Author Topic: Cleanng oil pickup screen.  (Read 2458 times)
Saml01
« on: February 25, 2010, 08:00:00 PM »
What is the accepted practice when it comes to taking care of these things?
I am really averse to taking off the right case cover because its messy, might necessitate a new gasket or permatex and generally looks like a pita.
Last oil change, the oil was free from any metal particulate, and looking down the fill hole into the sump, it looks clean.
Bike has 12k miles and im wondering if I should bother with it.
Offline Johnie
Re: Cleanng oil pickup screen.
« Reply #1 on: February 26, 2010, 06:04:09 AM »
What bike???
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline Kframe
  • Life is good!
« Reply #2 on: February 26, 2010, 08:58:30 AM »
Yeah what bike?
On the 550 I think the screen is up under the oil pan.
-K
2007 Triumph Bonneville T100, ARK'd, Pods, TOR's, Napoleon's, Innovate G5 Air/Fuel Gauge, Ignition Relocation by D9, Stebel Nautilus, Avon Roadriders
1984 Honda Shadow VT700c, Stock
1974 Honda CB550K, In rehab
1986 Honda Helix
Offline Johnie
« Reply #3 on: February 26, 2010, 09:16:12 AM »
Yeah what bike?
-K
Same on the 750K.
Oshkosh, WI  USA
Saml01
« Reply #4 on: February 26, 2010, 11:22:31 AM »
What bike???
My apologies, thought I put in my sig.
74 CB360.
« Reply #5 on: February 26, 2010, 12:28:57 PM »
Take it to a motor cycle shop and pay them to do it for you.
Saml01
« Reply #6 on: February 26, 2010, 01:04:03 PM »
I can do it myself, I just want to know if its due or can I ignore it for another oil change.
« Reply #7 on: February 26, 2010, 01:16:05 PM »
I don't know of any bike that has cleaning of the oil pump pickup screen as a regular maintenance item.  Good idea I suppose, but not necessary. You should clean the centrifugal (dixie cup) filter. We cheat on those by taking off the round cover (Prop the bike to the left a tad so noting runs out) Take the lid off the dixie cup, fish around in there with a rag on a screwdriver until its clean, put the lid back on and the cover. Piece of cake.
Saml01
« Reply #8 on: February 26, 2010, 02:30:16 PM »
What round cover? All I got is a whole crank case cover.
Offline tbpmusic
« Reply #9 on: February 26, 2010, 05:50:37 PM »
That's correct - 360's do not have the round cover he speaks of....
"If you can't fix it with a hammer, then it's an electrical problem"
Bill Lane
 '71 CB450 Mutant/ '75 CB200/ '81 CM200/ '71 C70M
« Reply #10 on: February 26, 2010, 06:23:00 PM »
Ooops my bad. I was thinking of the 350. Looks like you need to pull that cover. Your manual should recomend service intervals. But since that's the only way into the filter, I'd say every other oil change or once a year, whichever is more. But that's just me and I've already been wrong once.
Saml01
« Reply #11 on: February 26, 2010, 09:07:39 PM »
Recommended service interval is 6k miles on the filter and pickup screen.
I dont know if the previous owner did anything but it seems as though the engine was out of the bike.
Offline TomC
« Reply #12 on: February 27, 2010, 06:19:53 AM »
Hi Saml01
     If it were me I would do it the next time I changed the oil. Then I would know what things look like. If all is well maybe the 6k service interval is OK. If You have to clean out a lot of crud. I would clean it out again sooner that 6k.
     TomC in Ohio
TomC in Ohio
76 CB750 F1 Daily Rider
76 CB550 stalled project
76 CB400F Injured Reserve
« Reply #13 on: March 01, 2010, 09:03:55 AM »
6K is correct for cleaning out the centrifugal filter and the pick up screen. Get a new clutch cover gasket and take the permatex in your right hand and either :-
(1) Dump it in the trash or
(2) throw as far away a possible .
If you use that anywhere on the 360 you will end up needing a new head and cam cover along with cam and followers
Offline Green550F
  • Nothing is as cool as that which you made.
« Reply #14 on: March 01, 2010, 06:05:02 PM »
++++ Get real gaskets!
Silicone is ok in some cases but, a good gasket is unbeatable!
350/360 gasket sets are fairly cheap. Real cheap compared to doing it over!
93 Kawasaki Voyager XII
70 Honda CL350 Cafe
