Author Topic: removing spark plug #3 77 550f?!?  (Read 922 times)
Offline 000jeremy
« on: February 24, 2010, 07:10:09 AM »
My deep 18mm socket WILL NOT fit down into the recess where the #3 spark plug sits...and yes, I did remove the little housing where the tach plugs into the head above.  The only other option seems to be to remove the head?  To change a spark plug?  I know this can not be correct.  Do I need a special socket for this?  Mine fits just fine onto the other 3 plugs.
Thanks in advance,
Jeremy
Offline JBMorse
    • Travel Blog
Re: removing spark plug #3 77 550f?!?
« Reply #1 on: February 24, 2010, 07:22:57 AM »
The only thing that works for me is the honda tool.  Check the parts fiche for it.  It's really deep.  I bought a reproduction here: http://www.crc2onlinecatalog.com/Index_Main_Frame.htm
You'll also find used ones on ebay.
1971 CB500K
Offline Gordon
  • 750K1, 550K2
« Reply #2 on: February 24, 2010, 08:03:03 AM »
Yep.  You either need the too -kit plug wrench or a thin-walled, deep 18mm socket.  I got one from an auto parts store that fits perfectly.
