect moisture so readily. I was also thinking about changing over the KO & K1...
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline BeSeeingYou
Re: Brake Fluid mixing???
« Reply #1 on: February 20, 2010, 04:21:25 PM »
I have a bottle of what is labeled DOT 3-4 so they are compatible.  I believe DOT 4 is a premium version of DOT 3 with a higher boiling point and absorbs moisture less.  Just don't mix with DOT 5.  I would still drain the old stuff out if you don't know how long it has been in there.
« Last Edit: February 20, 2010, 04:26:38 PM by srust58 »
Offline Bill/BentON Racing
    • BentON Racing
« Reply #2 on: February 20, 2010, 04:27:25 PM »
They 3 & 4 readily mix,if it calls for 3 ok for 4,if it calls for 4 not ok to add 3.It will still mix and work,but not to the specs of Dot 4.Dot 4 has higher wet and dry boiling temps.Bill
BentON Racing Website
BentON Racing Facebook
Offline Johnie
« Reply #3 on: February 20, 2010, 04:49:37 PM »
Yah, I flushed the KO, K1 & K4 with new DOT 3 every couple months during the riding season since these are OEM systems that have never been rebuilt. I heard the good on the DOT 4 which is why I was thinking about changing it over. So is the DOT 4 a synthetic or not? If so, will it reek havoc with my OEM seals?
Oshkosh, WI  USA
Offline dusterdude
« Reply #4 on: February 20, 2010, 06:40:52 PM »
dot 4 is not synthetic,only dot 5 is.you can tell whether or not you have dot 5 because 5 is purple in color
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline jkot55
  • Wingman55
« Reply #5 on: February 20, 2010, 06:58:23 PM »
I do not think that you can use DOT4 in these old bikes.  Not sure that the seals will like it.  I would not mix them either.  I have heard many suggest that it is o.k. and to be honest I have no personal experience with mixing.  It just seems that there is really nothing significant to gain from mixing or converting to something other then what it calls for.
When I ride my CB750 I'm a teenager again
Offline HondanutRider
« Reply #6 on: February 21, 2010, 06:47:23 AM »
From the Honda Common Service Manual (published in 1988):
Offline Johnie
« Reply #7 on: February 21, 2010, 07:10:03 AM »
Excellent info in the service bulletin there.
Thanks...
Oshkosh, WI  USA
