Author Topic: What am I missing here?  (Read 1240 times)
Offline lordwhimsey
« on: February 25, 2010, 07:46:13 AM »
I'm building my 550 up from (old!) parts and I've just put the back end together. I seem to be left with this 8mm gap on the back axle?
I can't see any more spacers on the parts fiche. The swingarm and wheel came off the same bike and I'm pretty sure I've put everything back where it should be. Should I use the axle to pinch the swingarm together?
Here's the other side; have I done something daft?
Never kick a man when he's down, he may get back up again
Re: What am I missing here?
« Reply #1 on: February 25, 2010, 08:17:21 AM »
Yes the axle nut piulls it together, if there is a gap like shown it is easier to get the wheel and spacers in.
 However, you may have a problem on the sprocket carrier side. Remove wheel and check that the STEPPED SPACER is in the carrier.. if you leave it out it will wreck a few things..
Offline sangyo soichiro
  • Tuck
  • ☢ the atomic playboy ☠
« Reply #2 on: February 25, 2010, 08:18:45 AM »
I'd prefer you take the more experienced members' advice over mine, but my anecdotal claim is that mine also springs out a little when I loosen the axle.  I just tighten the axle down.
But your adjustors in the bottom pic do seem a little too squeezed.  Like maybe they belong to a different bike or something.
1974 CB 750
1971 CL 350 Scrambler
1966 Black Bomber
Too many others to name…
Offline lordwhimsey
« Reply #3 on: February 25, 2010, 09:07:18 AM »
Thanks Chaps, very helpful.
754, which is the stepped spacer; I'm worried now!
But your adjustor's in the bottom pic do seem a little too squeezed.  Like maybe they belong to a different bike or something.
Well spotted. I just checked the parts fiche and the part number for the adjusters for the F model are different from the K. The mounting points on the K swingarm are 14mm compared to the F's 8mm so it looks like these adjusters are off a K. I could try and track down some now discontinued F adjusters or I might just use some washers. What do you think?
« Reply #4 on: February 25, 2010, 09:32:20 AM »
I dont think the adjuster hurt anything, cept looks..
 The stepped spacer;
 Most roller bearing assemblys have spacers between, to set or eliminate preload, which can hurt the bearings.
 On your sprocket carrier there is a spacer that goes into the bearing in the sprocket carrier, it is stepped as they use a larger ID bearing there. Then there is a portion of the spacer, larger diameter that projects inwards, that contacts the hub bearing.
 Usually a bit oily or greasy, they do somethimes fall out or get misplaced.
Offline lordwhimsey
« Reply #5 on: February 25, 2010, 12:42:56 PM »
Ah ha, thanks for clearing that up; I checked it and it's ok.
I reckon four m20 x 3mm washers, one each side of the axle mounting points should eat up 6mm of internal space and make the wheel a nice snug fit.
Thanks for your help Guys.
