SOHC/4 Owners Club Forums
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
The
SOHC/4 World Tour
is in under way.
Home
Help
Login
Register
Donate
Tech Forums
SOHC/4 Bikes
Topic:
CB550 engine rebuild kits??
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: CB550 engine rebuild kits?? (Read 3790 times)
Elniniomuchachos
Hot Shot
on:
February 24, 2010, 03:02:06 PM »
I'm tearing apart my engine, and want to rebuild it.
Are there any recommended rebuild kits?
Logged
fastbroshi
Puppet
Old Timer
Re: CB550 engine rebuild kits??
Reply #1 on:
February 24, 2010, 03:27:18 PM »
There's probably a few out there but kinda hard to find. Hit up David Silver Spares, I believe they have one. Keep in mind this doesn't have piston rings, bearings, etc., so know what you need beforehand.
Logged
Just call me Timmaaaaay!!!
campbmic
Sea-Foam and Flaming 151 is a dam good
Hot Shot
Reply #2 on:
February 24, 2010, 04:16:51 PM »
If your tearing into your engine people typically just purchase the things that need to be replaced. Your manual is very good at showing how to take apart the engine and how to measure the pieces to decide whether or not they need to be replaced. I just did this with my 75 550 as well.
The first thing I did was measure the cylinder bore. If it has exceeded the serviceable limit as outlined in the manual then you will need to bore it out. If that is the case then you'll need new larger rings and larger pistons.
If you don't need to bore it out then you can measure your piston diameter and see if its also within serviceable limits. If your pistons are good then measure the piston ring end gap and the side clearance. Just like in your manual!
Also, never reuse old circlips you have to buy new ones. Also, its highly recommended to replace all of the o-rings and gaskets while your in there. Many shops carry kits that have every o-ring and gasket you need.
Logged
Its hard to be wrong when you know nothing!
Print
Pages: [
1
Go Up
« previous
next »
Tech Forums
SOHC/4 Bikes
Topic:
