you can check spark using your car battery. don't follow the procedure for normal car jumping! just disconnect the motorcycle battery (and might as well take it out and use it as a door stop), disconnect the car battery from the car ( i take mine out) and then connect it to your bike with jumpers. that should allow you to test for spark. good luck.
by the way, your bike looks cool.
