Author Topic: Pros and Cons: Holley vs Edelbrock (Carter) Carburetors?  (Read 16055 times)
Offline bill440cars
  • Feeling More & More,
  • Tryin' To Slow Down "Time"!
« on: February 21, 2010, 07:01:12 AM »
     Which would YOU prefer and WHY?
           Seems to ME like the Holley responds quicker, but is pretty complicated (compared to the Edelbrock) to setup for any particular engine.
      Like to hear what you all have to say on the matter from YOUR experience and/or what YOU all have seen. :)
                                  Thank you, Bill ;)
Member # 1969
Offline 6pkrunner
Re: Pros and Cons: Holley vs Edelbrock (Carter) Carburetors?
« Reply #1 on: February 21, 2010, 08:10:57 AM »
Oh wow - talk about  kicking, beating, jumping on and punting a hornet's nest. Put on your helmets and duck and cover. You may as well have asked who is the one real God, prove a Honda is better than a Kawasaki, or redhead over brunette.
Just my $0.02 - the Holley has a greater tuning range, will allow greater throttle response and will indeed make more peak HP. The Carter has greater tractability and will forgive more sins against it. And a Carter can go years without being touched - not so with the Holley. As for my experience I've had Mopars for the last 36 years and have run more Holleys and Carter than I can count. The opinions above are from my dealings with them.
Jesus Bill you really don't pull any punches do you? Helmets on!
Offline bill440cars
« Reply #2 on: February 21, 2010, 11:51:23 AM »
           Whoa! I didn't realize that it could be so controversional. I just knew what I had experienced and wondered about leaving well enough alone on the GTX or considering change. I'd had several Carters, but only had 1 Holley before this one.
          Thank you for YOUR input Mike. Now, I huess we'll duck and see what happens next. ;D
Member # 1969
Offline 6pkrunner
« Reply #3 on: February 21, 2010, 12:11:47 PM »
This very topic has been the cause of bannings and quittings on one board at least. And of that fallout only one of 10 possibly more members has returned. Straw that broke the camel's back - maybe, but it was very animated before the thread was deleted and suspensions/quitting handed out.
Offline bill440cars
« Reply #4 on: February 21, 2010, 12:19:54 PM »
           Whoa! Hard to believe things would go THAT far (but, I'm not doubting what you are saying. Just amazed!)
Member # 1969
Offline mark
« Reply #5 on: February 21, 2010, 12:35:38 PM »
I like the fact that there are a gazillion little bits available to tune every system of a Holley just so...
I also like the fact that the Carter has no gaskets "below the waterline".
F you mark...... F you.
Offline domer
« Reply #6 on: February 22, 2010, 08:35:30 AM »
edelbrock carbs are crap. imo. holley is the way to go if your budget minded, if not get a demon and call it a day! my chevelle came with an edelbrock and gave me nothing but hell  (never did figure out what the problem was)... bought a well used holley 750 and most of my problems went away with some time consuming tuning. borrowed a demon 650, and what a #$%*ing difference... god i miss that car...
« Reply #7 on: February 22, 2010, 08:47:40 AM »
Well, IMO, that disqualifies you as an authority or reference.
You were unable to fix your test case of one, and side stepped the problem by replacing the entire unit instead of finding the flaw in your carb (be it damage, dirt, or design, you will never know).
You could have fixed the original problem by replacing the entire car, too.  Oh wait, you did replace the entire car....  ;D ;D ;D
Offline bucky katt
  • i am a pastafarian!
    • facebook
« Reply #8 on: February 22, 2010, 09:21:17 AM »
the edelbrock carb is going to be more trouble free in the long run with no gaskets below fuel level. really easy to change out jets and metering rods too for tuning. i ran a holley on both 5.0 litre motors and the 514 big block i had in the mustang but that car was torn down at the middle and end of racing season here and only did maybe 2000 street miles a year. edelbrock has an 800 cfm carb that would be just right for a street driven 440.  http://www.summitracing.com/parts/EDL-1813/
Mark Twain - Notebook, 1894
Offline wannabridin
  • Patience made me a
  • -Garrett
« Reply #9 on: February 22, 2010, 09:26:50 AM »
i have an edelbrock 600 4v in my 66 mustang 289.  not much performance work, about 225 horse or so.  it's more carb than the motor needs, but i got it for cheap, and it's better than the 2v that was on there!!  i haven't touched the thing in 8 years and it fires right up once a week or so, and she drives and idles very well all the time.  great carb IMO, but i have no experience with holley, so don't take my word for much.  just stating what i do know...
Offline domer
« Reply #10 on: February 22, 2010, 09:33:24 AM »
well i wont lie, replaced the edelbrock cause i could never get it right. yup i gave up. did i know what i was doing? hell no! what i do know is that after trying and trying, i finally listened to the opinions of others who did know what they were doing and went with holley. i rebuilt the edelbrock, which seemed a little easier than the holley but i could never get it right. rebuilt the holley and after some jetting and a/f adjustments i never had a problem.
am i an expert... no. thats just my opinion from my experience. :P
Offline bill440cars
« Reply #11 on: February 22, 2010, 11:04:13 AM »
        Hey, I appreciate ALL of the input here and hope you all realize that I am not trying to start a feud over the two carbs. Only problem I have with the Holley that is on there now, is not the carb itself. it's the cheap choke cable that the P.O. put on there. After you put on the choke, you have to pop the hood and pull it back off! ::) The carb performs well. Now, I have to say that after a buddy told me that the Holleys (in his opinion) were bad about "washing down the cylinders" and THAT THOUGHT is in the back of my mind, everytime I start it up.
