Author Topic: Conversion of rear brake hub- from rigid to cable activated  (Read 15378 times)
Offline Howell
  • Honda the power of dreams
    • CB500 classic racing
Re: Conversion of rear brake hub- from rigid to cable activated
« Reply #25 on: February 24, 2010, 11:46:52 AM »
On our new build CB500 racer , we made also a cable at this way, we bold it on.
« Last Edit: February 24, 2010, 11:48:56 AM by Howell »
You meet the nicest people on a Honda
Offline CPHjimm
« Reply #26 on: February 24, 2010, 12:50:51 PM »
[/quote]
Ha ha! It's from six years of searching like you've been doing Jimmy - no easy route, you gotta do the time  ;)
[/quote]
haha, im sure, guess my 5 years of on_off didnt pay off as good  :'(   ;D ;D
After several hours of thinking (my old brain is hurting ;D ) It should be possible to create a cable opperated 7" twin leading shoe rear brake using both CB160 front and rear components.
You would need the front shoes, leavers and acctuating spindles.
Remove the shoe pivot pin from the rear plate, bush and replace with one of the front acctuating spindles.
Simple ::) ::) ::) or is it.  ;D ;D ;D ;D ;D ;D
Sam, be careful with all that thinking, that can be dangerous!! Well, at least that is what I tell my boss.  :D :D
It seems really nice, will def. check it out.
[/quote]
Yes, these are made up in batches with alloy lever/ pedals sourced from newer Honda models.
KOS
[/quote]
Mark, ill give you a mail tomorrow for more details.
\m/ [(-_-)] \m/
Offline CPHjimm
« Reply #27 on: February 24, 2010, 12:56:31 PM »
That looks good!! hmmm, Getting all confused on which way to go  ??? ???  Ill figure it out
Sam, someone over on your side of the Big Pond used to make replacement plates for the Suzuki 4LS that looked like Ceriani plates. Since I can't afford a full Ceriani 4LS repro, I'd love to find a (used, affordable) set of the side plates to use on this build.  Know of any?   ::)  RR
maybe here?
http://www.menani.it/menani/index.php?id_cat=1&posizione=lista&lingua=&carrello=
not really affordable but nice eye candy in any case :)
WOW... are those hubs made on a virgins inner thighs ;D ;D
\m/ [(-_-)] \m/
Offline derkafer
« Reply #28 on: March 21, 2010, 12:16:42 AM »
What about the source for the brake cable itself? Any ideas there? Id like to buy a new one if I was gonna do this, new cables make me feel warm and fuzzy...  ;D
Offline turboguzzi
« Reply #29 on: March 21, 2010, 07:21:23 AM »
not easy to find off the shef. Try the clutch cable of a manual shift car like say  a subaru, they are pretty sturdy, have a teflon lined outer sleeve, threaded adjuster at the end and if you are lucky, it might be the right length :)
I am using one myself, no idea about part number or such...
TG
Offline CPHjimm
« Reply #30 on: March 22, 2010, 02:51:16 AM »
I bought a Suzuki GT750 rear brake cable on Ebay. haven't done the conversion yet but it got the right lenght. should work
/Jimmy
\m/ [(-_-)] \m/
Offline paulages
  • 1976 cb735
    • DOOMTOWN RIDERS P.R.M.C.
« Reply #31 on: March 23, 2010, 09:32:42 AM »
i used a clutch motorcycle clutch cable and just re-soldered the ferrule and end where i needed it.
paul
SOHC4 member #1050
1974 CB550 (735cc)
1976 CB550 (590cc) road racer
1973 CB750K3
1972 NORTON Commando Combat
1996 KLX650 R
Offline derkafer
« Reply #32 on: March 23, 2010, 12:44:55 PM »
/Jimmy
I wonder if it would be easy to use that cable and the hub from the same bike. Does anyone know if this hub is the right size to fit the CB500?
http://cgi.ebay.com/ebaymotors/Suzuki-GT750-rear-brake-plate-assembly-water-buffalo_W0QQcmdZViewItemQQhashZitem255923fffaQQitemZ160409321466QQptZMotorcyclesQ5fPartsQ5fAccessories
Offline Old Scrambler
« Reply #33 on: March 23, 2010, 04:17:21 PM »
New HONDA rear brake cables are sometimes available from the CB72 and CB77 models as well as the CL72 and CL77 models.  A cheap substitute fjor this ap would be an aftermarket front cable, especially the extended lengths from the ape-hangers and extended tube days. Most come in gray sleeves.
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
Offline kos
    • m3racing.com
« Reply #34 on: March 23, 2010, 05:19:01 PM »
If you guys really want the correct cable for these special applications. Ali you have do do is draw them up and send to Motion Pro here in USA and they will make you any cable you want. New, with newest and best materials made on the planet.
Stay away from soldering, cutting, retro-fitting your super fast racer for safety's sake!
KOS
220...221, whatever it takes.
Offline derkafer
« Reply #35 on: March 25, 2010, 01:08:42 PM »
The only thing I could find in my internet research on the subject is that they are both 180mm drums. That leaves a lot of variables to consider... Anyone have one of these laying around that we can get some measurements from?