        I'm not sure what I'm gonna do. I sure do like the way it revs, when asked to! Comment has been made about whether the 750 Holley was big enough for my 440 or not and it may not be, but it works well AND drinks enough gasoline as it is. ;D
          Thinking about selling the 83' GPZ and see about one of those Keisler 5 or 6 sp trans, to help with the mileage, give the engine a break while cruising down the hwy AND still have the UMP! when I want to feel the Power! Shame I can't make a deal with them and just swap the bike for the trans. ::) I'd even deliver the bike and puickup the trans. ;)
Member # 1969
« Reply #12 on: February 22, 2010, 12:25:10 PM »
well i wont lie,... am i an expert... no. thats just my opinion from my experience. :P
Don't feel bad. The original question simply begged for unsupportable conjecture and vague, meaningless testimonials.  You just took the bait.
Since both Edelbrock/Carter and Holley/clone carbs have been used successfully on thousands (millions) of vehicles, by what metric do you decide if one is better than the other, without even a cursory glance at application, or the application required parameters?
The thread at the outset reminded me of the school yard kids poking at a dog pile, just to see the flies get agitated and buzz around wildly.  You can expect the same level of "conclusive, scientific test results" here, I imagine.
So which is best? Coke or Pepsi? ... A broken right finger or a broken left finger?
Ford or Chevy.
Mopar or Mack?
John Deer or Caterpillar?
Honda or Toyota?
Betty Crocker or Pilsbury?
Trojan or Paradise?
Consumer brand loyalty is really a very stupid concept.  As none of your favorite "trusted" brands have any loyalty to their customer base, and will change their product at the whim of increased profits, even if it means a different selection set of "customers".  (Yup, my old 84 Toyota was a really reliable car without accelerator problems.  My even older 55 Chevy was a great car.  My 89 Chev Camaro is a piece of engineered Sh!T.) Do you think any brand will change back to the old product or product recipe/process to satisfy 100 old customers rather than sell to 10,000 new customers (plus the old ones who can't tell the difference)?
Sigh...
I may have said too much... :-X
Maybe that dog pile is safe to land on again?   ;D ;D
Offline domer
« Reply #13 on: February 22, 2010, 01:10:38 PM »
 :D ha ha :D
Offline mark
« Reply #14 on: February 22, 2010, 03:05:20 PM »
It used to be Coke until that 'New Coke' business. 'Classic' just doesn't cut it.
add an ice cube or three and Coke goes to water instantly.
Pepsi cans are a nice patriotic red, white, and blue.
Coke cans are commie red.
 :P
« Reply #15 on: February 22, 2010, 03:18:33 PM »
So what's this?  The Brit version?
Offline Inigo Montoya
« Reply #16 on: February 22, 2010, 06:48:52 PM »
Funny how he says brand loyalty is stupid but brand hatred seems to work just fine for him. ::)
Online Don R
« Reply #17 on: February 22, 2010, 07:06:07 PM »
I like the AVS carter or Edelbrock, the air valve secondary makes it work on a variety of engines with less tuning. For put it on and forget it, theCarter. For tunability and for horsepower making the Holley is the king. Last year I heard the demons had a falloff in quality, shavings in the carb etc, could be bull, I don't know. I run a quick fuel 1250 dominator style on the race car, it's been great.
 I took an 1850 type 600 holley and put center hung float bowls on it and a secondary plate with removable jets with an air horn to smooth the air entry without milling off the top. It worked so well the guy I loaned it to never gave it back. I had a total of 50 bucks in it.
« Reply #18 on: February 22, 2010, 09:54:38 PM »
Funny how I never said I hated any brands, but you assumed (and claimed) I did.   ::)
What axe have you to grind?
« Reply #19 on: February 23, 2010, 01:09:29 AM »
qjet.
« Reply #20 on: February 23, 2010, 05:08:26 AM »
Ford or Chevy.
Mopar or Mack?
Honda or Toyota?
Trojan or Paradise?
Sigh...
   That would depend on hand dominance Loyd. ;) ;D
« Reply #21 on: February 23, 2010, 06:37:07 AM »
You put your right hands in you pull your right hands out, in out in out shake it all about, you do the coke a cola and you turn around that's what it Holley about. ;D ;D ;D ;D ;D
Sam. ;)
« Reply #22 on: February 23, 2010, 06:49:02 AM »
Sam. ;)
You hitting the hard stuff??  ??? ;)
« Reply #23 on: February 23, 2010, 06:58:55 AM »
Hard at work mate and thinking about home time while eyeing up the nice new cleaner, very dishy. ;D ;D ;D ;D
Sam. ;)
Offline bill440cars
« Reply #24 on: February 23, 2010, 07:18:17 AM »
Sam. ;)
           Sam, YOU definitely have TOO much time on your hands! :D
                                   WAY too much time! ;D
          Take care, Bill ;)
Member # 1969
